Old Nov 25, 2012, 01:13 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Originally Posted by jalves View Post
one packet with aprox. 31bytes
Do you plan to transfer any other data also? Or just gps info required for tracker ..
Maybe rssi could be useful, connected to some leds installed in video goggles so you could see some colour shining in goggles, like red for critical rssi green for good rssi
Code will be incorporated into diy-osd right?
msev is offline Find More Posts by msev
Old Nov 25, 2012, 02:19 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
maybe yes, maybe not
I think opendiyOSD_max7456 is a better candidate
jalves is offline Find More Posts by jalves
Old Nov 25, 2012, 02:24 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
If you use H-sync and V-sync from MAX7456, you might be able to use MAX7456 for OSD-overlay, and atmega for processing and video-downlink. If you get really good results, we can just add it to next PCB-design
Dennis Frie is offline Find More Posts by Dennis Frie
Old Nov 25, 2012, 02:59 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
I'll do it, need to contribute something
Does anyone have anything against pads for a GPS on board?
Legot is offline Find More Posts by Legot
Old Nov 25, 2012, 03:03 PM
Just another user
Joined Feb 2011
Like this:
(was just a layout I considered while designing)
Sounds like a plan
By the way, have you received your PCB with the OSD design yet?
Old Nov 25, 2012, 03:13 PM
msev is offline
Joined Sep 2010
Hope LM1881 version will also get some of your love
Old Nov 25, 2012, 04:21 PM
Legot is offline
Legot's Avatar
Joined Nov 2009
Like this:
Sounds like a plan
Alot like that, but in my brainstorming I think a Fastrax 3339 based GPS would be better for most people, along with a single size of SMD components (either 0603 or 0805), and a header layout like the other one I designed before (maybe it will be shield compatible )
I haven't gotten my boards yet, I'm going through Seeed Studios, and they apparently had an issue that set their PCB fab back abit.
Jalves, even though you can receive 99.9999% of the sent data through wired video, have you tested what the minimum percentage of sent data that is needed to get useable information, or is that still to come?
Old Nov 25, 2012, 04:56 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Legot,
we are still in the very beginning of the video telemetry for the opendiy projects.
Old Nov 25, 2012, 06:04 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
A small follow up, opendiyAT did another small step towards video telemetry.
We have already a FULL package received through wired video signal with 100% error free
Old Nov 27, 2012, 12:53 AM
Legot is offline
Legot's Avatar
Joined Nov 2009
In the opendiyAT program, is there any problem with changing the audio output to a pin other than Digital 10? Like if I were to switch it to Digital 6,would all be well?
Old Dec 01, 2012, 10:41 AM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
Hi again,
Now it works. I put GPS on the stick outside the window. In first 2-3 minutes it doesnt't work, but after few tries, It worked. Is it normal that GPS needs few minutes?
And I get something like this.
Code:
$PAK,531248352,231512016,291*48
Time= 153434
Date= 11212
Valid Data= V
Sats= 8
current_loc.lat= 531248352
current_loc.lng= 231512016
current_loc.alt= 291
ground_speed= 0.00
ground_course= 238
108062
Time= 153434
Date= 11212
Valid Data= V
Sats= 8
ground_speed= 0.00
ground_course= 238
108120
Time= 153434
Date= 11212
Valid Data= V
Sats= 8
ground_speed= 0.00
ground_course= 238
So now I'll try connection via cable to arduino RX (without resistors in TX, directly pin 10 in TX to pin 2 in RX.
How to enable in RX to see parametres?
And also i have question about Diode in TX do digital pin 13 to see GPS status. Can I connect directly LED diode? What voltage is there in HIGH status? I read that in pin 13 there is only 1.7V?
Grzechu is offline Find More Posts by Grzechu
Old Dec 01, 2012, 11:53 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Grzechu,
Now that you know that the arduino Tx is working as it should (receiving gps data and retrieving the lat, long, alt ), comment the print commands and connect the pin 10 of arduino Tx to pin 2 of arduino Rx.
In arduino Rx code uncomment the print statements to see if the Rx is receiving the telemetry.
Start (one each time) with print_string_buf(); then print_pak_decoded(); then print_track_data(); and finish with print_servo();
In the field choose the output you like more.
In regard to the pin13 association with the led, you can use pin13 with an external led (is this what you want to accomplish?) but don't forget to add a aprox. 330Ohm resistor in series with pin13-led-resistor-gnd.
Old Dec 01, 2012, 11:54 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Legot,
pin6 is already used to indicate absence of telemetry, what do you want to accomplish?
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Video telemetry is working in the bench.
Have yet to fine tune it.
Old Dec 01, 2012, 02:19 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Hm, what is ground course in printing? And altittude is above the sea level? How can I know altittude above the ground?
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
