Old Jun 14, 2012, 11:10 AM
Blizards316 is offline
Find More Posts by Blizards316
Glow? What is that?
South Africa, GP, Pretoria
Joined Apr 2009
@ticketec:
There was absolutely NO damage to the fuze or the plastic pivot points.
Once you glass the stabs, be sure to balance the stabs... And use a decent size (possibly go digital) servo with proper mechanical advantage.
Good luck with ur build!!
Blizards316 is offline Find More Posts by Blizards316
Old Jun 16, 2012, 07:19 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Thanks mate,
That's good to hear that the fuse mount didn't move.
I have Hs-81 sized Metal geared servos coming for the stabs and the ailerons, with nreay 3kg of torque so that should keep it all in check.
I saw that the CS 90mm fan has come back into stock so i've ordered that and another 3 nanotech 4s 4000mah li-pos. I bought a pair of them recently for my Flyfly sabre and had been breaking them in with my FMS Fw-190 and my mates FMS T-28 and one of the packs has had a cell go bad so I will now have 2 sets of packs to be used on both models.
Only need the motor and the landing gear legs to have everything in hand and ready to go! anyone have any good options for the oleo legs? I really don't like the sloppy standard legs that come with the kit.
dave
ticketec is offline Find More Posts by ticketec
Old Jun 16, 2012, 11:01 AM
Glow? What is that?
Joined Apr 2009
@ticketec:
I upgraded the oleo legs from FlyFly by grinding out the brass eyelets and replacing them with propper 3mm bolts and nuts. Also the tires were replaced with 2.25" jet wheels from HK. Will take pics for u.
I just kept the FLYFLY nosewheel, only because i couldnt source a replacement yet. ( due to the width of the fork)
Basically replace all the joints with proper bolts.
They are great now.
And didnt cost me an arm and a leg.
Old Jul 03, 2012, 05:42 AM
Glow? What is that?
Joined Apr 2009
Post Crash Mods
Herewith some pics to explain my mods to the elevator and to the Undercart bogyes.
She was maidened yesterday again..
Flew like an angel.
Stab incidence is slightly out.
But that is something I can live with..
Will just run a Mix to adjust elev to throt.
Hope the pics help.
Old Jul 06, 2012, 06:03 AM
Biggles51 is offline
Find More Posts by Biggles51
Gold Coast Australia
Joined Sep 2010
About to maiden mine.
Bliz, was the COG as per the instructions Ok
and the line of your stab... was it level with the wing .
Cheers
Tony
Biggles51 is offline Find More Posts by Biggles51
Old Jul 06, 2012, 08:05 AM
Glow? What is that?
Joined Apr 2009
Cg as per instructions. Its spot on. I moved mine about 5mm aft but fly it as per instructions 1st.
You can actually see the CG black pen marks on the bottom of the wing. Just ahead of the Main bogeys.
As for stabs... I TRIED to get it to ZERO degrees. But they are slightly to positive. (I think)
Dont have enough flights on her to say exactly yet.
She pitched slightly nose up at WOT...
But that can be mixed out.
Most importantly: The stabs stayed on the aerie for the whole flight...����
Good luck with the maiden!!!��
Last edited by Blizards316; Jul 06, 2012 at 08:07 AM. Reason: Saw the cg in the pics. Wanted to mention that.
Old Jul 07, 2012, 01:08 AM
Joined Sep 2010
Thanks.
Yes my only real concern is the stab mounting.
I reinforced the mounting of the L shaped wire into them. Couldnt face up to redoing
everything as per the previous posts as my servos were already in the "standard"
position.
With only a 6 cell set up I will take it nice and easy.
Cheers
Tony
Old Jul 08, 2012, 08:34 PM
Joined Sep 2010
Viking Funeral
Not good news....
Got her off nice and smoothly, then needed loads of elevator up trim.
(left the stabs neutral for first flight). Flying nicely when a mate called out saying he had spotted a puff of smoke. Couldnt see anything and did a couple of lower passes to check on stab flutter. Big mistake. Lined her up for landing and then loads of smoke.... put her down quickly and heavily but all to late.
By the time we got there well and truly ablaze in the mid section. Total loss and
only got the battery and receiver out.
Crash flight investigation has intial cause as wiring fire from speedy
back to the motor. Speedy was Deluxe 80amp.
Will reflect and decide if I will get another kit.
My 262 is due in this week so it could be a while.
Real bummer, shite of a build these Flyfly kits but they do fly nice.
Regards
Tony
Old Jul 09, 2012, 03:41 AM
ticketec is offline
Brisbane, Australia
Arhh Tony,
Sorry to hear that mate!
My flyfly sabre was plenty of work to finish and has given some grief since day dot! mostly Landing gear related, and if didn't look soo good i the sky, I would have parked it by now as well. Hopefully you don't loose your drive to get another one of these going.
My ChangeSun 90mm fan arrived today together with the 4s 4000mah Nano-tech Li-po's so all I really need to complete is the motor, but that's no reason not to start on this one now!
dave
Old Jul 09, 2012, 04:08 AM
Joined Sep 2010
Such is life Dave.
Is 4 cells going to be enough ? I was on 6 with the same motor.
Allthough it was only 3 minutes of flying I wouldnt say it was overpowered at all.
Tony
Old Jul 09, 2012, 04:36 AM
ticketec is offline
Brisbane, Australia
Originally Posted by Biggles51 View Post
Such is life Dave.
Tony
4s???? more like x2
Running the sabre on 8s with an ARC 3675-1 and wemo rotor, so I wanted to keep the packs for the two models the same.
dave
Old Jul 22, 2012, 09:22 AM
NickM91 is offline
Find More Posts by NickM91
NickM91's Avatar
Australia, WA, Perth
Joined Jan 2009
G'day,
Sorry to hear about the loss.
I can say I have absolutely nothing to report with my build. I have a couple of photos showing where I left it a few months ago which I never got around to putting up.
Cheers
Nick
NickM91 is offline Find More Posts by NickM91
Old Jul 25, 2012, 03:59 PM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Finished and maiden
decided to just build it with normal nose , the model is covered with
tissue and 20 min finish epoxy mixed with aclohol , this gave great
results with out weight gain total ready to fly weight 94 oz
model flew great ,even with 12-17 mph wind .
full fly stab no problem
BAE Maiden Flight (4 min 26 sec)
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Jul 27, 2012, 10:25 AM
Glow? What is that?
Joined Apr 2009
Congrats pulsery!!!
I like the gear doors too!
What is she carrying under the belly?
May I ask how u fixed the stabs? I cant see any servos in the pics. Maybe you can just clarify for the forum...
Regards
Old Jul 27, 2012, 11:49 AM
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Blizards316
for the flying stab and flaps the linkage is internal
the flying stab is custom machined from 6mm lite aluminum
the pod under is the telemetry airspeed ,amps ect
Build Log My Fly Fly BAe Hawk build and scale mod thread. Matt Halton Foamy EDFs 297 Nov 24, 2015 03:48 PM
Build Log SAPAC T-45 Hawk 100mm Build Log sbritton Electric Ducted Fan Jet Talk 31 Aug 23, 2015 03:36 PM
Discussion Build Log: Monogram "build'n fly" DHC-2 Beaver lw_hughes Scratchbuilt Indoor and Micro Models 9 Nov 17, 2009 08:01 PM
Discussion is there a build thread somewhere on the fly fly bae hawk ? aviador Foamy EDFs 1 Feb 04, 2008 09:42 PM
Help! WattAge Camel Build / Fly / Crash / Rebuild Log Newtron North Coast Electric Flyers 10 Apr 18, 2006 11:38 PM
