Old Jun 03, 2012, 01:15 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by IceWind View Post
If that tuner is the same as mine, it has no RSSI pin and you'll need to solder it.
I'll see if I can find a photo I took when I did that to mine.
That would be awesome!!!
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jun 03, 2012, 02:00 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Here you go:
Max - 0.4v
Min - 4.80v
Hope it helps as you may have a different tuner.
PS: Yes I've swapped my SAW filter.
IceWind is offline Find More Posts by IceWind
Old Jun 03, 2012, 02:13 PM
Joined Aug 2009
Awesome IceWind!!!
Question, is that main chip ID TA8804F?
Old Jun 03, 2012, 02:24 PM
Joined Aug 2009
Thank you, found the Pin. Now I need to do some serious testing. Will report my findings.
Last edited by rimshotcopter; Jun 03, 2012 at 03:23 PM. Reason: Updated the Picture with RSSI
Old Jun 03, 2012, 02:31 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
nop, mine is the TDA8012
Old Jun 03, 2012, 02:32 PM
Joined Aug 2009
Thank you, your comment placed me on the right direction to locating mines.
Old Jun 03, 2012, 03:17 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
check to see if pin 19 is connected to one of these spots. Makes for an easy add on.
Martin Y is offline Find More Posts by Martin Y
Old Jun 03, 2012, 03:19 PM
Joined Aug 2009
Yeap, we are thinking on the same track. It is connected to that first hole there and I added a pin there.
I guess I should update that picture.
Old Jun 05, 2012, 09:00 AM
Joined Aug 2009
Update: I just finished testing the voltage of the above RX and it measures .86 volts with the transmitter turned off and 3.86 with the transmitter ON. Well within the range to read on an Arduino analog port however, I believe it would be wise to use an LM358 to buffer the signal.
Old Jun 05, 2012, 10:09 AM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
I don't think the tuner's send out a PWM signal, it should be a stable analog voltage.
Sometime ago I made some simple code to a arduino read it and show in a LCD and it was smooth and stable.
Have to try it again.
Old Jun 05, 2012, 10:14 AM
Joined Aug 2009
Well, sorry for the misinterpretation here, what I was implying is, the output voltage from the RX is within the voltage range to feed directly to an Arduino port without supporting circuitry however, it would be safer to use an LM358 to eliminate any possible draw down or excessive load on the RX.
Old Jun 05, 2012, 10:15 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
I tried a lm358 without much luck. Tell us how it goes.
jalves is offline Find More Posts by jalves
Old Jun 05, 2012, 11:02 AM
Joined Aug 2009
Question, did you use it to buffer the signal as shown in this drawing?
Old Jun 05, 2012, 11:59 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
No.
Test it, maybe it do the trick.
Old Jun 05, 2012, 12:01 PM
Joined Aug 2009
No.
Will do and report back. Need to build a new buffer, the existing one is an amplifying and not a voltage follower.
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
