Old Aug 25, 2012, 02:27 PM
vikedal is offline
Find More Posts by vikedal
Joined Jul 2011
Is there an "shopping list" for the parts?
And a good guide for assembly?
Looks like a good project
vikedal is offline Find More Posts by vikedal
Old Aug 25, 2012, 09:56 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Originally Posted by typicalaimster View Post
I'm having the same trouble with a Futaba Servo I hacked with the 2.2k resistor setup. After some Googling around I ran across this link and may give it a try.
Just as a follow up to the thread I posted. I went out and bought a 5K Ohm potentiometer and applied it to the Futaba Servo. It works like a champ and I now have a perfectly functioning 360 degree servo. I'd highly suggest using the potentiometer hack instead of the 2.2k resister hack.
typicalaimster is offline Find More Posts by typicalaimster
Old Aug 25, 2012, 10:12 PM
Joined Jan 2005
I follow the Wiki when I assembled mine.
http://code.google.com/p/opendiyantr...ki/Connections
I went with a Arduino Nano instead of a Mini... I'll probably scale mine back to two Nano's vs a Mini and a Uno.
TX:
1 - Arduino Board
1 - 1.8k Resistor
1 - 8.2k Resistor
1 - GPS
RX:
1 - Arduino Board
2 - 100k Resistors
1 - LED
1 - Resistor to match your LED (470 ohm on the schematic)
1 - Push Button
1 - 0.1uF Ceramic Capacitor
1 - 360 degree servo
1 - Servo
For the 360 degree servo I hacked the servo and removed the internal potentiometer and gear stop. I added a external 5k ohm potentiometer.
Hope that helps!
Old Aug 26, 2012, 10:35 AM
vikedal is offline
Joined Jul 2011
TX:
1 - Arduino Board
1 - 1.8k Resistor
1 - 8.2k Resistor
1 - GPS
RX:
1 - Arduino Board
2 - 100k Resistors
1 - LED
1 - Push Button
1 - Servo
Hope that helps!
Tnx. That helps i'll start shopping.
So if the resistance in the led is 470ohm the resistor also need to be 470ohm?
Old Aug 26, 2012, 02:00 PM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
No, you just need a resistor so that the LED doesn't burn out. 470ohm is just a suggestion, but something near that should work in most cases.
Legot is offline Find More Posts by Legot
Old Aug 26, 2012, 03:17 PM
vikedal is offline
Joined Jul 2011
Ok tnx. Is it ok to use two arduino nano. Is it same board only smaller?
Is the clone boards from hobbyking ok?
Old Aug 27, 2012, 03:08 AM
vikedal is offline
Joined Jul 2011
TX:
1 - Arduino Board
1 - 1.8k Resistor
1 - 8.2k Resistor
1 - GPS
RX:
1 - Arduino Board
2 - 100k Resistors
1 - LED
1 - Push Button
1 - Servo
Hope that helps!
How many volts does the capacitor need to be?
And do i need one on the tx side, 47nF?
Old Aug 27, 2012, 09:03 AM
Legot is offline
Legot's Avatar
Joined Nov 2009
Any arduino compatible board would be fine, even the hobbyking ones.
Capacitor voltage shouldn't matter (if it is an unlisted voltage it should be fine), but to be safe anything greater than 5v would be good.
Old Aug 27, 2012, 09:52 AM
vikedal is offline
Joined Jul 2011
What gps do you recomend using?
Is there a better wiring diagram?
I don't understand the servo wiring.
Old Aug 27, 2012, 12:24 PM
Grzechu is offline
Find More Posts by Grzechu
Grzechu's Avatar
Poland
Joined Jun 2008
I heard that ublox has a good price and parameters.
http://rctimer.com/index.php?gOo=goo...3&productname=
Servos:
Orange line - 360 PAN servo
Yellow line - regular TILT servo
black - GND
And use BEC to power servos.
typicalaimster, I also use 5kohm trimmer and it works perfectly
Grzechu is offline Find More Posts by Grzechu
Old Aug 27, 2012, 03:22 PM
vikedal is offline
Joined Jul 2011
Servos:
black - GND
Do i need to connect GND from the board with the GND from the bec?
Old Aug 27, 2012, 04:12 PM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
Yes, you need.
Is a good practice to do a common ground (star common ground, AVOID ground loops).
jalves is offline Find More Posts by jalves
Old Aug 27, 2012, 04:29 PM
vikedal is offline
Joined Jul 2011
Originally Posted by jalves View Post
Yes, you need.
So you mean that i'll connect all the GND at the same point on the arduino?
Sorry for all the questions, but my english isn't that good.
Old Aug 28, 2012, 12:29 PM
vikedal is offline
Joined Jul 2011
vikedal is offline
Joined Jul 2011
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
