Old May 09, 2012, 02:56 PM
gwilliams20 is offline
Find More Posts by gwilliams20
Joined Apr 2012
Locating receiver, ESC, battery and antenna
Are there any problems mounting these items closely together? I'm running out of room in the fuselage with a scratch build. I have a thunder 2700 mah 3S battery, CC Ice 50 amp ESC and Futaba R617FS 2.4 GHz FASST receiver.
To balance properly, I am pretty sure the battery will have to be located directly behind the firewall, followed by the ESC directly behind the battery with the receiver directly behind the ESC. There is a tray over the wing (low wing) running from the firewall aft to the trailing edge of the wing. I have a little latitude with the antenna.
Can I expect any problems with this setup?
All replies appreciated.
gwilliams20 is offline Find More Posts by gwilliams20
Old May 09, 2012, 05:36 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
1) Read the instructions on installation best practices.
are there problems? Maybe, maybe not.
Normally 2.4 FASST is not affected by ESC as their frequencies are different and FASST is extremely interference resistant. BUT.... your smileage will vary.
aeajr is offline Find More Posts by aeajr
Old May 09, 2012, 06:31 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The key requirement is that the antennas be well separated, not blocked by conductive stuff (battery, electronics, CF, aluminum landing gear, etc.) and have the active portions (the last 31mm or so) of the two more or less at right angles. Radios on 2.4 are remarkably resistant to noise but at least one of the antennas needs to be getting a reasonable signal at all times.
Daedalus66 is offline Find More Posts by Daedalus66
Old May 09, 2012, 09:08 PM
Joined Apr 2012
Thanks, guys. I reviewed what information I have. There is nothing in the CC instructions, and in the Futaba instructions, the only thing mentioned was the antenna installation. I'm thinking I saw something about an ESC interfering with a receiver a while back, but a search turned up nothing.
Oh, well. On the bright side, this radio came with a second free receiver. At least I'll have a few things to try again.
Old May 09, 2012, 10:35 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The ESC is not likely to bother the receiver even if they are very close. Some people even mount them back to back.
Old May 10, 2012, 08:21 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
There is always a chance of interference, but typically you are OK. Do your range check with the motor off and with the motor at 1/2 throttle. If you pass both you should be OK.
Old May 10, 2012, 10:44 AM
Joined Apr 2012
Alright! I feel better now. Just don't want to start out with a failure.
Thanks for your help.
Discussion Antenna location on my plane ricknoon FPV Aircraft 0 Apr 26, 2012 08:53 PM
Discussion does the location of the 2.4 GHZ transmitter antenna, really affects its range ? lazy-b Radios 7 Apr 09, 2012 04:51 PM
Discussion Electonic Ignition /Battery location RRS Engines 2 Mar 15, 2012 08:16 AM
Sold Garage sale AD! Longrange Spektrum DX6, Patch antenna, Batteries, Engines, ESCs, More seprice40 Non R/C Items (FS/W) 15 Jan 01, 2012 11:13 PM
Discussion Best location for Vtx and antenna? pc_pilot FPV Talk 0 Oct 29, 2011 09:54 AM
