This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old May 11, 2012, 02:57 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Build Log
Fast Foam BAe Hawk 90mm EDF
Found this Hawk on sale at the local HS (Hobby People) and could not resist
It's the huge foam FlyFly (or Hobby TopGun) BAe Hawk, but the box inside says Graupner !
Maybe cheaper somewhere else, but the temptation of just throwing the box in the back of my car was just too great...
http://www.hobbypeople.net/index.php...ixed-gear.html
http://www.graupner.de/en/newsdetail...9-9a8357e559f6
http://www.flyflyhobby.com/products_...cf38ed021.html
http://www.hobbytopgun.com/PC/Red%20Arrow.htm
http://jepe.org/indek.htm
Edit : Short video May 2012:
Red Arrows FlyFly HTG BAe Hawk (90mm edf) 9S CS 12bl fan (4 min 36 sec)
Herb is offline Find More Posts by Herb
Old May 11, 2012, 03:09 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Wing details, with some lightweight carbon reinforcements.
Old May 11, 2012, 03:11 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Waiting for the electric retracts and stronger struts. Nevertheless I used some JB weld to strengthen some of the joints.
Old May 11, 2012, 03:13 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I added a rudder ...
The full flying stab is cute, but won't last long (how do I know ) in a foamie.
I use instead the much more robust (for a foamie) traditional KISS setup.
Old May 11, 2012, 03:15 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The new HET 650 motor offers the possibility of using both 36mm (WeMoTec) and 40mm diam (HET 700) EDF fans. So I went that route.
Old May 11, 2012, 03:17 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
This will be a nice testbed to finally test the (hysoled and balanced) CS 12-bl fan and see if it's any good
http://www.rcgroups.com/forums/showthread.php?t=1521751
The fan will be mounted so that it can easily be swapped.
Old May 11, 2012, 03:21 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The Hawk will also give me a chance to test this new HeliDrive controller (YGE clone) to see if it's any good. What a brick
Old May 14, 2012, 12:58 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
120A HV esc opened at both ends to allow better air cooling
Old May 14, 2012, 12:59 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Canopy glued on frame with JB weld (gives good rigidity).
Old May 14, 2012, 06:43 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Tamiya Red and Testors Acryl Cobalt Blue are a very good (almost perfect) match for the original colors
Old May 14, 2012, 06:47 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Finally on her legs to test CG with various components
Old May 15, 2012, 12:38 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
What I like about the Hawk is that there's a ton of place for batteries up front
Old May 15, 2012, 12:41 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The speed controller (120A HV) is installed above the duct so that it gets plenty of air ... also the battery cables are kept short this way.
And finally, it does not throw the CG off by much as does sit right over it.
I have also made some improvements on the ducting by shaping some styrofoam blocks.
Some finishing and spackling is still left to do, then I will glue the shaped blocks securely in place.
The motor wires will eventually get wrapped up completely in aluminum foil.
Old May 15, 2012, 03:01 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Landing gear and struts arrived (from www.hobbywhere.com) ... the new mechanisms are 4mm diam, the new struts are solid but a bit heavy.
Everything works fine, but the extension cords had the wrong polarity plugs crimped on
Old May 16, 2012, 07:07 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The new wheels are really heavy, the new struts are quite a bit longer which causes some issues.
I dremeled out part of the wing to get the new struts to fit, but I think I will go bakc to shorter struts due to the nosgear probloem (see below).
Discussion KV2 Gigant tmanzaroli RC Tanks 2 Apr 04, 2012 05:34 PM
Discussion one sheet dollar tree foam board flying wing 63 nova The Builders Workshop 1 Mar 12, 2012 04:18 AM
Discussion One man foam wing cutting wire position calculator chiloschista The Builders Workshop 7 Mar 08, 2012 03:35 PM
Discussion Leaving this area, and have a big chunk of foam .... not coming with me saucerguy Foamies (Scratchbuilt) 0 Jul 21, 2010 04:22 AM
Discussion Yet another flying chunk O' foam.... power Aerial Photography 53 Feb 12, 2009 01:30 PM
