Old May 12, 2012, 11:28 AM
Tubbster85 is offline
Find More Posts by Tubbster85
United States, WA, Port Orchard
Joined Oct 2011
Question
Anderson Powerpoles
Currently I am using EC3 plugs for all my lipos. I came past a video about the powerpoles, and I was quite impressed on how easy they look to assemble. I have a few questions. Can you use just any crimper because the ones that I have seen are pretty expensive for just a one use tool, if not then what crimper are you guys using out there? Also, where is the best place to buy them? Do any local stores sell them? I have also seen that Duratrax makes something similar, any experiences with that?
Tubbster85 is offline Find More Posts by Tubbster85
Old May 12, 2012, 11:54 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
You cannot use any crimper. Go to powerwerx.com
They are about 40 dollars. I got mine at a local ham radio outlet store.
You can also use a pair of pliers needle nose but it would seem to be a little difficult that way
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old May 12, 2012, 12:07 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
^^+1^^
Definitely get the crimpers. Either the Powerwerx as indicated or the West Mountain Radio version. I would not fiddle with anything less.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old May 12, 2012, 01:53 PM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I don't use PowerPoles very often, so I just use a pair of long-nose pliers to make the crimp. I just do a bit at a time, making sure both sides close up evenly.
abenn is online now Find More Posts by abenn
Old May 12, 2012, 02:11 PM
Joined Oct 2011
Thanks for the info guys. So I take it the 15,30 Amp connectors should be good for pretty much any park flyer, with 1000-2650 mah 3S batteries?
Old May 12, 2012, 02:42 PM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
The amp ratings do not relate to our hobby. The 15-amp, 30-amp and 45-amp rated connectors each take up to a different gauge wire. Basically, if the wire can take the current, the connector can.
Ken Myers is offline Find More Posts by Ken Myers
Old May 12, 2012, 08:47 PM
ncsky is online now
Find More Posts by ncsky
Maggie is in charge
ncsky's Avatar
United States, NC, Raleigh
Joined Nov 2011
I know this isn't about the crimpers, but I just got some powerpoles and had a question.
It states the 30Amp ones are for 12 gauge wire, but when it seems like a very tight fit, the stripped wire keeps "fraying" so it is hard to fit into the 30amp connector.
Is everyone else using the 45amp metal pins instead? Most of my batteries have 12g wire so I wll need to do several of them.
Also, I bought the powerworx crimpers and they make it very easy to crimp the powerpole.
ncsky is online now Find More Posts by ncsky
Old May 12, 2012, 09:02 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
What is the problem soldering them?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old May 12, 2012, 09:27 PM
ncsky is online now
Maggie is in charge
ncsky's Avatar
Joined Nov 2011
[QUOTE=TheWoodCrafter;21596784]What is the problem soldering them?[/QUOTE
My soldering skills are lacking, that is why I thought I would go with powerpoles on all my connections
Old May 12, 2012, 09:43 PM
RC Helicopter Pilot
Joined Mar 2010
Ah, that would do it.
I didn't buy the crimper and solder all mine.
Old May 12, 2012, 10:08 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
+1 for Anderson Power Poles,one of the benefits of these connectors is that they eliminate the evils of soldering and the connector separation pull is VERY light.
itsme2 is offline Find More Posts by itsme2
Old May 12, 2012, 10:50 PM
So. Cal.
Use the 30A contacts. Simply fit as many of the strands as you can within the contact, crimp, and then trim the 'stragglers'. The loss of a few strands will have zero measurable effect on the voltage drop or mechanical integrity of the joint. Don't let anyone tell you otherwise.
I personally don't care for the 45A contacts as all of the sources that I've ordered from sent the tin plated contacts rather than silver plated. Silver has lower contact resistance and performs better. All 15 and 30A contacts that I've ever seen have been silver plated.
Mark
Old May 12, 2012, 10:52 PM
So. Cal.
The crimper will RUIN you, Roger. You will never solder them again after just one crimp. It's that magical.
Will let you borrow my crimper if I ever run into you when I'm in OC.
Mark
Old May 12, 2012, 11:03 PM
RC Helicopter Pilot
Joined Mar 2010
I would love to try it Mark.
I have a crimper for standard wire ends.
That tended to flatten the piece and didn't fit the plastic holder after that.
I know, the right tool for the job, works best.
Old May 12, 2012, 11:13 PM
So. Cal.
I have the WMR version and it's crazy good. I understand the Powerwerx is basically identical.
I had used my trusty Thomas & Betts crimper on occasion before getting the WMR crimper and it was more of a hassle than it was worth.
The WMR crimper forms a perfect crimp and the contact slides into the housing and locks properly every time, like butter.
Mark
For Sale Anderson Powerpole Crimper and 30 amp connectors lower price Ed Franz Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 14, 2012 12:02 AM
For Sale 45-Amp Red/Black Anderson Powerpole Sets (20 and 40 sets) Bombay Aircraft - Electric - Power Systems (FS/W) 1 Mar 15, 2012 10:30 AM
Found Anderson Powerpoles & Crimping Tool kellymacdaddio Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 04, 2012 05:51 PM
Sold 45-Amp Red/Black Anderson Powerpole Sets (20 and 40 sets) Bombay Aircraft - Electric - Power Systems (FS/W) 3 Nov 26, 2011 01:51 PM
