Old Dec 28, 2012, 02:57 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Nope!
Time to investigate the culprit the tracker work very well in my home, but not in the field...
I have here 5 lm1881 chips, two of them (1st batch) work very well, the other 3 also work well together, but they don't mix well. I have to teak the code to work well with mixed batches of chips.
Tomorrow will take the pc with me to the field to try to understand what's going on there that prevents the tracker from working well.
In regard of the video telemetry for the openMAXosd the "module" is working well in the bench (wired and wireless), now it's time to integrate it in the openMAxosd code.
jalves is offline Find More Posts by jalves
Old Dec 28, 2012, 03:13 PM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
Ok guys, here is schematic for 5.8GHz AV from Hobbyking (Boscam) - inverting amplifier
And some pics
Now I'm going to connect servos. I hope that it will works
Grzechu is offline Find More Posts by Grzechu
Old Dec 28, 2012, 03:29 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
keep the fingers crossed
Old Dec 28, 2012, 03:48 PM
Magpie is offline
Find More Posts by Magpie
Belgium
Joined Sep 2004
Is it possible to use the ardupilot as the autopilot + upload the code from the openat and use is as antenna tracker TX as well ?
Magpie is offline Find More Posts by Magpie
Old Dec 28, 2012, 04:49 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
I think it could be possible, you just have to program two new PWM outputs (two new for the AT or two new for the AP) because I use two them of the original code for PAN and TILT.
If you manage to advance, please share the code here.
Old Dec 28, 2012, 09:16 PM
aquintero is offline
Find More Posts by aquintero
aquintero's Avatar
Colombia, Bogota
Joined Nov 2012
hi Jalves,
Would you please give a quick look to my material list? I have to make international order and it will take some time. I am working in CAD standard design for mechanical so you can make this proyect standard and share in ur wiki if you like, later I can improve the electronic diagrams.
main elements:
  • 2 x Servos (Hitec HS-645MG)
  • 2 x Arduino Pro Mini 328 - 5V/16MHz
  • bateries, bec
  • resistors and other minor elements
1. Do I need arduino Demilanove as RX side or is ok with arduino pro mini as the link below?
https://www.sparkfun.com/products/11113
2. What about LCD, do we need it? I found one below.
https://www.sparkfun.com/products/10862
thanks for your comments sorry for silly questions (but I hurry to order).
regards,
Andres Q.
aquintero is offline Find More Posts by aquintero
Old Dec 29, 2012, 04:16 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
The servos are good ones, but a little to much in strength (to much torque for our usual antennas, what antenna you pretend to use?), but for PAN you only get about 120~180 degrees with these servos.
No need to change anything in the code but bear in mind the 180š PAN.
You can use any arduino board with the atmega328 , I prefer the duemilenouve/uno for the ground station, but use a mini pro in the model plane.
You can use a lcd, but the tight timings don't recommend its use.
Check the good working of the tracker before adding the lcd to the tracker.
Old Dec 29, 2012, 12:16 PM
aquintero's Avatar
Colombia, Bogota
Joined Nov 2012
thanks a lot, itīs clear now.
Old Dec 29, 2012, 01:17 PM
ntgr is offline
Find More Posts by ntgr
ntgr's Avatar
Joined Oct 2011
I wonder how easy is to replace the pan servo with a stepper motor?
ntgr is offline Find More Posts by ntgr
Old Dec 29, 2012, 02:28 PM
aquintero's Avatar
Colombia, Bogota
Joined Nov 2012
Originally Posted by typicalaimster View Post
I follow the Wiki when I assembled mine.
http://code.google.com/p/opendiyantr...ki/Connections
I went with a Arduino Nano instead of a Mini... I'll probably scale mine back to two Nano's vs a Mini and a Uno.
TX:
1 - Arduino Board
1 - 1.8k Resistor
1 - 8.2k Resistor
1 - GPS
RX:
1 - Arduino Board
2 - 100k Resistors
1 - LED
1 - Resistor to match your LED (470 ohm on the schematic)
1 - Push Button
1 - 0.1uF Ceramic Capacitor
1 - 360 degree servo
1 - Servo
For the 360 degree servo I hacked the servo and removed the internal potentiometer and gear stop. I added a external 5k ohm potentiometer.
Hope that helps!
Hi, can I use Futaba S3305 for PAN? unfortunately i dont have to many options i found that one in similar proyect and towerhobbies store. Thanks for your recommendation.
S3305
Operating Voltage: 4.8-6.0 Volts
Operating Speed (4.8V): 0.25sec/60 degrees at no load
Operating Speed (6.0V): 0.20sec/60 degrees at no load
Stall Torque (4.8V): 99 oz/in. (7.1kg.cm)
Stall Torque (6.0V): 124 oz/in. (8.9kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Counter Clockwise/Pulse Traveling 1520-1900usec
Potentiometer Drive: Indirect Drive
Thanks for your comments.
Old Dec 29, 2012, 03:26 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Folks,
One little question to you all:
Who from you, that are reading this question, has this Antenna tracking device mounted, in working order and use it in the RC field with regularity?
I would like to hear cases of success (or the lack of it...)
Thanks.
Old Dec 29, 2012, 04:07 PM
pisagor is offline
Find More Posts by pisagor
FPV!
pisagor's Avatar
Joined Feb 2007
here is my arduino's i will start next week
pisagor is offline Find More Posts by pisagor
Old Dec 30, 2012, 04:01 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Jalves, what sould I change in TX if I want to use pin 11 instead of pin 10? I burnt it
I changed
" pinMode(11,OUTPUT);"
But it doesn't work
Old Dec 30, 2012, 04:06 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
I changed
But it doesn't work
It's not "just a pin"
Pin 10 is the MOSI-pin if I remember correctly. It have a 8-bit buffer to send out chars, and can be used at a high speed (8MHz).
If you have really fried pin 10, I would suggest to buy a new Atmega328P. If it's an Arduino with the Atmega328P in socket, you can get them quite cheap with bootloader.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Dec 30, 2012, 04:20 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Hm, I don't say precisly. I can't solder into pin 10, now it is pure laminate. I know that I can solder it into atmega or ftdi but I don't have good soldering.
Eh, again costs This will be my third Arduino nano ^^
So, it can be only pin 10?
I found:
SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication, which, although provided by the underlying hardware, is not currently included in the Arduino language.
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
