The Netherlands
Joined Nov 2009
Where I fly, it's all helicopters (it's an RC flight school actually) and everybody knows how to behave on the field. For me, the distraction is not in what is going on around me, but in the fact that on the street, people do not know what is safe and what not with regard to helicopters. On the flying field they are. So whatever happens on the flying field does not distract me the least; I have faith that the other guys know what they are doing, and if not, there is always at least one other instructor keeping an eye on things from the pits. On the street however, EVERYTHING is a distraction, because I cannot trust whoever it might be, to do the clever thing.... If you look at it that way, the flying field is MUCH safer.... Brgds, Bert |
Joined Apr 2010
At the time, we had two members who flew heli. They did 3D in that 35' area between the heli pad and runway. If they flew circuits they flew out with the planks but had to stand back behind the heli pad. And right behind the heli pilot is a long row of workbenches where at least one plank guy is almost always adjusting the mixture on a nitro. Both heli pilots would kinda warn the rest of us "I'm gonna fly my heli when Joe is done flying" so we could decide if we wanted to stand in a pilot box whlie he was doing 3D, and most of us had no problem giving him the field for 10 minutes or so. When I started learning heli it never crossed my mind to rejoin the club and try to learn there. |
Want to keep this thread going - too easy to get diverted off course and too easy for beginners to get on the wrong track. Anyone can fly - all you have to do is keep it in the air. But precision take-off and landings and maintaining a constant hover and turning the nose and doing very slow figure 8's and circles - is a far cry from zigging and zagging and bobbing and flipping like a humming bird on crack. Just because collective-pitch helicopters can fly 3D doesn't mean you have to or even want to. Flying an RC helicopter is very much like flying the kind you fly in - except RC helicopters are more difficult to fly. You may even find flying like the real thing may lead you to trying the real thing - a bit more expensive than RC helicopters, but without the RC, an experience that you will never forget and could even become more than a hobby. It takes many hours of training and practice to learn how to fly. Be patient - that's the most difficult part of learning. Have a great flight!!
captJac |
Joined Nov 2012
Hi CapsJac and others members:
My name is fher from puerto rico, im very very new to the rc helicopter, i have 3 trex 450 clon, one x525 quadcopet and 2 dh 9116, im in the hobby like 10 years but in th helis like 4 months, i read the entire post but have several question before i set one of my 450 to the scale world(also i not like much the 3d stuff, but have one heli set for that, never fly it) My numbers: 3500 kv outrunner 2200mha mechanical pitch -11 to 11 flybarless tarot zyx-s Questions: 1- What motor pinion i need to use with the flat 80% TC? or what head speed is good for 450 scale? 2-How many cyclic pitch degree is good? 6*, 5*??? 3- For the 450 what pitch curve is good? in the post i read -2/3/8, -2/4/7 and others 4-How much D/R? if any 5-How much expo for cyclic and rudder?? I know are much question, and most of the question have personal tastes, but i like to know your preferencences and test it in my heli, thanks again, and by the way nice nice post, we need most post like this, No all rc pilot like the 3D stuff |
Answer - the standard motor pinion (11T) provides adequate head speed and torque using an 80% TC. From a 2200 ma battery - you should get 6-7 minutes of flight time without overheating the motor or ESC. As a precaution (and a much needed deep breath exercise) - I take a 30 second breather after 3 minutes of concentrated flying. 2-How many cyclic pitch degree is good? 6*, 5*??? Answer - depends on your skill level - type of flying you want to do - and how steady your hand is. For training I set the swash-mix for 60% on the aileron-elevator-pitch. The higher the number the more sensitive the cyclic becomes. 3- For the 450 what pitch curve is good? in the post i read -2/3/8, -2/4/7 and others. Answer - with the resolution and measurement error of a pitch gauge - those numbers will yield about the same performance. I use a linear pitch curve with center stick (50% collective) at 3 degrees. This makes the heli light on the skids and very close to lift off. The (-2 degrees) is to get it back on the ground if there is an updraft. The 7 or 8 degrees will give you plenty of climb speed if you need it. 4-How much D/R? if any Answer - dual-rate is used when you want to switch the sensitivity of your cycle while you are flying. I seldom use it other than setting the expo value for the cyclic and rudder - which is your next question. 5-How much expo for cyclic and rudder?? Answer - definitely this is a person preference again depending on all the factors defined in question 2. I find 25% is about right for the cyclic. More than that it is too "sluggish" - less than 20% I tend to over-control. Rudder is the only exception - it feels better when it is linear (expo => off). Last comment - every heli has it's own characteristics - some good - some not so good. The only way to know what's the best setting is trial and error. Eventually (more error than trial) - you will get it dialed in where it just feels good. If doesn't seem to want to ever dial in - you may need some mechanical adjustments and tweaks - or some more time on the simulator. Most importantly - I keep saying this to myself every time I fly but sometimes I don't listen - "take it slow and easy" - especially when training something new. It's that "I can do that" impulse that gets you every time!! Have a great training! captJac |
Joined Nov 2012
What I don't get(must be getting old) is the tic-tocs. just doesn't appeal to me. But, thanks again,your the one that got me started. |
Suomi, Ruovesi
Joined Feb 2011
same here, you gave me the confidence to get airborne and figure out my mistakes.
I got the forward flight and circuts down pat now but my fine motor skills are still lacking.... I was using speed to mask poor control. My interest now is smoothness/precision and its making me realise quite how poor my fine motor skills are. when you are zipping around all over the place, thinking you can fly the speed masks your mistakes. Its not till you slow things down the "over controlling" becomes apparent. |
With a little "tweaking" these settings will work for all sizes. Have a read of post #10 and post #48. |
Joined Nov 2012
Hi people, i fly my bird for a week with this setting and is supr cool and easy to fly, thanks fos the suggentions ans opinios, also i need to know your opinion about the head speed for a 450 scale fly with 2 blades, for now is pod and boom but i have my hudge 500 fuse waiting for more practices, so i need ideas of the deasd speed with and without fuse, thanks for read
| Thread Tools | |
| Discussion DJI Props Really Do Suck -- THEY WILL COST YOU MONEY! | brianshell | Multirotor Talk | 39 | Dec 10, 2012 03:41 AM |
| Discussion Do you need a sim to fly/learn 3D | Pyrofan | 3D Flying | 16 | Apr 07, 2012 07:37 AM |
| Poll NEW!!! What do you want to see next from FLY FLY? | wcc963 | Foamy EDFs | 66 | Oct 12, 2009 07:04 AM |
| Poll What do you want to see next from FLY FLY? | wcc963 | Foamy EDFs | 83 | Aug 13, 2009 03:05 PM |
