Australia, NSW, Albury
Joined Jun 2012
I've just spent many hours upgrading my Droidworx ADX-4 to X8. I've fallen short just 3 female bullet connectors for my new ESC's, so can go any further tonight. I hope to continue my upgrade tomorrow afternoon, and get the UBEC in to power my gimbal servos. I've not flown for 2 weeks, but getting close again. Nearly there. Lotts of wire tidying to do, but should be able to spin up without props soon.
Nic. |
Joined Jun 2012
I'm glad you got it sorted. Perhaps they intentionally put the GPS upside down for our southern hemisphere folk.
honestly I don't know if it's a good idea to put the IMU right on top of the control unit...
Steve Quote:
Also, I would say most if not everyone has ditched the damping plate assembly you've mentioned. V advised against using it (he was passing on the info from the developers) and I never looked at it again. |
India, KA, Bangalore
Joined Aug 2011
Hi Guys
Can anyone answer my questions 1: I have tried my YS-X6 on my old HTC wildfire: It has a encryption WAP2-PSK-AES ; The connect was ok; I got the data stream 2: I was really excited and got a new Galaxy S2 and update to the latest ICS os I found out the it has only WAP2-PSK encryption and I created the hotspot and the bule light on the WI-FI module is solid indicating the connect is successful but when open the GCS i do not get any data 3: I tried the same on my friends galaxy note and I also tried routing with a netgear router; but still i do not get any data on GCS in with my S2 or note both run ICS Can anyone solve the problem |
Wirelress Setting > Hot Spot > click on Menu (depend on phone.table). Once you can go into the advance menu... go to Lan Setup... see if your IP is 192.168.1.1 (if not, see if you can change it... ) and see if there's a DHCP and if there's a check box next to it.. check it. |
Hi all, I have read throught the manual and have a couple questions... I read 1.2 version of the manual BTW
1) Nowhere in there does it describe the arming function? is there one? as in like mikrokopter or DJI ? 2) it seems we can not locate the IMU "off centre" like DJI allows us to do... am I correct on this? 3) it states not to adjust the PID settings but I am sure everyone is... I know I will have to because my octo is very large and has 14" props with 4008 MT motors... soooo... I just want to see what others with large settings are doing with PID.... in my mikrokopter days I usually jsut toyed with "P" mostly... and a little "I" but never touched "D" If anyone can chime in on a large octo build with large props that would be awesome. Thanks guys. Steve |
South Africa, GP, Johannesburg
Joined Sep 2010
I am not using it. I would have installed it if I found that I had vibration issues, but I think with most good installations (balanced props etc, good motors) , any vibration should be minimised. I have installed my IMU on top of the main controller. Rob |
Joined Sep 2010
![]() Quote:
| Thread Tools | |
| Discussion YS-X6 testing | GotHeliRC | Multirotor Talk | 1199 | Feb 22, 2013 07:48 PM |
| New Product Test video of YS-X6 Autopilot system | pzhang | Multirotor Talk | 141 | Jun 07, 2012 06:50 AM |
| Discussion New UAV System from Zero UAV | alishanmao | UAV - Unmanned Aerial Vehicles | 2 | Apr 19, 2012 09:02 AM |
| New Product YS-X6:A coming new king in the multi rotor heli world | yiny0730 | Multirotor Talk | 13 | Mar 28, 2012 11:28 PM |
