Old Nov 03, 2012, 03:26 AM
p66charly is offline
Find More Posts by p66charly
Joined Sep 2011
height dampening what is used for
hello gays
i have two question about the kk2 v1.2 firmware
the height dampening what is used for ,how it work?
about the alarm voltage ,how i will connect the battery to display the voltage,now is connected to the board by the esc,end naturally i read 0 volt.
thank you for your answere.
p66charly is offline Find More Posts by p66charly
Old Nov 03, 2012, 09:07 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by p66charly View Post
hello gays
You must solder one wire from KK2 board it is a little hole and this cable you solder to + of battery or power distribution board.
KK2 Voltage Alarm Setup (7 min 21 sec)
er9xuser is offline Find More Posts by er9xuser
Old Nov 06, 2012, 10:55 PM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
http://www.youtube.com/watch?v=_jmjiIpQWTA
Cool,
Just want to klnow what is ,max voltage it can handle? 4S, 5S or 6S?
caotri is offline Find More Posts by caotri
Old Nov 07, 2012, 02:37 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
Originally Posted by caotri View Post
Cool,
this is just + from battery. Border is powered from esc. I have 3S lipo.
Old Nov 12, 2012, 08:27 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
having erratic vertical movement. It keeps wanting to bob up and down so that I'm constantly increasing and decreasing throttle...and this is in my parking garage with no wind. I read that it could be the result of the p gain being too high so I reduced it down to 40 which worked for a while and now it's down to 35 and a little better but still almost unflyable in my parking garage and not much fun out of the garage...how do you fix this?
AdamChicago is offline Find More Posts by AdamChicago
Old Nov 12, 2012, 09:09 PM
mdjohnson is offline
Find More Posts by mdjohnson
Never left one up there yet...
mdjohnson's Avatar
Canada, BC, Campbell River
Joined Jun 2009
Turn your throttle ratchet around. You have to take the back off of the transmitter and turn the ratchet spring around so you have better control of the throttle function.
mdjohnson is offline Find More Posts by mdjohnson
Old Nov 13, 2012, 01:06 AM
SupraGo is offline
Find More Posts by SupraGo
SupraGo's Avatar
Canada, AB, Vegreville
Joined Jun 2009
Why not take the ratchet spring off altogether? Silky smooth throttle. Still stays where you put it and you don't have to fight it.
Bill
SupraGo is offline Find More Posts by SupraGo
Old Nov 13, 2012, 03:46 AM
er9xuser is offline
Slovenia, Ljubljana
Joined Sep 2011
You have too much vibrations.
Old Nov 13, 2012, 09:27 PM
Chicago, IL USA
Joined May 2010
Vibrations are a distinct possibility...thanks.
Yep this is happening in hover so not a radio issue.
Old Nov 25, 2012, 12:59 PM
Chicago, IL USA
Joined May 2010
What is the safe outdoor-flying operating temperature range for the HK KK2 LCD board? Would like to do some winter flying but read somewhere that the gyros don't operate well in lower temps but don't know what that low temp range is. Also what are the effects on the quadcopter when approaching or crossing the low temp...severe, slightly reduced, won't fly at all, erratic behavior, shakes etc?
Thanks for any help!
Old Nov 27, 2012, 11:32 AM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Flown a complete pack here last night ( 17min) ans it was -10 celcius with no problem at all.
saucisse is offline Find More Posts by saucisse
Old Nov 29, 2012, 01:24 PM
Chicago, IL USA
Joined May 2010
Awesome! Thanks for the info
Old Dec 05, 2012, 09:11 AM
moti is offline
Find More Posts by moti
israel
Joined Jun 2003
Hello, did anyone use KK2 for camera gimbal?
moti is offline Find More Posts by moti
Old Jan 06, 2013, 03:37 AM
xjrsp1 is offline
Find More Posts by xjrsp1
xjrsp1's Avatar
France, IdF, Draveil
Joined Apr 2008
Hello from FRANCE,
You speak about boutton number 1, 2, 3 or 4. The only name I knpw is from left to right: Back, Up, Down and Enter. Wich is wich?
Thank's for your help, Henry
xjrsp1 is offline Find More Posts by xjrsp1
Old Jan 07, 2013, 12:48 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by xjrsp1 View Post
Hello from FRANCE,
1-4 is the button from left to right.
LazyZero is offline Find More Posts by LazyZero
Mini-HowTo MultiWii, Clone WM+ with ITG3205 gyro and a Nunchuck clone with ADXL335 acc chip markusb2 Multirotor Talk 5 Apr 29, 2012 05:47 PM
Help! Mk gyros-Acc? smartquad Multirotor Talk 0 Mar 11, 2012 07:27 AM
Sold HobbyKing ECO8 150W 7A 8S Bal/Dis/Cyc Charger w/ acc. Wingbreaker Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 29, 2012 09:12 AM
Sold Multiwii quadCopter gyro ACC & baro ($205) madushan2008 Aircraft - Electric - Multirotor (FS/W) 12 Jan 23, 2012 08:19 PM
Discussion Acc only - no gyro drifter1949 Multirotor Talk 3 Sep 20, 2011 07:13 PM
