Old Dec 30, 2012, 08:41 AM
phthomps is offline
Find More Posts by phthomps
Joined Dec 2012
Is low voltage cutoff supported
Hi,
Managed to change 2 Turnigy F-20A's to brushed, anyone know if it's possible to set or use a low voltage cut-off for lipo batteries?
phthomps is offline Find More Posts by phthomps
Old Dec 31, 2012, 01:08 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Originally Posted by phthomps View Post
Hi,
Can you share your changes to make the F20 work?
Thanks Christian
LazyZero is offline Find More Posts by LazyZero
Old Dec 31, 2012, 10:44 AM
phthomps is offline
Joined Dec 2012
Programming ESC to Brushed
Hi,
I removed a small part of the black rubber backing on the ESC and it exposed 6 programming pins on the circuit board near the red wire.
In order from bottom to top, they are: MOSI/MISO/SCK/GND/VCC/RESET.
The firmware came from: https://launchpad.net/brushed
I used a USB AVR programmer and it flashed the hex file in a few seconds.
After that, connected it up and it's working great
Best Regards,
Paul
Old Jan 29, 2013, 02:13 PM
Tengil is offline
Find More Posts by Tengil
Joined Jul 2012
Nice programing, wonder what it can be use for...
What if using the 2 in 1 esc software together with a kk2 to make a Segway?
Should be possible.
Hardware maybe wiper motors from the scrapyard?
Unfortunately I must relay on you programing geniuses. ;-)
Tengil is offline Find More Posts by Tengil
Old Feb 21, 2013, 06:26 PM
Copernicus552 is offline
Find More Posts by Copernicus552
Joined Nov 2012
Copernicus552
Hi,
Best Regards,
Paul
Could you please show diagram of how to wire the motor connections to this ESC, I am assuming battery connection will stay the same? Just got a flushing tool rom Hobby King, will try it out as soon as I know the motor connections, hate to fry it.
http://www.hobbyking.com/hobbyking/s...hing_Tool.html
Copernicus552 is offline Find More Posts by Copernicus552
Old Jun 11, 2013, 10:03 PM
Ottomite is offline
Find More Posts by Ottomite
The Ottoman Flyer
USA, TX, Galveston
Joined May 2010
I just flashed my F-30 with this just curious how does the wiring work ? Do i just connect to the motor from the brushless motor leads ?
Edit: Found out that i was using the wrong hex now im using the right one and got it working.
Ottomite is offline Find More Posts by Ottomite
Old Jun 13, 2013, 08:30 PM
xerovis is offline
Find More Posts by xerovis
Joined May 2013
More information
Love this hack, thank you very much for making the information available.
I would like to use this on a couple of wheelchair motors but I am struggling with the documentation provided. I have checked out the other brushless ESC conversion project in this thread to see if I can work out how to connect the ESC to the motor. Is someone able to take a photograph of how they have done it please? I notice on the other project, they are connecting to two of the poles but it seems this project solders the wires directly to the FETs.
xerovis is offline Find More Posts by xerovis
Old Jun 17, 2013, 01:51 AM
Tengil is offline
Joined Jul 2012
Should be possible.
This is to lift this tread.
I still hope someone could be the first and show us how to make a segway using this and the KK2 control board.
Old Jun 25, 2013, 05:00 PM
elbowdonkey is offline
Find More Posts by elbowdonkey
Breaker of Things
elbowdonkey's Avatar
United States, OR, Portland
Joined Dec 2011
I'm curious as well. I just flashed a Atmel based Hobbywing Pentium-6A without issue, but I'm not sure what's next.
Is it safe to use two of the original three motor leads, determining which leads to use by trial and error?
elbowdonkey is offline Find More Posts by elbowdonkey
Old Jul 09, 2013, 12:19 PM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
I have flashed this ESC http://rctimer.com/index.php?gOo=goo...7&productname=
It seems to work on the 2 of the 3 BL outputs so I guess I don't need to solder between the mosfets.
I have one issue, the motor goes to full when the throttle is at approx 50% instead of 100... how do I calibrate the range?
Zen09 is offline Find More Posts by Zen09
Old Jul 22, 2013, 09:46 PM
Jame David is online now
Find More Posts by Jame David
Joined Feb 2013
maybe change throttle in program
continues
Jame David is online now Find More Posts by Jame David
Old Jul 30, 2013, 04:50 PM
danjr1 is offline
Find More Posts by danjr1
Joined Jul 2013
Hi all,
have just found this hack and am planning to use it on some RC timer 20a ESCs for a fighting robot. I was just wondering if the flashed ESCs failsafe or anything weird if the RC input signal goes over the 100% value? problems have occurred with other reflashed ESCs when using Spektrum DX6i with elevon mixing and additional mixing to get 100% throws.
Cheers
Dan
danjr1 is offline Find More Posts by danjr1
Old Oct 22, 2013, 04:23 PM
danjr1 is offline
Joined Jul 2013
hey,
I flashed a RC timer 20a ESC but it never seemed to work correctly. is there any set-up work that needs to take place once its been flashed with the software? I was using the brushedV3 hex file. Any help would be greatly appreciated as its for a fighting robot and would not only be for me, but the UK fighting robot community as a whole.
Cheers!
dan
Old Oct 22, 2013, 04:36 PM
rc my life is offline
Find More Posts by rc my life
Joined Nov 2012
Originally Posted by danjr1 View Post
hey,
Cheers!
dan
you should use firmware here : https://launchpad.net/brushed
Buy esc Tunigy30a or 85a.
rc my life is offline Find More Posts by rc my life
Old Oct 22, 2013, 04:52 PM
danjr1 is offline
Joined Jul 2013
Hey
That code won't work as the ESCs failsafe if the signal goes over 100%. We use the spektrum rc gear which has some funny mixing properties but we've managed to amend the code for the tz85a ESCs to compensate for this.
Cheers
Dan
Discussion Brushless ESC with a brushed motor soprano1 Power Systems 7 May 05, 2012 01:10 PM
Discussion ESC - brushed/brushless emeraldPark Electric Motor Design and Construction 1 Mar 14, 2012 09:13 PM
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 09:48 PM
need reversable speed control with no delay aaronredbaron Power Systems 0 Jul 31, 2003 04:40 PM
