Old May 09, 2012, 05:51 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
Reprogram a brushless ESC to get a brushed ESC with no delays / RC Switch
Hi, I have made a new firmware for the Turnigy Plush 10A brushless ESC (old type) to make it into a no delay, instant reverse, fast response, forward and reverse brushed ESC for RC crawler cars, tanks and other skid steer vehicles. It has a switching frequence of ca 16kHz, so it does not make that annoying whining sound.
Other ESC's can probably be used for higher current capability.
It currently does not have arming, LVC or overtemp protection, but I can add that if there is a interest in it.
Source code is attached. **EDIT**: There is a newer version later in the thread.
Homemade Brushed ESC for crawlers and tanks. (1 min 8 sec)
kapteinkuk is offline Find More Posts by kapteinkuk
Old May 09, 2012, 08:09 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Rolf,
This will come in handy for a future project Thanks for posting!
Just FYI Steve also did something like this with Silabs processor fitted ESCs here: http://www.rcgroups.com/forums/showp...0&postcount=13
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old May 09, 2012, 09:06 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Please, can you post a wiring diagram of how the ESC is connected to the motor?
Thank you.
Edited: A brushed motor has two poles, so I am confused.
rimshotcopter is online now Find More Posts by rimshotcopter
Old May 09, 2012, 11:38 AM
schumixmd is offline
Find More Posts by schumixmd
schumixmd's Avatar
Moldova
Joined Jun 2010
Hi.
That's great Rolf. I have bought an Tunigy 20A Brushed ESC for my mini car project, but it has no reverse and it is very hard to control the card without reverse. So I was searching for this conversion for long time.
my question: will your firmware work with Tunigy Plush 25A and/or Tunigy Plush 6A and/or best option for me TowerPro Mag8 (30A)
thanks
schumixmd is offline Find More Posts by schumixmd
Old May 09, 2012, 02:33 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by jesolins View Post
Hi Rolf,
Cheers,
Jim
Ok, I have not seen that one. But anyway, I like to make things myself
Thank you.
The motor is connected to the two half bridges closest to the battery side of the ESC. (two wires closest to the capacitor)
Originally Posted by schumixmd View Post
Hi.
thanks
It should work on a 6A. About the two others I do not know since I do not have the schematics for them.
I'm planning to take a look at the plush 30A. Maybe all the plushes has the same hardware pinout?
Old May 09, 2012, 02:41 PM
George Shering is online now
Find More Posts by George Shering
Scotland
Joined May 2005
There might be a problem with ESCs that use FET drivers as they have a bootstrap capacitor that needs re-charging all the time?
George Shering is online now Find More Posts by George Shering
Old May 09, 2012, 04:21 PM
Quad Whisperer
Joined Jul 2008
It will only be a problem when using an all-NFET ESC where the charge pump is driven by the half bridge's output. (HK F-20, F-30 and others).
Whether it uses a driver chip or not is not important.
It will be possible to use an all-NFET ESC if it has a separate charge pump, like the ginormous tower pro 40A heli.
Old May 09, 2012, 06:52 PM
simonk is offline
Find More Posts by simonk
hacker
Canada, BC, North Vancouver
Joined Dec 2010
You can get a bit of an idea about compatible hardware by looking at http://docs.google.com/spreadsheet/c...jU1YzdBQkZZRlE ... if they work with tgy.hex, they should be compatible.
simonk is offline Find More Posts by simonk
Old May 09, 2012, 10:31 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Another nice one Rolf. You are a clever boy.
Rob...
mxspode is offline Find More Posts by mxspode
Old May 11, 2012, 05:31 AM
Quad Whisperer
Joined Jul 2008
Good idea
Rob...
Old May 11, 2012, 06:46 AM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
Pretty cool project. I was looking for a brushed forward/backward ESC to reanimate a old RC fisher boat with Mabucchi 300 for my son. And was amazed to see that the market decreased dramatically. You only get some overpriced car ESC. I will test after vacations on a RedBrick 25A.
Best Christian
LazyZero is offline Find More Posts by LazyZero
Old May 11, 2012, 06:35 PM
simonk is offline
hacker
Joined Dec 2010
btw, if you want a crawler brushless ESC, you can enable RC_PULS_REVERSE in my tree and put it on any flight board
the real question is what can you do with the extra FET channel when using the brushless ESC board as a brushed ESC... dimmable headlights?
Old May 11, 2012, 07:13 PM
Quad Whisperer
Joined Jul 2008
I was thinking using the extra channel for back-up light.
Old May 14, 2012, 01:58 PM
vipix is offline
Find More Posts by vipix
FPV from Lithuania
vipix's Avatar
Lithuania
Joined Mar 2007
Can this software handle 490Hz PWM?
vipix is offline Find More Posts by vipix
Old May 15, 2012, 04:29 PM
Quad Whisperer
Joined Jul 2008
Yes, no problem.
Discussion Brushless ESC with a brushed motor soprano1 Power Systems 7 May 05, 2012 01:10 PM
Discussion ESC - brushed/brushless emeraldPark Electric Motor Design and Construction 1 Mar 14, 2012 09:13 PM
Found WTT: My Pro Boat Brushless ESC for your Pro Boat Brushed ESC Diegoboy Boats (FS/W) 12 Dec 23, 2011 09:48 PM
need reversable speed control with no delay aaronredbaron Power Systems 0 Jul 31, 2003 04:40 PM
