Old Sep 16, 2012, 09:12 AM
vikedal is offline
Find More Posts by vikedal
Joined Jul 2011
Originally Posted by mrfliboy View Post
Taken from the caption below the picture:
I did not have the proper resistors, so I used a pair of 3.57 for the 1.8, and 4) 1.5 and a 2.2 for the 8.2. Power in on the red/black side Audio out opposite
Okey
Very clean mounting nice job
Where did you get the frame they where mounted on?
Did anything on the Rx side?
I'm still waithing for the arduino's to arrive
vikedal is offline Find More Posts by vikedal
Old Sep 17, 2012, 04:16 AM
vikedal is offline
Joined Jul 2011
Originally Posted by jalves View Post
Vikedal,
Two drawings for you, please modify or remove the drawings you post earlier.
On the Rx side I do it differently, I use a separate bec and lipo to power the servos and a different lipo to power the video Rx and the arduino board (all with common ground in star mode, without ground loops).
Jalves
Do you not use the capacitor on the Tx side?
Old Sep 17, 2012, 07:54 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
No, I don't.
I remove it and change resistors values to address banding issues in the video.
In the wiki I add a edit, maybe I should change the pic as well?
jalves is offline Find More Posts by jalves
Old Sep 17, 2012, 08:41 AM
vikedal is offline
Joined Jul 2011
No, I don't.
Tnx.
Yes,change the picture Do you have some better pictures Of the Rx side.?
Got the parts today, so i'm starting the build tonight
Old Sep 17, 2012, 03:34 PM
vikedal is offline
Joined Jul 2011
Started my build, and i got two questions.
1. On the picture where i collored red, are you supposed to connect this to GND?
2. Must i modify the servo? I got a rig that move 180 to the left and 180 to the right
Old Sep 17, 2012, 04:33 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
1. yes
2. no, enough for 360 covering
Old Sep 18, 2012, 04:38 AM
vikedal is offline
Joined Jul 2011
Oploaded the code to the Rx part, but when i trued to do it on the Tx part i got a error.
See picture.
What to do?Name: ImageUploadedByTapatalk1347961100.560777.jpg
Description:
Old Sep 18, 2012, 07:39 AM
RonSpooner is offline
Find More Posts by RonSpooner
Australia, VIC, Kurunjang
Joined Jan 2011
[QUOTE=Oploaded the code to the Rx part, but when i trued to do it on the Tx part i got a error.
See picture.
What to do?[/QUOTE]
I had the same problem. jalves told me to install Arduino version 0023. Works now but I use Linux.
RonSpooner is offline Find More Posts by RonSpooner
Old Sep 18, 2012, 08:16 AM
vikedal is offline
Joined Jul 2011
Okey tnx
Old Sep 19, 2012, 03:50 PM
vikedal is offline
Joined Jul 2011
Description: Name: ImageUploadedByTapatalk1348087797.239636.jpg
Description:
Done
Old Sep 19, 2012, 04:51 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Vikedal,
Another opendiyAT, Thanks!
Old Sep 19, 2012, 04:54 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Now test it on the bench (wire connect one arduino Tx to the other arduino RX, don't forget GND) and then remove the wire and test the RF link and only then, patiently, test it in the rc field.
Old Sep 20, 2012, 02:09 AM
vikedal is offline
Joined Jul 2011
Do i just connect the audio and audiGND on the Rx and the Tx?
Old Sep 20, 2012, 04:18 AM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
Could You describe it? I don't understand... :P
I also do Your antenna tracker in my BSc Thesis (engineering work), so I ask you about use Your software, can I?
Yesterday I burnt the RX input in arduino, so I couldnt solder the wire... I pushed it and glue... I hope it'll work and it'll be not necessary to buy new one...
We use TX wire from GPS?
Grzechu is offline Find More Posts by Grzechu
Old Sep 20, 2012, 09:40 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Yes, if you are using independent power source to each arduino boards.
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
