This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Jun 21, 2012, 06:37 PM
kenair is offline
Find More Posts by kenair
ken kalynuk, winnipeg CAN
kenair's Avatar
Winnipeg, MB CANADA
Joined Feb 2000
Herb, thanks for posting the product links, the HK $39.00 gear seems to stand well on that landing in the video clip.
Could you post a couple more photos of the balsa stop block, is if forward of the nore gear, I'm a bit confused here.
thanks - ken k.
kenair is offline Find More Posts by kenair
Old Jun 22, 2012, 01:22 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... Sold the fan and motor for $20 to a guy at the field ... for an electric swamp boat.
Hi Ken,
It's just a wood block placed behind the nosegear strut, with maybe 1/2mm clearance.
It prevents the strut from bending back on takeoff and possibly cracking the nosegear plastic mechanism.
Ply would be even better than balsa I think now.
The mechanism is fairly inexpensive - and interchangeable between mains and nose - so I bought from HK a spare set, just in case. I can always use it in the Mirage.
Herb is offline Find More Posts by Herb
Old Jun 22, 2012, 02:14 PM
kenair is offline
kenair's Avatar
Winnipeg, MB CANADA
Joined Feb 2000
DOOH! Thanks, I get it now, the gear retracts forward into the well, what was I thinking... appreciate the photos. -ken
Old Jun 25, 2012, 01:34 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
You'r welcome ... I've had no more issues with the LG ... If I do find problems I'll post here.
Old Jul 09, 2012, 12:39 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I tried a new Gens Ace 4000 9S pack (3S x 3) pack in the Hawk and it almost melted my connectors and got all my 12ga wiring hot ... that CS 12-bladed fan sounds cool but is a real amp HOG.
Thinking of taking that fan out and putting in a WeMoTec Midifan or some other more efficient fan to reduce the power consumption and get longer flights ...
Old Jul 19, 2012, 02:30 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Best sounding Hawk I've heard to date!!
erh7771 is offline Find More Posts by erh7771
Old Jul 19, 2012, 02:44 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Herb, what CG did u go with?
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jul 19, 2012, 06:42 PM
pulsery2k1 is offline
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Hi Herb
thanks for the link , nice build lots of good info .
mine is 95 % complete aircraft weight 74 oz , less battery
the tissue and finish epoxy mixed 75/25 alcohol worked very well
I when with full flying tail but redesigned it , I like this over the
CMP - t-45 much nice flying model .
pulsery2k1 is offline Find More Posts by pulsery2k1
Old Jul 20, 2012, 10:36 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
That's a good weight !
Mine had major strengthening done in the wing to make it more rigid (see pics above) and improved ducting. And I have a fairly big motor, a heavier fan and a 120A HV esc.
What struts & retracts did you end up using?
My CG is where the instructions say it should be. In flight it's actually quieter now since I plugged that huge resonating esc hole in the foam behind the fan.
Old Jul 21, 2012, 09:57 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
for retracts I used 3 of these
http://www.hobbyking.com/hobbyking/s...m_1pc_54g.html
the struts are the mains from 1400mm fms P-51 and the nose
strut is from the 1400 mm fms t-28 , not scale ,but light and they
work well in the grass
I did get these , but to save weight I used the above
http://www.hobbyking.com/hobbyking/s...1_20_class.htm
I also got the scale metal legs , but opted for the weight saving .
I also reinforced the wing with a hollow carbon spar
jet is complete (except decal's ) with telemetry an extra coat of clear
and a center drop tank , aircraft empt weight is 78 oz (less battery )
in the van for Maiden tomorrow
Old Jul 22, 2012, 11:44 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Good luck with it, you should not have any problems
Old Jul 25, 2012, 03:47 PM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
finally maiden after the nose wheel was damaged on our grass runway
sunday , then a rain day and 2 very windy days.
model flew great ,fly's like a trainer
the wind to day was 12-17 with a crosswind on a very narrow and
short paved runway - got some minor damage when the model got blown
off the runway on landing
BAE Maiden Flight (4 min 26 sec)
to save weight I didn't do rudder , but I will do it now .
all up flying weight 94 Oz
Old Jul 25, 2012, 04:14 PM
Hawk Fanatic
Joined Jul 2008
That looks great! Love the paint scheme.
Old Aug 07, 2012, 12:16 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Very nice Pulser !! Yes she is a very good flier.
Old Sep 02, 2012, 09:55 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Herb you left the field too soon today!
Longs blue hawk took off , did a couple laps, suddenly half the wing ripped off and then the ensuing corkscrew into the ground from 100ft up.
Nose broken/chewed up back to the intakes. We gathered up all the pieces, Looks fixable.
Wing broke where it meets the fuselage side. He didn't have a spar in it.
Bruce
bmiller is offline Find More Posts by bmiller
Discussion KV2 Gigant tmanzaroli RC Tanks 2 Apr 04, 2012 05:34 PM
Discussion one sheet dollar tree foam board flying wing 63 nova The Builders Workshop 1 Mar 12, 2012 04:18 AM
Discussion One man foam wing cutting wire position calculator chiloschista The Builders Workshop 7 Mar 08, 2012 03:35 PM
Discussion Leaving this area, and have a big chunk of foam .... not coming with me saucerguy Foamies (Scratchbuilt) 0 Jul 21, 2010 04:22 AM
Discussion Yet another flying chunk O' foam.... power Aerial Photography 53 Feb 12, 2009 01:30 PM
