Old May 10, 2012, 07:29 PM
Duke2448 is offline
Find More Posts by Duke2448
United States, OH, Painesville
Joined Dec 2011
Question
Retracts toe in how much is to much
This is first plane with retracts all others fixed landing gear, P 47 Thunderbolt
retracts seem to be toed in more than what I 'm used to seeing or is this normal
doesn't look they can be adjusted, but maybe they could be modified .
Would greatly appreciate and help or guidence.
Thanks Joe,
Duke2448 is offline Find More Posts by Duke2448
Old May 10, 2012, 07:42 PM
Edge767 is online now
Find More Posts by Edge767
AMA 52726
Edge767's Avatar
United States, TX, Spring
Joined Jun 2005
They can be adjusted by loosening the screw where the wire connects to the mechanism and then rotating the wire slightly to remove the extreme toe-in.
Edge767 is online now Find More Posts by Edge767
Old May 11, 2012, 06:20 AM
Duke2448 is offline
Joined Dec 2011
retracts
Thanks for response,took retracts out completely and found screws, looks like they have ground flat spots on wire where screws hold in position,looks like a little filing
will have to be done to help with alignment.
Thanks again Joe,
Old May 17, 2012, 11:08 AM
faststick is offline
Find More Posts by faststick
faststick's Avatar
BOTHELL,WA. NORTHEAST OF SEATTLE
Joined Jun 2005
Is it the durafly? If so when you change the toe, they won't retract properly, been there, done that! I put them back to original and doesn't seem to hurt anything, but looks goofy on the ground.
George
faststick is offline Find More Posts by faststick
Discussion Curving relative wind, how much slip is ideal in turns, yaw strings videos aeronaut999 Modeling Science 7 Jun 19, 2012 10:58 PM
Discussion How much noise in Video Link is tolerable? fpvbird FPV Talk 6 Apr 13, 2012 04:36 PM
Discussion How does Winglet toe-angle affect Yaw stability alexlb Flying Wings 4 Apr 09, 2012 06:57 AM
Discussion How much is too much of a difference in charging parallel lipos? TheNiceGuy Batteries and Chargers 1 Dec 30, 2011 01:59 PM
