Old Sep 30, 2012, 05:20 AM
skywalker34 is offline
Find More Posts by skywalker34
Joined Jul 2011
hi jalves,
I am following this thread for few week and decided to built my own tracker
I have now received the antenna, 4" Ball Bearing Lazy Susan Swivel Spinner Turntable , slip ring, gears and servo + arduino's board.
I will assemble all those part within very next week
I have downloaded the firmware's file but can't really understand the links between those: I suppose I should open openDY_AT_RX and send (compile) to the arduino board,
but how the other files are connected to the main "openDY_AT..." in your code ?
where should I change the code to use full & unlimited pan rotation ?
I will try to make pictures of # step when assembling my system
Rgds
skywalker34 is offline Find More Posts by skywalker34
Old Sep 30, 2012, 06:43 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
No need to worry, Download the arduino IDE (it creates a folder Arduino in your Documents folder), then just download the ZIP and install it in your Arduino folder.
Navigate to the folder you just create and click in any .pde, arduino ide should open the file and "attach" all the needed files.
As is, the software will use 360PAN if you use a winch servo or aprox. 180PAN if you use a regular servo.
I don't know if using a unlimited rotation servo will work. Try it and let us know how it goes.
Please, post some pics of the build
jalves is offline Find More Posts by jalves
Old Sep 30, 2012, 07:47 AM
Joined Jul 2011
Hi jalves,
Than you for this prompt reply
I will flask the firmware this next week
What is #if #endif usage ? i don't know and can't find info on arduino.cc
Rgds
Old Sep 30, 2012, 09:00 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
it limits a portion of code that is executed IF the condition is true or else ignore it.
Old Sep 30, 2012, 10:06 AM
Joined Jul 2011
I know if statement, what I don't know is the #if...
same purpose ?
Old Sep 30, 2012, 12:56 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yes.
All the code that is included between #IF and #ENDIF is executed if the statement attached to the #IF is true.
Old Sep 30, 2012, 01:14 PM
Joined Jul 2011
Originally Posted by jalves View Post
Yes.
Thanks, I don't know this statement !
We can learn all time from other...
I will take more time to understand your firmware properly, I want to use LCD to see all message sended to serial monitor, have setup message and so on....
I would like also to send GPS to blue tooth module to catch then on my laptop and send to google apps
I wonder if the gps info are good enough, why no install OSD on the tracker output and have less weight and power consumption on the multicopter, in this case the arduino TX can also modulate Voltage reading using embedded ADC those would have to be split on RX .....
Old Sep 30, 2012, 01:40 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Well,
The software is only a starting point, don't forget to share with us the developments you add
Old Oct 01, 2012, 12:30 PM
Joined Jul 2011
Hi jalves,
witch version of arduino ide are you using ?
mine didn't accept your file (for Rx) saying :
"As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead."
Rgds
Old Oct 01, 2012, 01:50 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Hi Sky,
You have to useArduino ide <1 i.e. arduino 23.
didn't port the code to Arduino 1.x yet.
Old Oct 03, 2012, 12:53 PM
Joined Jul 2011
Hi Jorges
I download the previous 0.23 IDE
The verifying i working good now is this version
By the same way I have seen that there is now 1.0.1 version available (I was 1.0) always a wagon late
I have all material now and I will starting building the main frame this week
This will be alu frame and antenna's vertical support will be removable to reduce the volume to a very flat case for transportation, antenna will act as the top cover like a briefcase.......
I have to buy a briefcase handgrip now
I will send picture as I will start assembly
Old Oct 09, 2012, 02:43 PM
msev is online now
Find More Posts by msev
Joined Sep 2010
Jalves did you maybe make any more experiments with videomodem code?
msev is online now Find More Posts by msev
Old Oct 09, 2012, 04:36 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
I am still working on it, slowly...
but at this rhythm, it will take a while.
Old Oct 10, 2012, 09:47 AM
msev is online now
Joined Sep 2010
Cool thats good news, means sometime its gonna be published ...Whats up with muerzi do you maybe know?
I'm waiting for beta testing whenever its ready
Old Oct 24, 2012, 04:00 PM
stupsi99 is offline
Find More Posts by stupsi99
Joined Nov 2011
Hi Jalves!
What an awesome project! A huge respect.
I am planning on doing something similar, possibly for my bachelor.
The idea is to downstream UAV serial information of a whole lot of sensors and decode it on the ground. So far they have done it with an xbee which hasn't been a great success.
Do you know about the amount of information that can be streamed via audio?
Looking forward to trying your code soon!
-Phil
stupsi99 is offline Find More Posts by stupsi99
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
