Grzechu,
Lets do the following: 1. Use your ftdi cable and NMEAGEN, select 38400bps in NMEAGEN and see if the opendiyat print the gps data. If it do, then we pass to 2. 2. Connect Arduino's GND and +5V to your remzibi gps receiver, connect the arduino board to the usb port of your pc (in this way you have powered the arduino board and the gps receiver) Now, connect your ftdi cable to other usb port of your PC. Connect the gps output to the Rx port of the ftdi cable. Use a Serial monitor (connected to the COM port of your ftdi cable) and wait till the gps acquire a good fix (gprmc and gpgga with good info), now move the wire from the ftdi cable to Rx of the arduino board. you should see now the gps info collected by the arduino, also you should see the $PAK sent to the modem if you uncomment print_modem. With my remzibi gps unit and my arduino board I had no problems to use it to show lat, lon, etc using OpenDIY_AT_TX_02a_alfa |
Change somthing in output condition? ![]() In step 2, Can i move the wire when arduino is turn on? |
Change period for 5HZ, degree dec. to 4 , port number choose ftdi COM port and speed 38400bps.
fill the Track setting with valid data. Go to Gearth and collect some coordinates around your rc field. This will be useful to understand if the tracker is working well when bench testing it. When ready, press idling to allow the opendiyAT to fix the home position and then press start |
Grzechu,
First we have to know if "your" opendiyAT and your Arduino board is working well, thus you should use NMEAGEN to generate gps sentences, of course you have to use your ftdi cable to be able to extract those sentences from the PC. Once you have NMEAGEN sentences through your ftdi cable (led is flshing to the cadence of 1Hz or 5Hz if you change the setting as I propose), connect ftdi Tx line to the arduino Rx line (GND is common if you have the arduino powered by teh PC's usb port). This is the first test, check if opendiAT Serial.print the gps data to you screen using a serial monitor (from arduino's IDE , hyperterminal or other). Then replace the NMEAGEN by your gps unit, maintain the ftdi cable connected to the PC. Now use the hyperterminal connected to your ftdi COM port, do the connections as I explained earlier (GND and +5V from Arduino to gps unit, and gps Tx to ftdi Rx) and check to see if you manage to get a fix (see in hyperterminal window if the gps sentences has the coordinates of the place you are sitting on), when it does, change the gps Tx wire from the ftdi Rx and connect it to the Arduino's Rx port. Now, you should see in arduino's COM port serial out from arduino's IDE the gps data printed by opendiyAT. |
| Thread Tools | |
| Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? | daign | Video Piloting (FPV/RPV) | 2 | May 17, 2012 03:36 PM |
| Sold 360 Servo for (Antenna Tracker or PAN).....NEW | crd | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Apr 15, 2012 05:39 PM |
| Sold RVGS Antenna Tracker | scrape | FPV/RPV - Equipment and Vehicles (FS/W) | 0 | Mar 31, 2012 11:18 PM |
| Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos | imagebuff | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Mar 20, 2012 02:26 AM |
| Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker | thefokker | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Sep 08, 2011 07:53 AM |
