Old May 10, 2012, 02:32 AM
bob_nj is offline
Find More Posts by bob_nj
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Question
How to test a motor or speed controller
Either the ESC or the motor on one of my foamies took a dump.
I'll do a search, but in the mean time thought I would ask;
What's the best way to test either the speed controller or the motor to see which
is the culprit?
Bob
bob_nj is offline Find More Posts by bob_nj
Old May 10, 2012, 02:50 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Substitute. Try the ESC with another motor and/or the motor with another ESC.
You should also check them for physical indications of failure. The motor could have a broken wire, or one of the connectors might be loose or poorly soldered (which usually causes the motor to jerk back and forth but not start up). Check the ESC for the same things, and also for signs of burning. If the ESC smells burnt, then it probably is!
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 10, 2012, 02:52 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
I should have mentioned that I don't have extra equipment to substitute.
Thanks for the reply
Old May 10, 2012, 07:18 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
What happens when you turn the TX on and then connect the battery to the ESC? Are there any sounds at all?
Don't open the throttle unless you get the normal arming tone, a bad motor can kill a ESC. A bad ESC is less likely to kill a motor though.
Everyone needs a multimeter, they are as cheap as $3 on sale at Harbor Freight. Do you have one?
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 10, 2012, 07:23 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
There is no noise from the motor at power up.
I have a boatload of meters and test equipment.
Just don't know exactly what to test??
Bob
Old May 10, 2012, 10:27 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Bob
If you set a multimeter to RX1 and check the three motor leads in pairs (1-2, 1-3, 2-3) you should see a steady, very low resistance there. It will be almost the same as you see with the probes shorted. If any of the reading dance and change or are considerably higher there is a short between the windings.
And if you find a bare spot on the stator for one probe, you can check all three motor leads for shorts to the stator. Either of those kinds of faults can keep the ESC from arming. And if you open the throttle with those kinds of faults you can kill off an ESC. I like to do those tests with the biggest ESC I have around and only open the throttle one click and momentarily to see if it will run.
Beyond those checks, I would try another ESC which I now know you don't have.
If you remove the throttle/BEC lead from the receiver you can check the red and black leads on that to see if the BEC voltage (5-6V) is present. That will give you an idea as to if the BEC power supply is dead and, if it is, there is a good chance that rest of the ESC is totally dead too.
More trouble shooting procedures here too:
"Dry Testing" brushless motors - http://www.wattflyer.com/forums/showthread.php?t=35216
I have never tested the motor leads on an known good ESC and motor with a meter to see what the voltage indications on the motor leads would be. But I'm pretty sure that if the ESC is not arming there would not be anything on those leads.
Jack
Old May 10, 2012, 10:32 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
Thanks for the info!
I'm going to try to make it to a local shop today after work and pick up some stuff to figure this out.
Take care
Bob
Old May 10, 2012, 10:55 AM
Jack
USA, ME, Ellsworth
Joined May 2008
The ESC not making any sounds at all kinds of makes me think that the problem is there initially. All of my ESCs do something when you plug them in even if they don't carry on through to the arming stage.
And the noises come from the motor, not the ESC. They sort of "buzz" the windings against each other. So if there is no motor connected and no LED indicators on the ESC, you might not get any indications at all.
Jack
Old May 10, 2012, 10:58 AM
bob_nj is offline
bob_nj's Avatar
Vineland, N.J.
Joined Sep 2003
The plane and accessories are on the bench.
I'll try to get a good assessment of what's going on and let you know.
Thanks a lot!
Bob
Discussion 2S Lipo Receiver battery pack without BEC or Speed Controller? Moparbob Batteries and Chargers 6 Mar 18, 2012 11:58 AM
Sold Eflite 450 BL Motor, Eflite Speed Controls, Atlas BL Motor, ESC, Rimfire 300 - $50 tonebone Aircraft - Electric - Power Systems (FS/W) 5 Jan 24, 2012 02:19 PM
Question To extend speed control wires ? motor or battery side ? Dennis Everett Power Systems 5 Oct 17, 2011 05:05 PM
Discussion How to determine the correct speed control for twin electric motor Wbeniquez Power Systems 9 Jan 28, 2010 02:57 PM
Question Motor, or speed control,or receiver issues DESIGN ENGNR Ornithopters 19 Mar 28, 2006 01:12 PM
