2.4g is good for surface and air.
A good inexpensive radio is this one. FlySky FS-TH9X 2.4G 9CH System: http://www.planeinsanerc.com/index.php?PageID=15. You can get it cheaper elswhere however Ryan is a great guy to deal with if you have any problems and you will get it in a week. This radio in it's stock configuration will serve you well for some time however if you install one of the custom firmware options it becomes a power house that nothing remotely can come close to for the cost. Recievers are cheap and reliable. With custom FW it will do anthing you can think of. It is not hard to install the custom firmware if you get this simple drop in board: http://www.smartieparts.com/shop/ind...roducts_id=331. Steve is also a great guy to deal with. There is plenty of support and information here: http://www.rcgroups.com/forums/showt...=1266162&pp=50 and here: http://9xforums.com/forum/ Welcome back! |
You ask why there are surface and air radios. The answer is that though they all work on 2.4 (where there are no discrete "frequencies" as the radios are all spread spectrum and/or frequency hopping), there are different requirements for model control. The land transmitters typically have a wheel and trigger, while marine radios may also have special features. In some cases the various receivers and transmitters are compatible but not in others. There's nothing to stop you from using an air radio with a boat, for example, but it may not be the best choice. For example, you may want a long antenna on the receiver to get it up from the water.
Latest blog entry: Polaris Aileron Pushrods
| Thread Tools | |
| Discussion Getting back into the hobby after a 6 year break. What has changed? | aspencer80 | Electric Plane Talk | 5 | May 05, 2012 09:21 PM |
| Discussion Back after 3 years of not flying | jtderr | Electric Plane Talk | 11 | Apr 17, 2012 06:48 PM |
| Discussion Back after 20 something years | RCTodd | The Builders Workshop | 23 | Apr 09, 2012 07:04 PM |
| Discussion Back at it after years | unkjay | Car Talk | 2 | Mar 10, 2012 08:22 PM |
| Discussion I have an odd question... how to get rid of factory RC radio mixing | caall99 | Radios | 2 | Nov 10, 2011 10:13 AM |
