Old Sep 21, 2012, 04:10 AM
vikedal is offline
Find More Posts by vikedal
Joined Jul 2011
Originally Posted by jalves View Post
Wiki Updated!!
Nice
vikedal is offline Find More Posts by vikedal
Old Sep 21, 2012, 05:23 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
Excelente trabalho Jalves!
HF_ATL is offline Find More Posts by HF_ATL
Old Sep 21, 2012, 08:48 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Obrigado HF.
Anima-te e constrói um opendiyAT
jalves is offline Find More Posts by jalves
Old Sep 22, 2012, 02:55 PM
vikedal is offline
Joined Jul 2011
Is this right?
http://vimeo.com/49977639
Old Sep 22, 2012, 04:55 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Vikedal,
I couldn't understand much of your video, can you upload a improved (more focused, improved definition) video??
Old Sep 22, 2012, 05:49 PM
vikedal is offline
Joined Jul 2011
Is this better?
What information will you see in the serial monitor?
http://vimeo.com/49983274
Old Sep 22, 2012, 06:18 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
It seems like your serial monitor is at the wrong baud rate. It should work if you change the receiving rate to 9600 baud.
Legot is offline Find More Posts by Legot
Old Sep 22, 2012, 06:35 PM
vikedal is offline
Joined Jul 2011
It is at 9600... What should the other be?
Old Sep 22, 2012, 06:46 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
When you power your arduino, do you see the welcome message "Projecto DIY_AT, Tx V02a-alfa" "Ready!"
EDIT:
If you are using the version from the repository (The Tx version) it should be 9600bps, if you are using the Rx version, it should be 38400bps.
Old Sep 23, 2012, 07:58 AM
vikedal is offline
Joined Jul 2011
EDIT:
Is it just "Projecto DIY_AT, Tx V02a-alfa" "Ready!" That should come?
Old Sep 23, 2012, 09:45 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yes.
But if you uncomment
//print_data();
You should see more action, good to bench test, but avoid it in the model.
Old Sep 23, 2012, 12:18 PM
vikedal is offline
Joined Jul 2011
final test (0 min 25 sec)
Is it ready?
Old Sep 23, 2012, 02:19 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
I couldn't read any sentences in the serial monitor, but it seems you are good to go.
Now test it with the wireless link, airwaves modules are 100% compatible, any other brand has to be tested.
Old Sep 23, 2012, 02:25 PM
vikedal is offline
Joined Jul 2011
So i do it the same way on the pc only wireless?
Old Sep 23, 2012, 04:44 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yes, you remove the "blue" wire (see wiki) from pin 10 and connect to audioIN of your video Tx (don't forget to connect the ground wire between Video Tx and arduino), in the Rx part connect the audio OUT of the Video Rx to the arduino's pin2 (again, don't forget to connect GND between video Rx and arduino GND).
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 04:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 06:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Apr 01, 2012 12:18 AM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 03:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 08:53 AM
