Old May 09, 2012, 09:52 AM
Rare Bear is offline
Find More Posts by Rare Bear
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Question
LED Light Installation w/ DJI F550 - How To?
Just wanting to see if someone kind enough could assist me w/ a question regarding LED setup. Have a DJI F550 on order with (3) LED colors I want to attach to arms. F550 is running on 4S, and lights are rated max of 3S. BEC will handle the drop in voltage to take care of LED's, but I am not sure how to effectively wire them up?
In short, I will have (6) arms that have LED strands coming off them that need to be fed appropriate voltage for power. Really do not want to use a separate battery for power.
Can anyone kindly provide insight on a CLEAN wiring setup for LED lights on this type of hexacopter? Really want this to come out clean - don't care much for spaghetti monsters.
Thank you for your help!
Rare Bear is offline Find More Posts by Rare Bear
Old May 09, 2012, 10:28 AM
Price4Flight is offline
Find More Posts by Price4Flight
Price4Flight's Avatar
United States, TX, Austin
Joined Jan 2012
Is there a F550 pre-wired LED kit out there?
Price4Flight is offline Find More Posts by Price4Flight
Old May 09, 2012, 10:31 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
We have been running these 12v LED strips on 4S battery for a while now, no issues at all. Just solder them together and wire them directly to your main power plug.
Steph280 is offline Find More Posts by Steph280
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Not that I am currently aware of; then again, I am new to multicopters, so I may be missing that key piece of info.
If anyone has any feedback on that, I would GREATLY appreciate it - will have my F550 today and want to get her flying very soon.
Thank you!
Old May 09, 2012, 11:21 AM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Really? Am I asking for trouble, aside from burned out LED lights? If only the LED lights are at risk, I have no issue just going for it, as they are cheap. However, I don't want a short somewhere, so if there is an issue, kindly let me know.
Thanks for the tips!!
Old May 09, 2012, 12:02 PM
azure is offline
Find More Posts by azure
Joined Mar 2012
I just tapped my 12v BEC off the points where the main 4S battery leads are soldered to the bottom plate on the f550. Then it was just a matter of making a 6 lead, parallel "star" patterned connector from the BEC output. I stuck JST connectors in-line also so I could disconnect them if I wanted to (switch would work too). Yeah, it's six pairs of wires, but wasn't too much of a mess: zip ties and velcro.
azure is offline Find More Posts by azure
Old May 09, 2012, 12:56 PM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
Using this ones with main 4S battery, the leads are soldered to the bottom plate on the f550 out were the ESC is soldered on..
It is 1watt and giving me a lot of light when I go high....
rsun77 is offline Find More Posts by rsun77
Old May 09, 2012, 01:29 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Incredibly helpful - thank you!!!
Old May 09, 2012, 01:31 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
May I ask where you found the below curved pieces that give your F550 some additional height?
Old May 09, 2012, 01:46 PM
Isaiah 40:31
Rare Bear's Avatar
Joined Mar 2006
Sorry Yet another question - where did you get those LED discs?
VERY COOL!!
Old May 09, 2012, 03:09 PM
rsun77 is offline
Joined Jul 2008
I did find them in Denmark....
This is the ones I used, maybe you can find then at your location...
http://www.led-manufacturer-supplier...er-leds/09.htm
It is Yuri that make them.... PM sent to you
Old May 09, 2012, 03:50 PM
worbc is offline
Find More Posts by worbc
United States, CA, Irvine
Joined Apr 2012
Can you suggest a source?
--terry
worbc is offline Find More Posts by worbc
Old May 09, 2012, 04:05 PM
worbc is offline
Joined Apr 2012
Wow, those are bright. Are they wired directly to the bottom board, or do you have a resister in there? The spec sheet has operating voltage at 3 volts. It also says they also dim?
--terry
Old May 09, 2012, 04:13 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
--terry
Source for the LED's? hobbypartz or hobbyking.
Or are you talking about the power source? Just tap into the 4S battery bus.
I've always wanted to try those 1watts+ LED's. There are plenty of them here, but not sure which ones work well:
http://www.dealextreme.com/c/flashli...-and-tools-917
Old May 09, 2012, 04:23 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
leg extensions: http://tppacks.com/catalog/product_i...products_id=30
Those are for F450 but they probably have F550 ones as well.
Discussion Machine Gun Muzzle blast w LED lights robotronski Electric Warbirds 36 Jul 25, 2013 12:29 PM
Build Log DJI F550 NAZA ARF COMPLETE BUILD and DJI NAZA ASSISTANT w/ TX CALIBRATION >VIDEOS< patrick21x Multirotor Talk 11 Nov 30, 2012 07:13 PM
Build Log Build/How-To Report: DJI Flame Wheel F550 feat. Wookong M + NAZA PitchBitch.EU Multirotor Talk 1 Apr 19, 2012 05:27 AM
Discussion My very first FPV flight ever with my DJI Flame Wheel F550 Hexacopter w/ Vuzix goggle jasper7821 FPV Talk 2 Mar 31, 2012 04:00 PM
Sold HPI 337 LED Light W/ Battery Indicator Set Blue for Baja NEW! tprada1624 Cars - Cars and Parts (FS/W) 4 Nov 20, 2011 10:50 AM
