Old Jun 23, 2012, 03:46 PM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Hi guys, here is what happens when you set roll sensitivity value accidentally to 10 instead of 100. Just a reminder to always double check right values before take off. It's very easy to make mistake clicks with mobile apps. In video roll compensation of gimbal corrects quite well so you cannot see so well what really happened but hexa came totally uncontrollable.
6 broken wooden props but glad that Cinestar 6 frame, gimbal, GH2, and YS electronics seems to be fine. Just scratches to GPS cover.
http://www.youtube.com/watch?v=B7Fm5LwOwds
KariY is offline Find More Posts by KariY
Old Jun 23, 2012, 04:18 PM
rwijnhov is online now
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
Ok then the fluctuating of 50cm-1m is normal? You are experiencing the same?
rwijnhov is online now Find More Posts by rwijnhov
Old Jun 23, 2012, 04:48 PM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
No. I'm having very good altitude hold just like when using WKM.
Try to reset all values back to default. You have to fill in those values manually, though.
fajar is offline Find More Posts by fajar
Old Jun 23, 2012, 04:55 PM
Netherlands
Joined Feb 2009
No i mean when you look in your data screen on the gcs there you see it fluctuating with a difference of one meter. Pls check of your unit does the Same. I need to know if this is normal or not.
Old Jun 23, 2012, 05:16 PM
Netherlands
Joined Feb 2009
Ok I just made a video of the problem. All this time the copter is standing in front of me on the table. You see it starts att 0.0 alttitude and then climbs to 2.0 and fluctuates a lot. After about 4 min the altitude will be att around 4.0 still the copter on the exact same hight as before. So I believe my baro is faulty. could you pls check if you have the same issue. Thank you verry mucht for your help. pls see http://www.youtube.com/watch?v=IXTxqGmRSEQ for the video and the problem pls go from beginning to halfway to end and you will see the problem.
Old Jun 23, 2012, 05:19 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
have you flown yours yet?
The readings you get on the ground do not translate into how it will perform in the air.
The baro readings will show differential pressure readings given outside temps, weather changes, winds, etc.
Barometric pressure is not a static number.
The FC will hold its altitude when commanded to do so in the air via the center throttle position.
If you are looking at numbers on the ground but have not yet flown yours...then go fly, get to an altitude you are comfortable with, and put your throttle in hover position.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jun 23, 2012, 05:24 PM
Netherlands
Joined Feb 2009
Yes i already flew in the air i also get fluctuations of 1m when wind is blowing. I also have the wookong so i know how alt hold should work.
Old Jun 23, 2012, 05:56 PM
cryhavoc38's Avatar
Joined Mar 2007
Don't know what to tell you.
send yours back to the place you bought it and fly your WKM
Mine is rock solid and parks itself in the sky when I have good sat lock and put the throttle to middle position.
I watched your video.
I video'd my screen.
It does the exact same thing. It starts low, and then will slowly climb in value.
This is due to the temperature of the electronics/baro getting warmer as its powered on.
Shall I also make a video of my octo holding altitude hands off, just fine?
all copters will vary a little bit due to tolerances and such, but if your WKM has a better alt hold, then please, reinstall your WKM and enjoy your copter.
I am enjoying mine with the YS-X6 and I don't get altitude drift of more than a few inches up and down when the wind is blowing.
For the record, my Naza has a fantastic alt hold, but when the wind is blowing, its really bad.
Old Jun 23, 2012, 09:28 PM
TNTJET is offline
Find More Posts by TNTJET
Wish i was a flight pack
TNTJET's Avatar
Australia, NSW, Bass Hill
Joined Jan 2012
They are raw values and normal not sure if its gps value or baro but the algorithm of baro sensor and z axis accelerometer that outputs smooth height hold,i own 3 ,oct ,hex and quad all 3 alt hold and Ph extremely well and show fluctuations in gcs ,spend less time worrying and more time flying ,they are solid fc's if you had these features on the competitor im sure you would find the same values in gcs!
TNTJET is offline Find More Posts by TNTJET
Old Jun 23, 2012, 09:45 PM
jdreitman is offline
Find More Posts by jdreitman
Joined Feb 2010
I'm with you on this one Fajar. It's been flying amazingly well for me as well. GPS hold is 10X better than the WKM and all of the GCS features are just amazing The follow-me feature still freaks me out.
Originally Posted by fajar View Post
What happened to your comment here? You went from "pretty impressed" and "nice smooth flying" two weeks ago to getting "a lot of twitches wobbles" today.
Do you still use it on the same platform? I use mine on F550, Droidworx CX in X8 configuration, and quad F450, all of them flies great with stock settings, check my videos on the first page of this thread.
jdreitman is offline Find More Posts by jdreitman
Old Jun 24, 2012, 01:56 AM
Netherlands
Joined Feb 2009
Ok thanks guys then I know it isn't the baro that is giving me the issues. Could it be ESC related? I now use the hobbyking blueserie 30A. could it be they are not fast enough? I also have a wierd rappid twitching going on. Also I will mount the gps on a pole I now have it on top of the large unit.
Old Jun 24, 2012, 02:01 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
I remember simonk saying the the stock firmware on the Hobbyking F30 is slow. Slower than even crappy plush slow.
Reflash your esc ASAP
redridinghood is offline Find More Posts by redridinghood
Old Jun 24, 2012, 02:18 AM
Netherlands
Joined Feb 2009
Hi use the blueseries HKz30A not the f30.
Old Jun 24, 2012, 03:48 AM
KariY is offline
Joined Jan 2012
Hi, i have used with YS same but branded to maytech and flashed with simonk and it's rock solid and smooth. Highly recommend to reflash them. Also mine is flying very nice and smooth already, just need to find best possible props.
Can anyone explain how changing roll and pitch P values affect? I still have some wobble in windy with 13X6,5 props and like to have it more relaxed. It's not even close much as with wookong in Cinestar size frame with smaller props, but should i try rise or lower P value, or something else?
K
Old Jun 24, 2012, 03:51 AM
Netherlands
Joined Feb 2009
Ok looks like I am getting there. I changed the esc from 8khz to 16khz and now the twitching is almost gone. In gps mode alt-hode is verry acceptable then it fluctuates within 30cm. Only a bit more when I get a gust of wind. But verry acceptable now. Only in manual alt hold it still fluctuates 1m or more. So to round it up in gps mode it looks good. Only in manual alt-hold it still fluctuates a lot. But all and all i am starting to like the system again .
O and i also found out why the android app crashes when sending data. It only works if you put your language in English of you use other european langage it will crash while sending data. I believe it is beceause in europe we use , instead of . as a seperator.
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
