This thread is privately moderated by nfcr, who may elect to delete unwanted replies.
Old May 09, 2012, 02:56 PM
nfcr is offline
Find More Posts by nfcr
Joined May 2012
SAE RC Aero Micro Class Competition
Hi All,
Has anyone here competed in an SAE RC Aero Micro Class competition? I was looking for a good guideline for typical dimensions, designs, materials and weights of common SAE Micro planes.
I am doing a project for a university course which follows most of the guidelines for the SAE Micro Class competition, and I am looking at identifying common designs, the most successful designs, materials, sufficient weights, etc.
Part of my team's objectives is obtaining the highest payload fraction possible - any help you could provide (or any typical ranges) would be much appreciated.
Thanks.
nfcr is offline Find More Posts by nfcr
Old May 09, 2012, 08:17 PM
nfcr is offline
Joined May 2012
Also, does anybody have any experience with designing landing systems for grass landings? I would imagine large, thin wheels would be preferable because they would be less susceptible to catch blades of grass and get tangled up, however I have seen designs with 2L pop bottles, foam pads (and other skid pad materials), etc... again, any help would be much appreciated.
Thanks.
Old May 11, 2012, 01:06 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Sorry I can't help much, but I did a few searches and found the -
http://students.sae.org/competitions/aerodesign/
and if you do a search on SAE Micro Aero in - http://www.youtube.com/ there appears to be quite a few SAE related videos.
One last check, scroll down this page, there is a 'Similar Threads' list, there may be a thread there that helps.
For grass take-offs and landings, larger diameter wheels are more important than how narrow, actually very narrow wheels could cause a problem, wider wheels will ride over the grass easier.
If you find a 'design spec' for the SAE RC Aero Micro Class, post a link, as knowing exactly what the requirements, limitations, are is needed to suggest any designs.
eflightray is offline Find More Posts by eflightray
Old May 14, 2012, 10:59 AM
nfcr is offline
Joined May 2012
http://students.sae.org/competitions...ules/rules.pdf - as far as I know, these are the most up-to-date rules for Micro Class 2012 (pages 30-40).
Also, our motor and servo requirements have been specified:
TGY-D1290P High speed Micro Servo
Turnigy Aerodrive SK3 - 3542-800kv Brushless Outrunner Motor
H-KING 35A Fixed Wing Brushless Speed Controller
Turnigy 2200mAh 3S 20C Lipo Pack
Turnigy 2S 3S Balance Charger. Direct 110/240v Input
Hobby King 2.4Ghz 4Ch Tx & Rx V2 (Mode 2)
We're thinking about belly landing for the grass landing requirement as it will most likely cut down on our empty weight.
Thanks again.
Old May 16, 2012, 02:52 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
That 3542-800kv is quite a big motor, I thought 'Micro' class would use a lot smaller motor. You could easily fly quite a big model with that. I have flown an 88" span vintage model on a similar sized motor.
Even the 2200mAh pack is quite a heavy weight for a 'Micro'.
The restriction of everything fitting in a case 24"x18"x8", will certainly restrict the design.
Belly landing is not a problem, a simple plastic strip would protect the fuselahe from most damage.
Competition SAE Aero Design Competition Photos--March 18-20, 2011, Lake Benbrook, Texas Richard N Electric Flight Events 5 Mar 22, 2011 11:15 AM
Discussion Old version SAE SD85-12N vs newer version SAE SD80-12? cptsnoopy Electric Heli Talk 0 Jan 02, 2009 02:00 PM
Competition SAE Aero-Design West 2008 at Thunderbird Field this weekend: April 5 and 6. Thomas B Electric Flight Events 3 Apr 07, 2008 11:04 PM
A Few Questions--SAE Aero Design natoquick Modeling Science 20 Feb 29, 2004 09:57 PM
