Old May 09, 2012, 12:48 AM
guyg is offline
Find More Posts by guyg
Israel, Ness Ziona
Joined Sep 2004
GAUI X330 sudden "Drifts\unstable " during flight- Help
My quad flyes great for a long time ...but..
As from 2 days ego as i had a bad landing- no big dammage
As i hover with my quad
I get sudden Drift to the left
It seems unstable.
Crazy to fly like that so i Must solve this thing
No mechanical problem was found
Went over ALL component for wire dammage- none
Replace for the safe side two motors- none..
-----Next step----------
Go over all Speed control- of all motors- Calibrate from 0 every one.
Check the main Gaui X330 move it to my other quad and check
Check the RX reciever ...(get it from my other quad)
Any one had this type of problem?
Info? help?
Tx
Guy
guyg is offline Find More Posts by guyg
Old May 09, 2012, 11:31 AM
sweatyfingers is offline
Find More Posts by sweatyfingers
I break cameras
sweatyfingers's Avatar
Joined Sep 2004
Guy, This may not be it, but when I still had in intact Gaui X330 the sticky anti-vibration mounting pads came loose between the Flight Controller and the frame of the quad enough to cause the quad to fly off at an angle..... I didn't realize it until too late. Did you check the FC mounting? If you hold the quad in your hands and throttle up, does it want to pull off at an angle? this may not be it but just sharing mine.
sweatyfingers is offline Find More Posts by sweatyfingers
Old May 09, 2012, 01:04 PM
guyg is offline
Israel, Ness Ziona
Joined Sep 2004
gaui maunting is OK..tx
Found out a Bad motor shaft that was probebly hit..
Replace the motor..with a New one- the bird flyes OK now
Mach Better !!
..still need some checking to do
Could be one more motor shaft is very slightly bend..
I will update
GUY
Tx for the help sweatyfingers
Discussion Chaos 550 boom broke during flight! jgpncll Large Electric Helis 101 Apr 11, 2012 02:48 PM
Discussion Motor wont run all of a sudden. Need help troubleshooting it. Bixler AKA Sky Surfer dllhg Electric Plane Talk 3 Mar 24, 2012 06:32 PM
Discussion FY91Q + THX9 and my unstable flight cvianna Multirotor Talk 3 Feb 26, 2012 07:40 PM
Discussion V120d05 drifts back and right during low battery power. bktho7771 Micro Helis 18 Sep 19, 2011 07:55 PM
Discussion HELP-Electric Motor Pulsing During Flight Tracks FPV Talk 13 Sep 06, 2011 06:30 AM
