Old Aug 28, 2012, 07:47 AM
jab
Unregistered User
Joined Aug 2007
Originally Posted by Mr_westie View Post
I do the same test again in 'Setting State', aka Init setup.
No FC control, just direct TX throttle to motors.
No shaking, shake indicator on the gcs less than 10.
This shows that the FC is inducing the shaking.
Is my reasoning correct?
What exactly is less then 10 on the shake indicator? Shake at 10 is A LOT of vibrations and might cause problems with the IMU. You really want to try and get that number as low as possible. Even my big octo with 15" propellers hover with shake as low as 2 with just short dips up into 3 when I punch the throttle.
jab is offline Find More Posts by jab
Old Aug 28, 2012, 08:07 AM
Joined Jan 2012
Just watched the pic of your install and wow what a mess. I think you should reinstall all and hard mount IMU to the middle of the frame without vibration dampening plate. I'm 99% sure it will fix your problem. And also try to mount IMU also vertically as close to CoG as possible, so "bottom" plate might be better.
KariY is online now Find More Posts by KariY
Old Aug 28, 2012, 08:55 AM
South Africa, GP, Johannesburg
Joined Sep 2010
I agree....I learnt a long time ago that the IMU on nearly all systems should more or less be at the same level as the props.
The other thing is the pad provided to support the IMU is too spongy and should not be used, and the IMU should be mounted on double sided tape. You can see in the pic how the IMU is leaning to one side. This has been mentioned a number of times in various threads, however, I suppose that ZeroUAV still keep on supplying it, so the user will still continue using it. The dealers should educate their customers though.
One other thing, I think the GPS is too close to the rest of the electronics. I suggest that you use the post that came with the YS-X6
Rob
robone is offline Find More Posts by robone
Old Aug 28, 2012, 09:09 AM
jab
Unregistered User
Joined Aug 2007
KariY is correct. I only read your text and did not really look at the picture. I suspect the foam you are using is to flexible, so that the entire IMU unit is wobbling. The IMU has internal vibration dampening, so try mounting it directly on the frame.
Old Aug 28, 2012, 09:31 AM
Salocin's Avatar
Joined Aug 2012
I use gyro gel to mount my IMU and it works good.
Salocin is offline Find More Posts by Salocin
Old Aug 28, 2012, 01:27 PM
Joined Jan 2012
I tested gyro gel also but ended up hardmounting it with double side tape + ziptie to secure it firmly. If any difference was notable it only got slightly better. Internal dampening should be efficient enough, if it's not then there is something else wrong, too much motor/prop vibrations etc. My vibration levels are normally 0-1 and max 2 in peaks.
Old Aug 28, 2012, 03:34 PM
YS-X6 Know why it crashes,blog
New Zealand, Auckland
Joined Nov 2007
Yes, it could be cleaner
Long term plan was to make it weather proof so I can fly it in rain.
So still proof of concept stage.
I tried hard mounting with foam tape/gyro gel before but the shake was too high.
It was my first frame build with no balancing and optimisation.
Will try it again now that I have done all I can.
Balanced props.
Dynamically balanced on motor.
I do look forward to the day I can build a frame with such low shake values
GPS close, I thought so too.
But it is still gertting good lock, better than my Garmen eTrex
Thanks all for the tips.
Will post results.
Mr_westie is offline Find More Posts by Mr_westie
Old Aug 28, 2012, 08:08 PM
Joined Nov 2007
Relocated imu and tidied up the cabling a little.
You can see the rubber gromets I used to isolate the gimbal and top tray.
Hopefully they help.
Looks like my effort with dynamic prop balancing paid off.
And putting the motors under arms to reduce prop wash vibration.
Shake is now down to 2, peaking at 5.
mmmuummm humble pie.
Thanks guys
Old Aug 31, 2012, 11:56 AM
uavservices on MRF
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
it's the dji arms that make it shake.... not so much your build... that frame is bad for vibrations.
Steve
Balanced props.
Will post results.
saabguyspg is offline Find More Posts by saabguyspg
Old Sep 04, 2012, 07:42 PM
fajar's Avatar
sydney, downunder
Joined Jan 2011
Steve
I've tested DJI F450 and F550 frame with YS-X6, the FC handled the vibes well.
fajar is offline Find More Posts by fajar
Old Sep 05, 2012, 03:18 AM
jab
Unregistered User
Joined Aug 2007
Yes, the YS-X6 should fly the F550 pretty well with default settings. And while the DJI frames are far from ideal, they (and Hobbyking OEM version) are well suited for lowering the price of experiments that have a high chance of not ending all that well.
ZeroUAV YS-X6 test flight (2 min 56 sec)
Old Sep 05, 2012, 03:24 PM
Joined Nov 2007
I asked about the RPM sensors.
ie.
http://zerouav.net/productmore.aspx?id=82
"ONITOR MOTOR ROTATION SPEED
When your are using S-Bus, if the channel C8?A?E?T?R?C5 is empty, the speed sensor can be inserted. In "Data" of GCS, it displays the accurate rotation speed of each motor, to monitor the efficiency and balance of multirotor."
The sensor is not available on it's own.
Only as part of a complete package.
Customized or Professional version.
My guess is it is most likely just an optical pwm input.?
Will test and report back.
On another note, Current sensors for all.
RRP us$111 from ZeroUAV
I understand the need to recoup R&D by marking up the price of hardware.
But at least do it on something that is not easily replicated.
ACS758LCB-100U-PFF-T
http://www.allegromicro.com/Products...Cs/ACS758.aspx
#originally linked to 200A version. 40mv/A 100A version is what is used.
DIY for $10 worth of parts
Old Sep 05, 2012, 07:43 PM
Reginak's Avatar
Joined Jul 2011
Just a test here in Brazil.
http://www.youtube.com/watch?v=9nPPP6kfCS4
Reginak is offline Find More Posts by Reginak
Old Sep 05, 2012, 07:54 PM
Joined Nov 2007
Another great video.
Can we expect some Olympic coverage when it comes around?
Old Sep 05, 2012, 08:30 PM
Salocin's Avatar
Joined Aug 2012
Awsome.
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1199 Feb 22, 2013 07:48 PM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
