Old May 08, 2012, 11:58 PM
justin144 is offline
Find More Posts by justin144
justin144's Avatar
Joined Sep 2011
Prop adapter for NTM Prop Drive Series 4248 650kv
Anyone care to help out a noobie?
I ordered this NTM Prop Drive Series 4248 650kv motor and I need a prop adapter to fit it. Can I just order any prop adapter that is 5mm? I was told by someone else that I need an 8mm prop adapter but I don't know where he got that number from . This prop adapter should work, right?
Here are the specs on the motor:
Model: NTM Prop Drive Series 4248 650kv
Kv: 650rpm/v
Turns: 7T
Max current: 70A
Max Power: 1295W
Shaft: 5mm
Weight: 243g
ESC: 60~70A
Cell count: 4~5s Lipoly
Front Mounting Hole Distance: 25mm
Connection: 4mm Bullet-connector
justin144 is offline Find More Posts by justin144
Old May 13, 2012, 06:23 PM
mlwartman is offline
Find More Posts by mlwartman
United States, OH, Columbiana
Joined Apr 2012
http://www.hobbyking.com/hobbyking/s...sory_Pack.html
mlwartman is offline Find More Posts by mlwartman
Old May 13, 2012, 06:35 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
And here it is from the U.S. warehouse:
http://www.hobbyking.com/hobbyking/s...dProduct=24240
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 13, 2012, 06:38 PM
justin144's Avatar
Joined Sep 2011
Jack
That states that it's for an 8mm shaft though.. The motor has a 5mm shaft.. Am I wrong?
Old May 13, 2012, 09:02 PM
Joined Apr 2012
dunno. the 42-58 says it's a 5mm shaft too, but the 42 series kit does say 8mm. good question.
i just looked and the 35-48 i ordered says 5mm shaft, but the 32 series kit says 6mm shaft. if you wanna wait a couple days both are already ordered from the us warehouse. i can let you know... i have a sneaking suspicion the specs aren't being updated from motor to motor. a 35 series shouldn't have the same diameter shaft as the 42 series...
Old May 13, 2012, 09:27 PM
justin144's Avatar
Joined Sep 2011
Yah, something must be up. Well I ordered it anyways because some other dude said that's what he ordered for the same motor, so we'll see!
Thanks!
Old May 13, 2012, 09:41 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The 8mm dimension is size of the threaded shaft that the prop goes over. The prop adapter attaches to the magnet housing with screws it does not slide over the motor shaft.
If you want a collet type prop adapter it will have a 5mm collet and a 8mm prop shaft.
Jack
Sold NTM Prop Drive Series 35-36A 1400Kv +60 Amp ESC and props and extras nige838 Aircraft - Electric - Power Systems (FS/W) 2 Apr 11, 2012 10:05 PM
Sold NTM Prop Drive 35-48 Series 900KV / 815W flyandi Aircraft - Electric - Power Systems (FS/W) 4 Apr 10, 2012 10:56 AM
Sold NTM Prop Drive Series 35-36A 1800Kv / 875w flyandi Aircraft - Electric - Power Systems (FS/W) 2 Apr 08, 2012 10:45 PM
Wanted NTM Prop Drive 28 Series Accessory Pack mamba max1 Aircraft - Electric - Multirotor (FS/W) 3 Mar 18, 2012 07:25 AM
Wanted NTM Prop Drive 28 Series Accessory Pack mamba max1 Aircraft - Electric - Power Systems (FS/W) 0 Mar 16, 2012 05:09 PM
