Old May 10, 2012, 02:22 PM
KMKAZE is offline
Find More Posts by KMKAZE
Question gravity.
KMKAZE's Avatar
Kane County, Il
Joined Sep 2000
Nav light system causing massive interference...
Is there anything I can do? With the transmitter (72mhz Optic6) RIGHT next to the plane, the Turnigy LED nav-light system still makes the servos go all batty.
Would one of them newfangled cheap Turnigy 2.4ghz systems eliminate this problem? Might be the excuse I need to upgrade...
KMKAZE is offline Find More Posts by KMKAZE
Old May 10, 2012, 02:40 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
They are not exactly newfangled, but 2.4 radios are very much more resistant to electrical noise than FM systems. Go for it!
Daedalus66 is online now Find More Posts by Daedalus66
Old May 10, 2012, 07:14 PM
KMKAZE is offline
Question gravity.
KMKAZE's Avatar
Kane County, Il
Joined Sep 2000
I wonder if a ferrite core would fix this?
Old May 10, 2012, 09:32 PM
rms59 is offline
Find More Posts by rms59
Electric Flyer
Connecticut, USA
Joined Oct 2003
I haven't seen the nav system your talking about but I do have the one from LiGlow systems that has both navs and strobes and it operates fine on my hitec 72mhz system.
If your nav system has led strobes running off a PIC programmed chip you need to make sure the strobe wiring is twisted with at least 10 turns per inch. This is more important in the power leads coming from the nav board but I twist them all.
I also connect the the nav board power lead directly to the ESC hot wires instead of the battery.
Hope that helps
Dick
rms59 is offline Find More Posts by rms59
Alert Nav lights at poundland uk ballores Night Flying 0 Feb 23, 2012 12:32 PM
New Product Scale RC Nav Light System oxothnk Scale Kit/Scratch Built 0 Aug 21, 2010 02:30 PM
FS: Curtek Nav light system Used 3 times!! av8rOC Aircraft - Electric - Airplanes (FS/W) 4 Apr 19, 2004 10:10 AM
FS: Aiptek AP camera, Lipo Charger and Curtek Nav-Light System Trikster Aircraft - Electric - Airplanes (FS/W) 16 Apr 13, 2004 12:05 AM
FS: Curtek Nav Light System with Extras geng Aircraft - Electric - Airplanes (FS/W) 2 Jan 16, 2004 01:42 PM
