Old Jan 02, 2013, 02:31 PM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
I have something like this (very similar and also 5k)
http://www.rapidonline.com/electroni...et-pot-68-0273
So it will be good or not? If not, how to hacked servo without resistors (dont work)?
Grzechu is offline Find More Posts by Grzechu
Old Jan 02, 2013, 02:51 PM
HOL is offline
HOL
Find More Posts by HOL
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
You can make it work with that pot. But there's some work to it.
First You must have it physically attached to the output shaft, so that when the shaft rotates, it changes the pots position. Then You'll have to rescale the servo.h's 180 degree to fit the resistance change on the pot, when a 360 degree rotation is performed. If it's a 10 turn pot, You'll get a rather small resistance change with a 360 degree turn, compared to the resistance change of eg a 180 degree turn on a std pot.
HOL is offline Find More Posts by HOL
Old Jan 02, 2013, 05:33 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
You mean I have to put new pot in tilt shatf?
So, I think that this will be better
Old Jan 02, 2013, 06:13 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Grzechu,
Why don't you buy a winch servo instead?
Wasn't simpler?
I have a link in post #1.
jalves is offline Find More Posts by jalves
Old Jan 03, 2013, 02:13 AM
HOL is offline
HOL
HOL
Joined Oct 2011
Yes that would probably be a better choice. Then connect the pot where the original pot was connected in the servo. But as Jalves says, it's better to get a winch servo. Then the pot is securely hidden and properly connected and scaled.
Old Jan 03, 2013, 02:24 AM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Because in one if first page i found that method to hacked servo and I was thinkinh what will work. Now I mounted servo to the tracker, I havent time and spend a lot of money
But... I think I must buy it (again).
EDIT:
I found in my country
http://www.kamami.pl/index.php?ukey=...oductID=195889
So, bye bye money ^^
Old Jan 03, 2013, 04:12 PM
pisagor is offline
Find More Posts by pisagor
FPV!
pisagor's Avatar
Joined Feb 2007
EDIT:
I'm going to buy from hobbyking
Ok here is my arduino's
pisagor is offline Find More Posts by pisagor
Old Jan 03, 2013, 06:25 PM
HOL is offline
HOL
HOL
Joined Oct 2011
Be aware, that the ones HK has in stock now, all turn more than one full turn, even though the description says 360 degree. They have one turn too, but they are in backorder atm.
Old Jan 03, 2013, 06:29 PM
HOL is offline
HOL
HOL
Joined Oct 2011
EDIT:
Great... Except for the money part ;-)
Old Jan 05, 2013, 09:03 AM
mp7.5 is offline
Find More Posts by mp7.5
Joined Oct 2003
Originally Posted by jalves View Post
Folks,
One little question to you all:
Who from you, that are reading this question, has this Antenna tracking device mounted, in working order and use it in the RC field with regularity?
I would like to hear cases of success (or the lack of it...)
Thanks.
Hi Jalves,
Thank you for making this antenna tracker open source, today i mount it on my naza quadrotor and the tracker is successfully working at flying field.
Cheers
mp7.5 is offline Find More Posts by mp7.5
Old Jan 05, 2013, 12:12 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
GREAT!
Thank you for your report
Can you give us more detail in regard to the hardware used and if you did some changes in the code?
Thanks.
Old Jan 05, 2013, 12:14 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Folks,
Anybody else is using this tracker in the field?
Or is mp7.5 the only one (besides me of course...)
Old Jan 05, 2013, 06:09 PM
mp7.5 is offline
Joined Oct 2003
GREAT!
Thanks.
hi jalves,
here are the details of hardware im using:
gps:
from bevrc nova osd.
tx:
hobbyking arduino v3 with sparkfun logic level converter.
rx:
arduino UNO.
vtx/vrx:
bevrc 5.8 ghz with crezchu's inverting amplifier, thanks crezchu for sharing.
servo:
hitech 645 and HS-785HB ( 3.5 rotation), added a map function after ch_1 out contrain to limit the pan sevo to 360 degree.
cheers
Old Jan 06, 2013, 05:13 AM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Originally Posted by mp7.5 View Post
vtx/vrx:
I'm Grzechu, 2 mistakes in one word! - I know, difficult Polish words
Glad to hear that inverting amplifier is work. No problem with that?
I saw Lawmate 2.4 on osciloscope, and that system also can be fixed, but I dont remember about Vpp (signal is inverted) Now I have also airwave 5.8 and now it's not useful... Time to sell
One picture from me, design for 1.2GHz and biquad, but fox is awful, but it was too late, parts was already cuted
Old Jan 06, 2013, 06:45 AM
mp7.5 is offline
Joined Oct 2003
Hi Grzechu,
very sorry for that , btw your tracker look good.
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
