Old Sep 20, 2012, 09:49 AM
vikedal is offline
Find More Posts by vikedal
Joined Jul 2011
Originally Posted by jalves View Post
Yes, if you are using independent power source to each arduino boards.
Maybe a dumb question. What should happend when i do this?
vikedal is offline Find More Posts by vikedal
Old Sep 20, 2012, 09:52 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
How to do Wired bench tests:
I connect both arduino boards to my PC using two usb ports (this way we have common ground), use a gps emulator and a ftdi cable to feed gps sentences to the arduino as Tx.
I only have now to connect a wire between pin 10 (of arduino Tx) and pin 2 (from arduino Rx).
Using a PC Serial monitor over the usb port of arduino Rx, you should see the package transmitted through the wire and printed in the serial monitor window.
In the pic below, the blue wire carry the audio signal (vikedal, as you see I use only one wire, the common ground is maintained by the usb connections), the rest of the wires is for another project that I have (but is on hold).
jalves is offline Find More Posts by jalves
Old Sep 20, 2012, 11:55 AM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
I have to buy another arduino because I burnt my old one ( ), So... Is it anything difference between arduino nano 3.3V or 5V? I see that we connect GPS to 3.3V output, so what the practical difference?
I'm thinking about that
LINK
And turn it on 3.3V or 5V? It is anything difference with that scheme?
jalves, Could You tell me anything about resistors and capacitors? I'll use that tracker to my study, my work will name "antenna tracking in UAV video system". And I don't know how to calculate that value. Why 8.2Kohm, why 1.2kihm and others...
I'll revenge with pictures from the building, and movies from testing it
Grzechu is offline Find More Posts by Grzechu
Old Sep 20, 2012, 12:04 PM
vikedal is offline
Joined Jul 2011
So i connect the ftdi where the green wire from the gps are? Can i just conect the audio wire from the Tx with the audio wire from the Rx?
Old Sep 20, 2012, 12:19 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
@vikedal,
ftdi (tx pin) ---wire--->arduinoTx (Rx or pin 0)
arduinoTx (pin 10)----wire---> arduinoRx(pin 2)
All powered by usb connections.
@Grzechu
That scheme was done for the situation that vikedal presented here and that contained some errors.
I re-did vikedal's scheme with the correct connections, thus the use of a 3,3V gps rx.
I use only 5V gps receivers, thus I power them from the same bec I power the osd.
The capacitors and resistors are used to adapt or change the electric signals .
For instance, the two resistors you mention were used as a voltage divider, to reduce the audio signal voltage and spare the audio input from high level audio signals.
Old Sep 20, 2012, 12:33 PM
vikedal is offline
Joined Jul 2011
@vikedal,
@Grzechu
Sorry for all the dumb questions. One last. You disconnect all the resistors and the other parts for the test?
What programs do you use?
Old Sep 20, 2012, 01:11 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
I have 3.3V GPS so I think that that scheme is for me too.
I asked about arduino. What is the difference between 3.3V/5V? If I'll buy adjustable version, wchich voltage have I use? Or maybe buy normal 5V version? Or maybe it's all about GPS connection?
Scheme for vikedals is for 3.3V or 5V operating voltage (arduino)?
Old Sep 20, 2012, 01:13 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yes, it is a bench test, you are connecting the two arduino boards together, thus no need to adapt signal levels, the two arduino boards talk to each other using the "same" type of signals.
When we put the RF link between them, then we have to adapt signals to increase the odds to succeed (arduino tx to audio in of Video Tx and Video Rx audio out to arduino Rx).
gps emulator (HappyKillmore's, NMEAGEN or google it) and serial monitor (realterm, putty or google it)
Old Sep 20, 2012, 01:14 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
You could try 3.3V, but I can't guide you, I didn't try 3,3V version.
Old Sep 20, 2012, 01:16 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Arduino board (Uno or Duemilanove) has 3,3V and 5,0V output, we can choose the desired voltage.
Old Sep 20, 2012, 01:31 PM
vikedal is offline
Joined Jul 2011
Can't you update the wiki with all the information you have posted now? Would be very helpfull for us beginners
Tnx for all the help Jalves
Old Sep 20, 2012, 04:04 PM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
How can I measure the audio voltage? I'm gonna use arduino 3.3V, so I think that it will be different values of resistors ( now are 1,8 and 8,2kohm). Or maybe not?
How you calculate resistors value?
Old Sep 20, 2012, 05:47 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
The choice of 3.3v and 5v depends on the specific type of GPS you are using, which gps are you buying, do you have a link?
Legot is offline Find More Posts by Legot
Old Sep 20, 2012, 06:06 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Wiki Updated!!
Old Sep 21, 2012, 02:58 AM
Grzechu is offline
Grzechu's Avatar
Poland
Joined Jun 2008
Ups... I found that my GPS (from remzibi OSD) works on 5V So I'll buy arduino nano 5V, and power directly from 5V
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
