Old Jun 01, 2012, 06:20 AM
Jockadopolus is online now
Find More Posts by Jockadopolus
Jockadopolus's Avatar
Scotland
Joined Jan 2010
Originally Posted by britinoz View Post
Joe
Looks like you have modified that head to roll only...............
Yes Chris the same as the wooden head I made for the PT25 head I'm using elevator for pitch and the head for roll I will use the same configuration when I build the Comper C25
Had a flight this morning with the Mk2 nearly a disaster the rudder servo decided to misbehave but I got it down in one piece its on the bench for replacement and should be flyable tomorrow weather permitting and video ASAP
Joe
Jockadopolus is online now Find More Posts by Jockadopolus
Old Jun 01, 2012, 09:42 AM
F.FANIS is offline
Find More Posts by F.FANIS
Greece, Peloponnisos Dytiki Ellada ke Ionio, Thouria
Joined Oct 2010
HI Joe ,you have done very nice job,congratulations. Please dont leave your plans of making(from heli parts) a VTO gyro,I have the same idea and I want a mate to share our thoughts and constractions. regarts FANIS.
F.FANIS is offline Find More Posts by F.FANIS
Old Jun 01, 2012, 02:16 PM
Scotland
Joined Jan 2010
Hi Fanis
The heli version was only to give me pre rotator and a fly bar for control the same as Jodinis Schluter Whopper and not for jump take off
Many people have and still are experimenting with jump take off but no results so far but its only a matter of time before someone is successful
Joe
Old Jun 04, 2012, 03:46 PM
Scotland
Joined Jan 2010
Had some fun today flew the depron Little Wings no problems the only damage was done to the balsa Little Wing on the ground the blades spun up and tilted back and hit the fin
The Wot 4E flew well after the rudder servo was replaced video to follow
Joe
Old Jun 04, 2012, 04:04 PM
Scotland
Joined Jan 2010
Video
testWot4e flight 1.wmv (2 min 33 sec)
Old Jun 04, 2012, 11:23 PM
britinoz is offline
Find More Posts by britinoz
britinoz's Avatar
Elizabeth South Australia 5113
Joined Nov 2005
G'day Joe
I was telling Rich a couple of days ago that I had tried to order some HK heads, but found they were O.O.S. I think that I have a pretty good idea who purchased them all.
I am guessing that the wot4 conversion must just about be at the top limits for the HK head and you have it flying great mate.
Chris...........
britinoz is offline Find More Posts by britinoz
Old Jun 05, 2012, 02:42 AM
Scotland
Joined Jan 2010
Chris I wanted to order some for the hotel but as you say O O S on back order waiting for an email to say when back in stock there must be a lot of gyros out there using this head I only have five
The model is lighter than the HK C30 and I will post some angles dangles and weight after a few more tests
Joe
Another video from a clubmate
Joe's Autogyro 4th June 2012.MOV (2 min 24 sec)
Old Jun 05, 2012, 02:51 PM
Scotland
Joined Jan 2010
Added some balsa to the frame just need to cover with film I would like to fit larger wheel and spats next
Any suggestions how to hide the alloy mast?
Old Jun 05, 2012, 03:31 PM
SafeLandings is offline
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
Joe,
Cracking job, I remember talking to Bill when he came over to my house a few months ago about converting the standard WOT 4 (well he was trying to convince me it would be a good idea). I think it looks great and I am sure it is very light?
How about shrouding your mast in that foam like you sent me? I thin coat of balsa loc and I bet it would cover with some film if it was set on a lower heat setting? Or a depron sandwich?
Regards
Rich
SafeLandings is offline Find More Posts by SafeLandings
Old Jun 05, 2012, 04:57 PM
Ricardo1500 is online now
Find More Posts by Ricardo1500
Ricardo1500's Avatar
Wolverhampton, England
Joined Jun 2010
Hi Joe
That looks real sleek!!
Don't know about adding anything to the mast.....I was thinking it looks fine as a single thin post on such a streamlined shaped fuselage.
Seems to fly really well in a good breeze.....should be ideal for Winterton!!
Cheers
Rich
Ricardo1500 is online now Find More Posts by Ricardo1500
Old Jun 05, 2012, 08:44 PM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Joe
That does finish of the model a lot better,and I am interested in your angles as I myself have a biplane that I have been flying as IC & E for over 20 years that mite just look good as an autogyro with a lower wing.
Chris..........
Old Jun 07, 2012, 05:54 AM
Scotland
Joined Jan 2010
Chris
Still to cover balsa fitted spats
AUW just under 3 lbs
Motor 6deg down thrust
Head 8deg back
Hang angle 15deg
Hope this helps with your bipe conversion
Joe
Old Jun 08, 2012, 05:06 AM
britinoz is offline
britinoz's Avatar
Joined Nov 2005
Joe
Thanks for that........that is pretty much the numbers that I would have expected,although am still pleasantly surprised the weight that the HK head will handle .
Chris...........
Old Jun 08, 2012, 07:53 AM
gyronuts is online now
Find More Posts by gyronuts
gyronuts's Avatar
United Kingdom, Gamlingay
Joined Jul 2002
Hi joe,
May have missed it but what is the rotors pan of the wot 4.
. Bill
gyronuts is online now Find More Posts by gyronuts
Old Jun 08, 2012, 08:38 AM
Scotland
Joined Jan 2010
Bill I used the std HK C30 blades and head 36ins
The one in corfu had the PT25 head and blades 38ins
The PT25 setup flew slower I will try different blades on the HK head later
I would like to try a two blade version also
Joe
