Old May 09, 2012, 09:59 AM
gdimonte is online now
Find More Posts by gdimonte
Canada, ON, Newmarket
Joined Dec 2005
Mini hawk pusher - tip stall issue
I built a mini hawk for fun and it flies really well except for one problem. It has a nasty tip-stall issue when slowing down for a landing. The model is based on a 3-view drawing and is 100% scale in terms of overall size. The wing is a flat bottom with a basic airfoil sanded on the top. Where should I start to look to resolve the issue.
gdimonte is online now Find More Posts by gdimonte
Old May 09, 2012, 04:31 PM
Joined Dec 2005
Anyone....
Anyone....
Buler..................
Old May 09, 2012, 11:40 PM
djacob7 is online now
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
It's not a glider, so you must land at relatively high speed. One wing will naturally stall before the other. If you really want to come in slower, you might try twisting the wing tips leading edge downwards.
djacob7 is online now Find More Posts by djacob7
Old May 10, 2012, 04:25 AM
ResQ is offline
Find More Posts by ResQ
Gravity Sucks
Somewhere in the Nations Capital
Joined Sep 2007
Hi gdimonte,
being a jet and since you have indicated that you used scale proportions, this will likely be an airspeed thing as mentioned above. A sanded airfoil may not produce sufficient lift at low (or even just reduced) airspeeds. You may need to review your wing (span, area and/or airfoil). Also with a pusher config, keep in mind you won't havethe prop blowing air over the wing and helping to generate lift. Are your controls mussy on approach?
Lots of the hawks modelled have an enlarged (i.e. non-scale) wing to achieve suitable flying characteristics. Also, the real hawk has wing fences on the LE about 2/3 of the way out. My understanding is that they work to stop exactly the type of thing you are descibing.
Try having a look at these 2 threads by Nitro.
http://www.rcgroups.com/forums/showthread.php?t=689156
http://www.rcgroups.com/forums/showthread.php?t=1386094
He has a fantastic looking and flying mini EDF hawk. He has a built up airfoil and has the wing fences. I think his wing may have been enlarged too (IIRC).
Good luck with it. It's a great looking little model and hope you get it sorted. If nothing else, just fly it WOT and like you stole it - that should fix things!
ResQ is offline Find More Posts by ResQ
Old May 10, 2012, 03:36 PM
Joined Dec 2005
Thanks for the input. I'm going to play around with a larger wing area and see what I get. In the mean time, I'm going to knock-off a couple of airframes to play with.
Idea Solution to vicious tip stall! skybolt123 Electric Plane Talk 91 May 15, 2012 10:30 AM
Discussion washout at wing tips to avoid stall phil alvirez Scale Sailplanes 36 May 12, 2012 04:12 AM
Question Graupner Mini Discus TIP STALL????? Edwinzea Foamies (Kits) 4 Feb 15, 2010 01:19 PM
Discussion GP Mini Super Sportster: Tendency to tip stall? whwong Parkflyers 0 Apr 25, 2006 10:17 AM
Tip Stall - Mini Thermalaire sierra-gold Electric Sailplanes 4 Sep 26, 2003 07:21 AM
