Old May 11, 2012, 09:22 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Nice work!
wyowindworks is offline Find More Posts by wyowindworks
Old May 11, 2012, 10:17 AM
sarmoby is offline
Find More Posts by sarmoby
Composites guy
North OC, Ca.
Joined Jun 2005
since you have the mold- make yourself a fleet of them.
Looks like a lot of fun.
Scott
sarmoby is offline Find More Posts by sarmoby
Old May 12, 2012, 09:31 PM
Aerogance is offline
Find More Posts by Aerogance
U down with EPP? Ya U know me!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
I like the "old school" plywood sheeted wings. I am starting to build with old materials and techniques again too. Nice job on the mould and part!
Aerogance is offline Find More Posts by Aerogance
Old May 17, 2012, 04:01 PM
manolitogafota is offline
Find More Posts by manolitogafota
Joined Jun 2009
The plane weighs 800 grs.
Is it too big this orutrunner?
Specification
Rotational Speed :850 (kv) RPM/V
Continuous Current :50A
Max. Current :60A
Input Voltage :11.1 - 25.9V
Max. Efficiency :98%
No Load Current :2.6A
Internal Resistance : 40m(Omega)
Motor Weight (Motor only) : 198g
Motor Dimensions (Diameter x Length) : 42* 40mm
Propeller Dimensions : 13" x 6"/ 13" x 8"/ 14" x 8"
Input Battery Types : NiCd/ Nimh/ Li-po Battery
Recommend Model : Airplane
manolitogafota is offline Find More Posts by manolitogafota
Old May 21, 2012, 06:53 AM
razortoe is offline
Find More Posts by razortoe
Keep it Simple Stupid
razortoe's Avatar
United States, NC, Raleigh
Joined Jul 2011
I think that's a fine motor for this plane, assuming you go with a 60A ESC, I'd run a 6-cell LiPO for sure (it'll be a rocket!) - sized (mAh) based on weight and desired flight-time. For prop selection, I'd get all three sizes. Once you know your AUW, you can bench test the motor + different props easily to measure thust and draw. Otherwise, there's lots of motor+prop+AUW info. on other forums.
razortoe is offline Find More Posts by razortoe
Old May 22, 2012, 01:03 PM
Joined Jun 2009
Thank you very much. I'll try with this engine.
regards
Old Jun 06, 2012, 11:02 PM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
I have used that size motor for many 3d planes in the 1200g range. 3S lipo and apc 14x7E prop or 4S and 12x6E prop.
Eagleburger is offline Find More Posts by Eagleburger
New Product Brand New Nitroplanes.com Projet Sky Trainer Scale Plane Kit Nitro_Nancy Product Announcements 0 Apr 04, 2012 06:13 PM
Discussion Precision Aerobatics 3D Racer Bandit F3P Connor 3D Flying 2 Mar 26, 2012 11:22 AM
Wanted Aerobatic/3D plane Florida dylang Aircraft - Fuel - Airplanes (FS/W) 2 Mar 21, 2012 04:05 PM
Question Looking for a TOUGH aerobatic/3D airframe for electric conversion Lost Oracle Giant Scale Airplanes 2 Mar 06, 2012 06:09 PM
EBAY 3D Extra 300S EPP FOAM Aerobat AIRPLANE-Dave's Electric Foamie Aerobat baro99 Aircraft - Electric - Airplanes (FS/W) 0 Oct 10, 2003 12:56 PM
