Old May 11, 2012, 10:29 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Gallery
Pic's the of new Maxi Swift 600 LED's !
The new Maxi Swift, 56" wing, is all most complete for night flying!
Took about 10 hours of wiring, soldering, and about 400 LED's ( 10 packs of 60)
from HK !
I have white strips all the way around the nose, in bedded in the foam, so the whole nose glows white
On top is green strips in the shape of the V
On the wing tips is Orange, and also I have strips of Ornage LED's pointed at the blades from the motor, so the blades should show Orange while spinning!
On the bottom is strips of blue LED"s for easy seperation between top & bottom
I used 2 strips of white, 4 strips of green, 2 strips of orange, and 4 strips of blue
I'm also using a HK Turnigey ON/Off Switch which goes into the gear channel to turn them on & off with the flip of a switch!
Let me know what you think! I should be ready in the next day or two, for it's madien flight!
fltekdiver is offline Find More Posts by fltekdiver
Old May 16, 2012, 09:00 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Hey, I'll give this a thumbs up! Ms.Pdiddyg40 and I are looking to start a 4-5 foot flying wing scratch build and equip it with ~6meters of LEDs from hobbypartz. Do you have any idea of the current draw of your lights? Your design is neat, it should be easy to differentiate in the dark. I've seen the rear facing-prop illuminating lights before and was planning on using them in our build as well. Should look pretty neat. Neat build!
pdiddyg40 is offline Find More Posts by pdiddyg40
Old May 17, 2012, 02:30 PM
Joined Jan 2010
Thanks ! I apprecaite it, and good luck with your build!
LED's draw around 2 amps, not much!
Old May 17, 2012, 05:02 PM
pdiddyg40's Avatar
Joined Jul 2008
Wow, that's impressive! I expected the draw to be over 4 amps...
Are you powering from a separate battery or off the balance tap of your lipo?
Old May 17, 2012, 08:23 PM
Joined Jan 2010
Each strip is 400mA, 1000mA = 1 amp, or every 2-1/2 strips
I have 400 LED's, about 7 strips, but I also have left over from each strip, so I'm figuring around 2+ amps , your correct, I edited the original post from 600, cause I know I didn't use 10 strips , each strip is 60 LED's
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I'm running 2 lipos 3S-2200mah in Parallel , to give me 4,400mah on 3S
I did fry my motor, so maybe full throttle running it, with the LED draw caused it to over heat
Old May 20, 2012, 12:06 AM
pdiddyg40's Avatar
Joined Jul 2008
Well the current draw from the LEDs should have nothing to do with extra strain on the motor. So I'm thinking that it was just too much prop or too much throttle
Old May 20, 2012, 12:28 AM
Joined Jan 2010
probabley to much throttle. It was under powered. I'm still seaching for a motor for it
Planes weights 1390 grams with the lipos, or 3.06 lbs
Discussion things to know about the maxi swift iosxphone FPV Talk 38 Oct 19, 2012 06:04 AM
Discussion Where can I find a Hydrasnake or Maxi Swift Denominator Flying Wings 3 Jun 29, 2012 05:17 PM
Wanted Zephyr or Maxi Swift shlomi4046 Aircraft - Electric - Airplanes (FS/W) 1 Dec 09, 2011 11:45 AM
Help! new maxi swift build tesco FPV Talk 9 May 17, 2011 05:40 PM
