http://www.rcgroups.com/forums/showp...0&postcount=21 If you look at the top of micro heli thread, you will see TomZ post settings for advance, interimdeate and beginner for different heli. |
Hong Kong
Joined Jan 2010
Hong Kong
Joined Jan 2010
Hong Kong
Joined Jan 2010
I see what you are talking about. I thought you were talking about the actual pitch but in fact you were talking about the settings. I think -15 is completely reasonable for a beginner. Instead of cutting the throttle when a crash is imminent, you should flick the throttle hold switch. This is something you will have to learn sooner or later, however many crashes it takes.
The beginner doesn't know to flick the throttle hold switch. I still don't know where mine is. I think it is the upper left switch on my Devo 7 labeled HOLD and TRN. I'm flicking switches and the blades keep spinning. I want the blades to stop spinning in an imminent crash, and the answer is buried among plenty of useless information. So the next best thing is to put positive pitch settings at 0 throttle so you don't break anything. The expert user such as yourself can always make changes. The beginner like me just wants to fly the thing.
Joined Feb 2012
Just press any button to get what you want. When Function is flashing, press enter, scroll down till you see PTCRV, press enter, you see SRVHD yes, enter again, you see Mode NORM, I press Down, you see EXP On, press Down, you see Point P-L, press Down, you see Outpu -15% (or some other value), you can change this value pressing R or L. I set the value at +20%. Then press Exit repeatedly until nothing else is flashing. I've made no other settings changes. Since I have the Genius CP, I turned on my 6 axis gyro beginner switch in my heli. From there, I fly as carefully as I can, taking it slow. Walk with your helicopter. |
Hong Kong
Joined Jan 2010
The reason why I am a worried about adjusting throttle and pitch curves right from the start is that you may make a mistake and make things worse. I would strongly recommend that you save a copy of the original settings as a different model memory. |
My Devo 7 has a copy & paste feature? |
| Thread Tools | |
| For Sale Brushless Walkera Mini CP, Devo 8s and parts | itsmillertime | Aircraft - Electric - Helis (FS/W) | 1 | May 11, 2012 12:43 PM |
| Wanted WTB Mini CP and Genius CP with Devo 6 or 8 Radio | Dark Poacher | Aircraft - Electric - Helis (FS/W) | 6 | May 11, 2012 12:37 PM |
| Discussion Finally Walkera Mini CP and Devo 8s arrived today | Udonsushi | Micro Helis | 1 | May 06, 2012 07:01 AM |
| Question Mini CP with Devo 8s Binding Error | miniCP | Micro Helis | 20 | Mar 06, 2012 01:43 AM |
