Old May 12, 2012, 05:40 AM
Amsterdam
Joined Sep 2005
ESC beeping but motor wont work..HELP!
I bought this 18-20A ESC from hobbyking
http://www.hobbyking.com/hobbyking/s...rammable_.html
and when I hooked it up it seemed to work fine, for a moment.. but then the motor stopped responding.
now i've found the manual to program it by transmitter;
http://www.svensktmodellflyg.se/user...Sentry_ESC.pdf
..but when I start by turning down the throttle on the transmitter, and then connecting the battery to the ESC like the manual says, I just hear the three '1,2,3' beeps, and then nothing... also turning the throttle up to enter programming mode just gives me those three beeps.
It's my first ESC like this and I dont have a clue.
does anyone know whats going on?
Thanks!
Johannez is offline Find More Posts by Johannez
Old May 12, 2012, 08:31 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
What trans. are you using.?? Futaba throttle channel needs to be reversed. I'd leave the prop off till you get it programmed to avoid any dangerous surprises.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old May 12, 2012, 10:39 AM
Amsterdam
Joined Sep 2005
Im using a 2.4ghz 4 channel transmitter from skyangel, the one that came with the RTF micro MIG 15 35mm EDF from hobbyking.
it's for this project..: http://www.rcgroups.com/forums/showt...1645514&page=2
I've tried reversing te channel too. no result. But the first time it worked, it also beeped, and i also moved the throttle channel randomly (i didn't know yet about the programming by transmitter..) so i might have put it in some mode by accident.. any idea how to reset everything?
thank you it's much appreciated!!
Old May 12, 2012, 04:16 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Sorry I'm late, just got back from flying. The throttle may not be low enough to arm the ESC. Try lowering the throttle trim lever. If that doesnt work, try going further with the lower throttle end point. Not sure how to reset as I'm not familiar with that radio system. I had the same little Mig and it flew very well till I piled it in. My finger slipped and I'm sticking with that excuse.
Gord.
Old May 13, 2012, 06:34 AM
Amsterdam
Joined Sep 2005
Thank you Gord,
I've tried lowering the throttle by trim level, but still nothing but "1,2,3" beeps..
I've posted a video in the build log, maybe it can clarify something..
..never knew these ESC's were gonna be so complecated. I can understand aerodynamics, but electronics pfff...
Old May 13, 2012, 08:11 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
In my old age, I missed the part where it beeps. That means the ESC has armed the motor so the problem may be in the motor. It still spins OK by hand? in case somethings not jammed the blades. Do you have another loose motor to plug into the ESC to try.? Sometimes a bad connection on one of the motor wire will not let it run, but the motor usually jiggles back and forth in that case.
Gord.
Discussion blitzwork f-18 70mm ESC beeping (receiver wont turn on)FIX! Ziffnab Foamy EDFs 0 May 10, 2012 08:11 PM
Discussion ESC does not emit any beeps anymore, but works. tlh101 Power Systems 1 May 02, 2012 10:12 PM
Help! Turnigy Delux ESC 100A wont work! Help! planebldr Power Systems 15 Mar 01, 2012 08:19 AM
Help! Hawk Sky motor/ESC help with beeps TcCobra13 Electric Plane Talk 13 Jan 01, 2012 09:51 PM
Discussion esc wont beep help PETEREL Micro Helis 4 Mar 21, 2007 07:42 AM
