This thread is privately moderated by peterswolf, who may elect to delete unwanted replies.
Old May 09, 2012, 01:54 PM
peterswolf is online now
Find More Posts by peterswolf
Trader Rating: 104
peterswolf's Avatar
United States, FL, Riverview
Joined Apr 2012
Trader Rating: 104
Sold
Flyzone SkyFly Max
Up for sale is a Flyzone SkyFly Max PnP. I removed some of the stock decals and replaced with some tribal art, and lettering, which can be removed easily if so desired. Everything else in regards to plane is stock, motor, esc, servos. I only purchased this two months ago from Tower Hobbies. You will need your own lipo, rx and tx. It uses a 1800mah 3S lipo which you need to supply, or I might be able to throw one in for a bit extra $$. It has minimal damage that has been repaired (see pictures). I had it gliding up high when my rx went bad and it slowly spiraled down to the earth. It made a fairly gentle nose down into the ground which scuffed the nose (I reinforced with some CA in the joint) and the propeller flexed enough to chip the wing a bit on either side, nothing major at all or that affects flight performance. Many use these planes for pan and tilt mount cameras and such since it has a pusher prop behind the wing itís great to mount a camera up front. Iím looking for $100 obo LPU (Tampa Bay area), I prefer not to ship as the way the tail boom is installed it might not be the greatest idea to ship it like that. However if you really want it shipped, you pay shipping.
Link to product website for more specs: http://www.flyzoneplanes.com/airplan...511/index.html
peterswolf is online now Find More Posts by peterswolf
Last edited by peterswolf; May 09, 2012 at 01:57 PM. Reason: Added link to product specs
Old May 12, 2012, 06:36 PM
Trader Rating: 104
peterswolf's Avatar
Joined Apr 2012
Trader Rating: 104
No longer for sale
No longer for sale
Latest blog entry: http://www.peterswolf.com
Discussion 9 volt battery upgrade to Skyfly 9x radio miss5031 Radios 10 Apr 06, 2012 04:12 PM
Help! 750mm p-47 & skyfly engine mods?! Laflammablanca Power Systems 3 Mar 18, 2012 12:44 PM
Sold Hobbico FlyZone SkyFly Max EP 2.4GHz RTF w/Ailerons 47 vcaruso Aircraft - Electric - Airplanes (FS/W) 11 Jan 21, 2012 08:40 PM
Discussion skyfly max motor upgrade boy santiago Electric Plane Talk 2 Oct 26, 2011 04:17 PM
Found want to trade flyzon select scale for micro cub hendleyusmc Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jan 25, 2011 12:38 AM
