Romania, Dolj, Craiova
Joined Sep 2007
I believe you and know the fun is to learn (and teach), I was 10 years in higher education.
But, as efficiency, the best move for me was to switch to CP, that makes tracking and diversity obsolete, imo. |
Latest blog entry: JRSky - birth of a dream radio
I've also thought about error checking. A simple check character on the end of each message should pick up most errors. The decoder can also look at the data and ignore messages that are unreasonable. ie. If the plane is 500 meters away it's not going to be rotating 1/4 turn between messages. Limiting the movement rate based on last known plane position etc. There may also need to be a search pattern if contact is lost. I'm still thinking about this one. A search pattern could be based on the last known position and distance with time. Lots to consider. Paul |
@msev
I was just meaning that I will put some comment in the DIY-OSD thread rather than clutter this thread which is about the open source antenna tracker using audio data link. http://www.rcgroups.com/forums/showthread.php?t=1473207 Much of the antenna control is probably more relevant here, but I haven't got to the decoder yet. I quite liked the look of Happy Killmores antenna tracker: http://diydrones.com/profiles/blogs/antenna-tracking-in But I don't want to use a PC program other than maybe just a terminal to do set up. I use Linux 99.9999999% of the time so a Windows program is just more work. Paul |
| Thread Tools | |
| Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? | daign | Video Piloting (FPV/RPV) | 2 | May 17, 2012 03:36 PM |
| Sold 360 Servo for (Antenna Tracker or PAN).....NEW | crd | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Apr 15, 2012 05:39 PM |
| Sold RVGS Antenna Tracker | scrape | FPV/RPV - Equipment and Vehicles (FS/W) | 0 | Mar 31, 2012 11:18 PM |
| Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos | imagebuff | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Mar 20, 2012 02:26 AM |
| Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker | thefokker | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Sep 08, 2011 07:53 AM |
