Old May 15, 2012, 04:39 PM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Here is a new version. It has arming and the motor is stopped if signal is lost.
kapteinkuk is offline Find More Posts by kapteinkuk
Old May 16, 2012, 03:49 AM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Nice minimal code. Impressive! I like your "ldy" macros and pwm measurement, and it's nice that the hardware PWM can work on those boards. Cheers
simonk is offline Find More Posts by simonk
Old May 16, 2012, 12:40 PM
Quad Whisperer
Joined Jul 2008
Thanks!
I would like to to see a C compiler make a same size binary.
But then C code is actually human readable!
At least AVR ASM is better than the train wreck called PIC ASM
Old May 23, 2012, 04:12 PM
Quad Whisperer
Joined Jul 2008
RC Switch
Here is a firmware to convert the ESC to a RC controlled switch.
Load+ is connected to battey+ and load- to any or all of the motor wires.
It looks for 10 input pulses in a row, without timeout, above 1500 uS to turn on. Else it stays off. It will not turn on due to a few glitches.
Old May 28, 2012, 11:29 AM
SteveQRSC is offline
Find More Posts by SteveQRSC
Joined May 2011
Yes that binary size is impressive. Probably could have done my implementation in assembly but I chose not to to keep myself sane.
I also do lots of things in software to keep it generic for multiple ESCs I think I have done about 15 different ESCs myself though I haven't pushed up to the repository lately.
Feel like re-implementing my 2in1 controller in assembly so I can then port it to the 4k SiLabs chips.....
2in1 Test Drive (0 min 48 sec)
SteveQRSC is offline Find More Posts by SteveQRSC
Old Jun 02, 2012, 02:23 AM
Quad Whisperer
Joined Jul 2008
Originally Posted by SteveQRSC View Post
...in assembly but I chose not to to keep myself sane. ...
Good job on the 2in1 controller. I assume motor power is max 50% when motors goes opposite ways and 100% when going same direction? Motors are controlled simultaneously when going in the same direction and alternating when going opposite ways?
I wish there was robot fighting here in Norway, it seem like a load of fun!
Old Jun 02, 2012, 02:40 AM
Quad Whisperer
Joined Jul 2008
Here is the newest version. It solves a problem that is common to many bi-directional brushed motor controllers without brake.
The problem: driving at full speed, lower the throttle to coast, and just passing to the reverse side causes full braking.
This is caused when only lower or upper side of the bridge is switched.
This version switches both low an high side. Now it is possible to get a seamless transition from braking to reverse just by giving reverse throttle.
Makes it much more fun to drive cars like the Lunch Box or the Wheelie king. No need for braking, neutral, then reversing. Brake and reverse in one throttle movement. This also applies for going reverse, then forward.
I also have applied sounds: power on, arming and over temp alarm.
And I almost forgot: a adjustable dead band and adjustable drag brake for crawling! Works very well!
Enjoy
Old Jun 19, 2012, 07:20 AM
Quad Whisperer
Joined Jul 2008
Here is a video of my Nikko Razer with modded ESC's:
The resurected Nikko Razer (1 min 19 sec)
Old Jun 24, 2012, 03:17 AM
tawandapro is offline
Find More Posts by tawandapro
Joined Jun 2012
Turnigy 20A esc non reversible
i have a few lying around. can i mod the esc to have reverse? how? please reply
tawandapro is offline Find More Posts by tawandapro
Old Jun 24, 2012, 08:13 AM
Quad Whisperer
Joined Jul 2008
Brushed or brushless ESC?
Old Aug 02, 2012, 04:52 PM
Masa159 is offline
Find More Posts by Masa159
Joined May 2012
How do you actually put the firmware on the ESC?
Masa159 is offline Find More Posts by Masa159
Old Aug 03, 2012, 06:49 AM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
I think the same way they flash the Simonk firmware for multis.
tigar is offline Find More Posts by tigar
Old Aug 03, 2012, 08:36 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
RCTimer/Turnigy/Hobbywing ESC DIY Firmware Flashing
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Sep 15, 2012, 03:43 PM
danielnc06 is offline
Find More Posts by danielnc06
danielnc06's Avatar
United States, NC, Charlotte
Joined May 2010
Edit: I tried the rc switch a second time and it worked!, no more heat either.... just no variable brightness.. oh well.
One observation... with the LEDs... in the Off position.. they glow just faintly....is this bleed through or possibly part of the code?
Thank You KK
__________________________________________________ _____________________________
A quick question regarding this. I reflashed this model of esc (hobbywing 25A):
to the brushless firmware.. works great although I am using it to act as a variable brightness led switch.. and i am testing it out while powering an stick-on led strip of about 45 leds..... it works great except that it is getting pretty warm..much warmer than i would of though I would estimate about 120-130degrees F. Is this the model with the "bootstrap" capacitor that was mentioned earlier and this is a malfunction or do you think its just running this hot since because its leds...I would not think it get this hot... they should only be pulling about .3-.4 A total max...
I did try the rc switch firmware with no luck before this.....
__________________________________________________ _____________________________________________
danielnc06 is offline Find More Posts by danielnc06
Old Sep 15, 2012, 08:02 PM
danielnc06's Avatar
Joined May 2010
A very good thread for this topic with the pinouts of most esc's on the market:
http://www.rcgroups.com/forums/showt...ght=esc+pinout
Discussion Brushless ESC with a brushed motor soprano1 Power Systems 7 May 05, 2012 01:10 PM
Discussion ESC - brushed/brushless emeraldPark Electric Motor Design and Construction 1 Mar 14, 2012 09:13 PM
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 09:48 PM
need reversable speed control with no delay aaronredbaron Power Systems 0 Jul 31, 2003 04:40 PM
