Old May 09, 2012, 09:15 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Question
Why Pine Wood on RCExplorer 2.5 Tricopter?
Why do most people use pine wood and not basswood on the RCExplorer 2.5 tricopter? Is it lighter, stronger or cheaper then basswood?
Dave8888 is offline Find More Posts by Dave8888
Old May 09, 2012, 09:36 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
http://www.ehow.com/info_12133491_ba...e-vs-pine.html this says pine is stronger, but more expensive.
here: http://www.engineeringtoolbox.com/wo...sity-d_40.html both pine and bass density changes a lot depending on type(white etc)
sirbow2 is offline Find More Posts by sirbow2
Old May 09, 2012, 09:43 PM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
For most of us, it comes down to availability as much as price. For me, the hardware store on the way home has 12mm (1/2") 900mm + 1200mm sticks for very little $$$
If you drop it from a great height... even carbon square rod smashes
Pete
Efliernz is offline Find More Posts by Efliernz
Old May 09, 2012, 11:03 PM
bladeaudio is offline
Find More Posts by bladeaudio
Joined Sep 2010
Made mine out of basswood, works great.
bladeaudio is offline Find More Posts by bladeaudio
Old May 09, 2012, 11:23 PM
sbole is offline
Find More Posts by sbole
United States, OK, Tulsa
Joined Nov 2005
i have made mine out of basswood, from the local hobbylobby, i had bought some 10mm x10mm pine from http://www.magnumwood.com/ but it was all warped
sbole is offline Find More Posts by sbole
Old May 14, 2012, 10:36 PM
fo4u is offline
Find More Posts by fo4u
Sylva, NC
Joined Dec 2009
All that Lowe's carries locally is yellow-poplar in 3/8, 1/2, and 5/8. Cheap and the 1/2 seems the best trade-off for strength/weight for the V2.5 build.
fo4u is offline Find More Posts by fo4u
Old May 14, 2012, 10:53 PM
oesti is offline
Find More Posts by oesti
Joined Jun 2011
Heavy lift Hexa frame built from 3/4" pine wood. Used plywood for the plates instead of PCB boards. All inspired by dadde
Description:
Description:
Description:
Previously built a Quad and a Tri with the same design/materials:
Description:
Description:
oesti is offline Find More Posts by oesti
Build Log RCExplorer Tricopter v2.5 FPV platform build sia100 FPV Aircraft 2212 Mar 07, 2015 06:30 AM
Build Log RCexplorer's tricopter v2.5 carbon build jwalker590 Multirotor Talk 6 Apr 03, 2012 07:39 PM
Help! Help with tricopter from rcexplorer.se JoseOlcese Multirotor Talk 4 Feb 19, 2012 06:46 AM
Discussion Alternative props for Rcexplorers Tricopter 2.5 xardinen Multirotor Talk 0 Dec 18, 2011 11:25 AM
Discussion Which copter body on an rcexplorer.se tricopter? David Jenkins Multirotor Talk 2 Nov 26, 2011 02:53 PM
