Old May 10, 2012, 10:08 PM
superdr34 is online now
Find More Posts by superdr34
superdr34's Avatar
United States, MN, Big Lake
Joined May 2012
Any way to view what a Sony Nex-5 is seeing before the picture?
I'm new to this side of rc. Wondering if there is any way to view what is in the view finder of the camera before you take a picture? Do guys just put the camera in a mode to take a picture every five seconds? Does everyone use a blip switch? Is there a video camera out there you can use for your fpv and take good quality pictures at the same time? Been doing quite a bit of reading on the fpv-lab forum and haven't come across the answer yet. Found out this forum seems to have alot more info. I haven't got to all of it yet.
Thanks Much
superdr34 is online now Find More Posts by superdr34
Old May 11, 2012, 05:49 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Hi superdr, welcome to the forum
There're already quite a few threads on this topic, including one slightly further down on the first page:
http://www.rcgroups.com/forums/showthread.php?t=1606521
If you want to see exactly what's on the screen of the camera you have two options – either buy a relatively inexpensive, but rather large HDMI to Composite converter, or point a small FPV camera at the screen itself. As far as I know most people have gone for the HDMI converter route, including myself. There are some photos of the most common converter in this thread:
http://www.aplanding.com/forums/showthread.php?t=5669
The bare board weighs around 60g and it certainly does what it says it will on the tin ... then you just need an HDMI cable:
http://www.hypershop.com/HyperThin-W...able-s/192.htm
http://www.cinegearpro.com/hdmi-cabl...dmi-cable.html
are just two examples. Finally you need a composite video link such as any of those shown here:
http://www.firstpersonview.co.uk/transmitters/5.8ghz
http://www.firstpersonview.co.uk/transmitters-receivers
Hope that helps get you started
David
Hogster is offline Find More Posts by Hogster
Old May 12, 2012, 05:54 PM
superdr34's Avatar
Joined May 2012
Thanks for the info. I'll look into the information you gave me.
Old Nov 01, 2012, 07:42 AM
WonderKing is offline
Find More Posts by WonderKing
WonderKing's Avatar
Indonesia, Jakarta
Joined Sep 2012
have anyone tried this one http://www.ebay.com/itm/Mini-HDMI-to...item416c888238
WonderKing is offline Find More Posts by WonderKing
Old Nov 01, 2012, 12:48 PM
GaryAW139 is offline
Find More Posts by GaryAW139
United Kingdom, England, Havant
Joined Aug 2012
try this i have one, works great ! your camera needs to have a live feed out .ebay iteam no :150937167299
GaryAW139 is offline Find More Posts by GaryAW139
Old Jan 22, 2013, 03:53 AM
pmijoiu is offline
Find More Posts by pmijoiu
Joined Sep 2012
Hi Guys,
We made a video in which we show how to install a Sony Nex 5R and a HDMI converter on a Gimbal. Hope it helps.
Sony Nex 5N / 5R on AV130 (HDMI converter) - Part I (13 min 15 sec)
Paul
pmijoiu is offline Find More Posts by pmijoiu
Old Apr 29, 2013, 12:03 AM
edwardjohn is offline
Find More Posts by edwardjohn
edwardjohn's Avatar
Joined Mar 2006
Originally Posted by pmijoiu View Post
Hi Guys,
http://www.youtube.com/watch?v=Sk2Nk-xlrSg
Paul
Hey there,
Did you successfully made the 5R to output video thru the hdmi2av?
Mine not working though. As explained here.
http://www.multirotorforums.com/show...463#post105463
But my sis EOS M works thru the same converter
edwardjohn is offline Find More Posts by edwardjohn
Old Apr 29, 2013, 02:21 AM
Krylon is offline
Find More Posts by Krylon
What goes up...
Krylon's Avatar
England
Joined Apr 2010
I had that same converter working fine on my 5R until I let the magic smoke out. New one on the way. But I can confirm it works for the 5R.
Krylon is offline Find More Posts by Krylon
Old Apr 29, 2013, 03:29 AM
Krylon is offline
What goes up...
Krylon's Avatar
England
Joined Apr 2010
Just read your posts on the other site.
To clarify the NEX-5 needs the converter to be powered with 5 volts via its USB port.
To achieve this I ran a 5v uBEC from a free RX port to the converter and attached it with a Jr servo plug to USB adapter I made but cutting up a mini-b USB lead.
Sold NEW Sony NEX-5 $325 DEL Z06 Tony Non R/C Items (FS/W) 0 Dec 05, 2011 11:58 PM
Sold NEW Sony NEX-5 $325 DEL Z06 Tony FPV Equipment (FS/W) 0 Dec 05, 2011 11:54 PM
Sold Sony NEX-5 w/18-55mm lense **CHEAP** Z06 Tony Aircraft - Electric - Multirotor (FS/W) 1 Nov 13, 2011 05:49 AM
Sold Sony NEX-5 w/18-55mm lense **CHEAP** Z06 Tony FPV Equipment (FS/W) 1 Nov 12, 2011 06:29 PM
Alert Sony NEX-5 w/18-55mm Lense Z06 Tony Aerial Photography 0 Nov 12, 2011 06:27 PM
