Old Nov 04, 2012, 10:36 AM
ntgr is offline
Find More Posts by ntgr
ntgr's Avatar
Joined Oct 2011
Hi.
Today i made my first attempt to bench test the Antenna tracker with no success .
What i've done is.
1.Uploaded the AT_TX sketch to my 1st arduino.(Transmitter)
2.Changed the baudrate to 115200 here ( because my GPS OUT settings are 10 Hz 115200 )
void setup() {
Serial.begin(115200);
pinMode(10,OUTPUT);
TCCR1B = 0x00; //stop timer
.......etc.....
3. TX out from my GPS goes to RX (physical PIN 2) of my "transmitter"
4. Power up everything and opened Serial monitor
I received the following
Projecto DIY_AT, Tx V02a-alfa
Ready!!!
no GPS, last 20s
What i m doing wrong ?
ntgr is offline Find More Posts by ntgr
Old Nov 04, 2012, 11:16 AM
ntgr is offline
ntgr's Avatar
Joined Oct 2011
Found it....
NO COMMON GROUNG WITH GPS !!!!!
Old Nov 04, 2012, 01:58 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Now you can use NMEAGEN and simulate a circular trajectory and see the pan and tilt servo following the "model".
Do it first with the wired connections and then with the RF link if the 1st test succeed.
jalves is offline Find More Posts by jalves
Old Nov 05, 2012, 07:36 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
This is great just what I need.
I'm planning to decode FY-21AP/FY-31AP autopilot data and send it via audio to the ground.
http://www.rcgroups.com/forums/showt...9#post23186248
hefest is offline Find More Posts by hefest
Old Nov 05, 2012, 12:33 PM
ntgr is offline
ntgr's Avatar
Joined Oct 2011
What kind of servo should i use ?
A modified continuous servo will do the job or i have to buy something like this
http://www.ebay.com/itm/SM-S4309R-JR...item1c183e443a
Old Nov 05, 2012, 12:37 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
I use a GWS S125 1T 2BB Sail Winch Servo for PAN servo and a regular servo for TILT
Old Nov 06, 2012, 04:39 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Suggestion, piezo speaker alerts would be very useful while you are flying instead of only led, e.g. when tracker is not receiving valid data.
Old Nov 06, 2012, 04:50 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Originally Posted by jalves View Post
msev,
The work is on hold, have some troubles to work first.
The mail man lost a helper I bought to work the video signal
, bad mail-man ... So did you re-order that "helper" ? ...Is it already on the slow-boat to Portugal
msev is offline Find More Posts by msev
Old Nov 06, 2012, 08:40 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
It was an expensive helper, have to "breath" again to be able to order it again .
piezo speaker addition is a good idea, I will implement that asap.
Old Nov 06, 2012, 10:56 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Was it a fancy dual-channel high-speed ADC with a screen and external connections by any chance? (hint hint, oscilloscope)
Dennis Frie is offline Find More Posts by Dennis Frie
Old Nov 06, 2012, 11:03 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yes, a old digital one.
The problem is that only now I am aware of the caps problem of this vintage models
It seems it is again on my way, lets see if the mail man this time delivers the goodie to whom it belongs...
Old Nov 06, 2012, 12:36 PM
msev is offline
Joined Sep 2010
Sorry to hear that it was expensive ... Thanks for sticking with the project !
Old Nov 06, 2012, 01:20 PM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Originally Posted by Dimitris76 View Post
It's good to have innovation and many options to choose from but Dakar with it's matching Lynx tracker has been around for some time now, the airborne board is smaller/lighter, needs much cheaper hardware (10x cheaper than the arduino boards) and doesn't occupy your audio channel either...
Dimitrios
The fact that its not open source defeats the purpose. The point of projects such as this is to share with other and to gain with as much developers involved as possible. For example this antenna tracker can be used with different onboard solution thanks to open source.
Old Nov 06, 2012, 04:44 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
The goodie is my hands, time to invest some free time playing with the new toy
Old Nov 08, 2012, 09:46 AM
msev is offline
Joined Sep 2010
Awesome, so this equipment will help you with video-telemetry development? Very cool
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
