Old Jan 06, 2013, 04:17 PM
ntgr is offline
Find More Posts by ntgr
ntgr's Avatar
Joined Oct 2011
I'm planning to use it as soon as one of this two arrives in my mailbox
http://www.hobbyking.com/hobbyking/s...Tx_Rx_Set.html
http://www.ebay.com/itm/5-8G-200mW-2...item1c1d46c776
Which one is better ?
Any suggestions ?
ntgr is offline Find More Posts by ntgr
Old Jan 06, 2013, 04:43 PM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
Yyy it's exacly the same... As You can see at pictures - RC305...
Grzechu is offline Find More Posts by Grzechu
Old Jan 07, 2013, 01:36 PM
ntgr is offline
ntgr's Avatar
Joined Oct 2011
Yeppp...
The question is IF will work as tracker..
Old Jan 07, 2013, 04:35 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
I did inverting amplifier for exacly that AV. Few post later mp7.5 show that works. Bevrc AV is on Boscam modules (hobbyking also).
Old Jan 07, 2013, 11:29 PM
mp7.5 is offline
Find More Posts by mp7.5
Joined Oct 2003
hi guys, that the same video tx/rx I'm using, btw I removed the build in microphone that come with the vtx. cheers
mp7.5 is offline Find More Posts by mp7.5
Old Jan 08, 2013, 07:51 PM
aquintero is offline
Find More Posts by aquintero
aquintero's Avatar
Colombia, Bogota
Joined Nov 2012
Hi,
While i was working with my uncle in 3D model and standard mechanical kit, Grzechu came with a simple model . We will made some improvements once is finish I will upload final design .
I am waiting my arduinos + servos.
regards,
Andres
aquintero is offline Find More Posts by aquintero
Old Jan 11, 2013, 03:27 AM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Can someone show me how to use delay in program ? I want to activate LCD. I printed my void and put it in "Printing". I use "delay(1000);" but it don't works. There are no receivied packages. Without delay it works, but with mismatch and values on LCD are false...
Old Jan 11, 2013, 07:26 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
You can't use a delay(1000), in this period the processor is doing nothing, thus not receiving or calculating anything.
In this project, the precise timings are everything.
Try this:
in the loop function, line --> if(data == 0b00100100){
after the function valid_packet() put your function print_lcd (avoid the use of delays here)
Try to print only one line in the lcd, if you have success then try to print the second line in the lcd.
remember, no delays in the print function!!!
jalves is offline Find More Posts by jalves
Old Jan 12, 2013, 12:23 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
LCD now looks like that.
It works, I checked by serial monitor and (GPS simulated by NMEA generator, and don't have servos yet) I have about 4-5 mismatch at 70 packages. I think it will not disturb.
I think I can add also buzzer when lipo <9V.
Old Jan 12, 2013, 12:47 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Very nice!
Did you use the trick I post above?
Old Jan 12, 2013, 01:13 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Thanks for Your solve, but earlier I found solution
static uint32_t time;
if(millis() > time) {
time = millis() + 2000;
here is all function for LCD
And use that
Old Jan 12, 2013, 03:45 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
Very cool with the LCD!
You should set it up so that if signal is lost it stores the last known GPS coordinants.
Another useful function would be to have 4 characters on the LCD reserved to display the current heading in degrees, this could also be "saved" in the event of complete signal loss, it looks like there's space after the longitude to put this in.
Legot is offline Find More Posts by Legot
Old Jan 12, 2013, 06:46 PM
pisagor is offline
Find More Posts by pisagor
FPV!
pisagor's Avatar
Joined Feb 2007
hi today i tried my tracker but i didn't work.
Ok my gps work at 115200 bps. I changed the code to 115200.
// Init serial communication;
Serial.begin(115200);
Then I then connected to GPS my arduino pro mini 5v 16mhz. Supply with 3s lipo. Red light on.
then I started to work on the receiver. i used two reguler servo. (i just want to check how it works. i will buy 360 degree servo)
connected like that
then supply with 3s lipo and led lights up. i press the button nothing happened.. where is my problem
here is the pictures
pisagor is offline Find More Posts by pisagor
Old Jan 13, 2013, 01:30 AM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Do You checked by wired connection (bench test)?
What AV do You have? I see antenna from 1.2GHz...
Old Jan 13, 2013, 08:29 AM
pisagor is offline
FPV!
pisagor's Avatar
Joined Feb 2007
yep i checked. my osd has a gps simulator i tried with that but got same results.
I connected uno directly to my receiver audio channel. I need to use any filter?
my vtx and rx
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
