Old Jan 20, 2013, 02:49 PM
FPV!
pisagor's Avatar
Joined Feb 2007
i am from turkey. test was wired not wirelles. I have a simple electronic information...
"Can you post here the Serial output of your gps unit?" how can i do that
pisagor is offline Find More Posts by pisagor
Old Jan 20, 2013, 03:15 PM
jalves's Avatar
Portugal
Joined Mar 2004
With a ftdi cable (or another serial interface) connect your gps to the PC, with a SerialTerminal (RealTerm comes to mind...) capture the gps strings and post them here.
What baud rate are you using for serial data?
Are the same for Arduino and the gps unit?
jalves is offline Find More Posts by jalves
Old Jan 21, 2013, 09:42 PM
FPV!
pisagor's Avatar
Joined Feb 2007
Today i solved my all porblems i use arduino uno on rx, arduino pro mini on tx.
Directly Connected pro mini pin10-->uno pin 2
I did bench test the first time with a GPS. But it did not work i think my gps not work at 115200bps. I look after
Second time using with ftdi cable. I tried this too. it didn't work at 115200pbs, never got a GPS signal. I checked port settings and ftdi cable set to 9600 bps. (windows port settings in device manager).
After a few attempts came to success with ardupilot emulator. Tilt work amazing i need 360 degree servo for the pan
i will try wirelles banch test. I hope that works..
Thanks for your patience, but not over :P
This tracker is cheap amazing and educational(for me )
Old Jan 22, 2013, 01:51 AM
Joined Sep 2010
Hi Jalves! My classic question -> Any news regarding video telemetry ?
msev is offline Find More Posts by msev
Old Jan 30, 2013, 07:02 AM
ntgr's Avatar
Joined Oct 2011
Any news
ntgr is offline Find More Posts by ntgr
Old Feb 09, 2013, 07:15 AM
ntgr's Avatar
Joined Oct 2011
Good news (for me)
Borrowed from a friend
5.8Ghz Transmitter- Receiver
and a camera.
Tomorrow i ll start to test the Tracker in the "real world"
Old Feb 10, 2013, 10:11 PM
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
Where is everybody?
Legot is offline Find More Posts by Legot
Old Feb 11, 2013, 05:43 AM
jalves's Avatar
Portugal
Joined Mar 2004
I am (still) here, answering questions when they are done (PM mostly).
As far as I am concerned, this project is "mature" and on hold.
With almost 400 downloads and only less than a hand full of declared users, this is not motivating to continue developing the project
Old Feb 11, 2013, 08:28 AM
Joined Sep 2010
Do you mean you will end developing for video telemetry version or for audio telemetry? Video telemetry could be more popular since a lot of people use Dennis Frie's osd.
Old Feb 12, 2013, 02:39 AM
Woppit's Avatar
United Kingdom, Hastings
Joined Jul 2012
Hi jalves, I only found your thread a week or so ago, I have ordered up some parts to build as I can't afford to buy commercial versions of the tracker. I can only enjoy this hobby because of people like you and the Multiwii guys, minim OSD and others that give up there time to do this stuff (wish I could do more!)
Please carry on this good work, I for one appreciate it!
Woppit is offline Find More Posts by Woppit
Old Feb 12, 2013, 02:44 AM
Joined Sep 2010
Me too, appreciate it! I would really like to see the videotelemetry version implemented into DF's Max-osd...That would be really sweet!
If you'll make it I will be the first to test it after you Jalves :P
Old Feb 12, 2013, 08:29 AM
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
I've been subscribed to this thread too for a long time. Don't have the use for a tracker atm, but expect to need one in the future. So even though there not a lot documented in use in the field, don't underestimate how much it means for a lot of us, that You and others put Your time in these threads. We learn a lot from You along the way. I'm hooked on Dennis' threads too. You both do a valuable job here.
HOL is offline Find More Posts by HOL
Old Feb 12, 2013, 03:48 PM
ntgr's Avatar
Joined Oct 2011
I was trying to compile AT_TX in ver 1.0 and i made this change.
In printing.pde
Code:
Serial.print("Valid Data= ");Serial.println(valid_data,BYTE);
with
Code:
Serial.print("Valid Data= ");Serial.println(valid_data);
I dont know if it is correct since still trying to learn.
Old Feb 12, 2013, 05:44 PM
jalves's Avatar
Portugal
Joined Mar 2004
Change it to:
Serial.print("Valid Data= "); Serial.write( byte(valid_data) );
But use the Serial.print out as minimal as you can get.
Serial.print is slow and can mess with the timings of the telemetry link.
Old Feb 12, 2013, 11:03 PM
Joined Feb 2013
I want to show my appreciation to dear " Jalves " for his great help. I am starting to build mine however I am still stocked in the fact that I have 900 mhz AV TX/Rx I do not know if I am able to run the system or not. Anyway my both thumb is up for you Jalves....
Drone_man is offline Find More Posts by Drone_man
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign Video Piloting (FPV/RPV) 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV/RPV - Equipment and Vehicles (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV/RPV - Equipment and Vehicles (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV/RPV - Equipment and Vehicles (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV/RPV - Equipment and Vehicles (FS/W) 4 Sep 08, 2011 07:53 AM
