Old Dec 11, 2012, 06:38 AM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
Jalves, Could You see into the picture?
Top graph is from the output signal arduino TX, It seems be good. Bottom graph is from output of receiver AV. I tried to see output directly from receiver and after Bench filter, but It is almost the same...
Can we do something with it? I'm little nervous because I'm doing that tracker to get the title of engineer in my technical university... And I have 1 month...
Grzechu is offline Find More Posts by Grzechu
Old Dec 11, 2012, 07:19 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
So, you are ripping of someons work to get your self engineer title instead of doing it your self, and than on top of that you're asking for support instead of trying to troubleshoot it alone?
hefest is offline Find More Posts by hefest
Old Dec 11, 2012, 08:33 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
What can I say, remove the fox Video system from the equation and buy a GOOD video system that we know that works.
Airwaves modules work as a charm, try to buy the modules alone and build the Tx/Rx or buy assembled airwaves Tx/Rx or buy immersionRc products, they are expensive but good ones.
Look at the signal of CH2, the video Tx/Rx absolutely destroy the PWM of the signal (and it also invert the pulses).
jalves is offline Find More Posts by jalves
Old Dec 11, 2012, 08:36 AM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Ripping? I'll write that it is not my software. My topic is 'video transmission in UAV', I made myself mechanics of tracker. I draw my antena in solid works with my idea. That is open source and I'll WRITE THAT I USE JALVES SOFTWARE, because when my want to get engineer title we don't have to discover all parts. We can use parts that are already exist.
Moreover, I writed over a dozen pages that I want to use it.
Thanks Jalves, I think I'm gonna buy... I have also 5.8GHZ from hobbyking, I'll try it...
Old Dec 11, 2012, 02:05 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Jalves, is it any difference about frequency? I have FrSky, so I need 5.8GHz video.
And I think about
http://www.dpcav.com/xcart/5.8GHz-A-...r-Uno5800.html
and
https://www.dpcav.com/xcart/5.8GHz-A...ter-600mW.html
Old Dec 11, 2012, 04:20 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
Shut up.
And I think about
and
Frequency won't matter as long as you are getting a good link quality. Those are really high quality systems from what I've heard. If its in your budget I don't think that you will find anything better. Good luck
Legot is offline Find More Posts by Legot
Old Dec 11, 2012, 04:35 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Grzechu,
I can only talk about what I know, and that is airwave's 2.4GHz modules.
Those Tx/Rx should be good quality, they have the immersionRC logo on it, what I don't know is if they invert the audio signal.
if I were you, I would ask here if they deliver the audio signal as the Tx receive it.
Old Dec 12, 2012, 06:40 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
I found few different 5.8 receiver with airwave modules, someone have audio level 2 V p-p, other 3 V p-p. What is Yours, jalves?
I found very similar to Your (at 5.8GHz)
http://www.electronicarc.com/catalog...0fbd3a963b84dc
But it has -85dBm sensitive...
UNO5800 has -90, but it has 3 Vp-p audio level, So i'm not sure it'll works... Eh
Old Dec 13, 2012, 08:50 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
I use this one.
The problem isn't the audio voltage level, it is what the link do to the audio signal, as you can see with your Fox video system.
Old Dec 13, 2012, 05:20 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
I think I'll buy
and
And I'm gonna also pray to that immersion will work...
Old Dec 13, 2012, 06:38 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
good luck with that, let us know if it works.
Old Dec 14, 2012, 12:46 AM
Legot is offline
Legot's Avatar
Joined Nov 2009
Can we get any more information on the video telemetry? Like a schematic and maybe a test code to play with?
Old Dec 18, 2012, 06:28 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
I think I have solved that. FOX800 is definitely not going with that project without much work, because You saw what receiver did with signal.
Lawmate is better, but it is not square-wave signal in 100% (strange slopes) and it inverted the phase.
But AV 5.8GHz from Hobbyking is good. It is square signal, but inverted. Audio level - about 0,7 V p.p. So, not enough V for arduino logic level (5V) even after inverted. I think airwave modules must have higher (about 3V p.p) when working.
I think I repaired it with my friend (don't have much time today, but wireless bench test was succesful with NMEA generator - packages were transmitted and LED was off). We inverted signal and raise it to 5V (exacly about 4,7V) with transistor.
So, inverting amplifier... It's a pity that I ordered airwave and spend 100$
I'll write more tommorow, time to sleep.
Old Dec 19, 2012, 01:48 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Can you show some pictures how you attached the transistor and which one did you use.
msev is offline Find More Posts by msev
Old Dec 23, 2012, 03:15 AM
msev is offline
Joined Sep 2010
Jalves do you have any more news with video-telemetry on Max-osd?
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
