Old Jun 21, 2012, 03:23 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Originally Posted by KariY View Post
No success with endpoints at 120 both and auto throttle calibrations off for sure. Hmmm.. ideas?
So what is it not doing? After you cal throttle, does it properly respond to TX throttle, and then gets confused with the output from Y6?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jun 21, 2012, 03:26 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
Does this help?
Castle Quick Tip- Throttle Calibration.wmv (3 min 23 sec)
redridinghood is offline Find More Posts by redridinghood
Old Jun 21, 2012, 03:30 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
No it's not even starting up. Just blinking red leds in castles. This throtte calibration and channel alignment of YS confuses whole thing. I have been calibrating castles many times successfully via RX but in this case that's not possible as channel alignment (endpoints) is different after YS MC.
KariY is offline Find More Posts by KariY
Old Jun 21, 2012, 03:40 AM
Joined Dec 2010
Maybe try and do the calibration before hooking up the YS-X6. I used my DJI esc's for a while without doing the calibration on the YS.
Old Jun 21, 2012, 03:42 AM
KariY is offline
Joined Jan 2012
Yeah that's what i tried first, but doesn't startup.
Old Jun 21, 2012, 03:59 AM
TNTJET is offline
Find More Posts by TNTJET
Wish i was a flight pack
TNTJET's Avatar
Australia, NSW, Bass Hill
Joined Jan 2012
Have you set esc firmware to multirotor?
TNTJET is offline Find More Posts by TNTJET
Old Jun 21, 2012, 04:05 AM
KariY is offline
Joined Jan 2012
Yes they have been working like charm with wkm. Actually i changed nothing but controller. This is too confusing for me right now, i'll replace flashed esc:s instead.
Old Jun 21, 2012, 04:51 AM
TNTJET is offline
TNTJET's Avatar
Joined Jan 2012
in android gcs you have a choice to set other esc have you tried that?
Old Jun 21, 2012, 04:54 AM
timecop is offline
Joined Dec 2010
I wouldn't go changing ESC settings in GCS unless you want props in your face.
X6 outputs standard PWM that normal escs work with without any problems.
You must be doing something wrong somewhere.
Old Jun 21, 2012, 04:55 AM
TNTJET is offline
TNTJET's Avatar
Joined Jan 2012
I use hobby lord /xa ultra pwm esc's without a glitch on my octo.
Old Jun 21, 2012, 04:56 AM
TNTJET is offline
TNTJET's Avatar
Joined Jan 2012
Yeah sorry props off!!
Old Jun 21, 2012, 06:07 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by Tahoe Ed View Post
You are calibrating the compass which is located in the GPS unit. It looks like the GPS is slightly off center.
Hi Tahoe Ed
That is what I initially thought and by hanging the hexa like I have shown previously and balancing it with a spirit level horizontally and ensuring that it is both vertically and horizontally aligned, I took the compass off and moved it around and it has no impact on the LED.
Thats what made me think that it is the IMU and testing this morning, the IMU does have an impact on the LED, and after a bit of time I managed to get the position of the IMU set so that the LED comes on. Unfortunately it is now no longer aligned with the Hexa, but the LED is shining when the Hexa is vertically aligned.
So, my thoughts are that something must have shifted, or not soldered in the right position in the IMU.
I am now going to go outside and try and calibrate the compass and hopefully I can get it done properly this time.
Rob
robone is offline Find More Posts by robone
Old Jun 21, 2012, 06:40 AM
KariY is offline
Joined Jan 2012
Don't have a clue what "other esc" setting is so not going to test with castles until there is in manual what that means.
Old Jun 21, 2012, 06:49 AM
timecop is offline
Joined Dec 2010
He means, in android gcs, besides standard/500hz/i2c esc, there's also an "other" setting, but I wouldn't recommend touching that without information about the parameters used i.e. pulse width/period/etc, and especially with props on
Old Jun 21, 2012, 07:21 AM
KariY is offline
Joined Jan 2012
Yeah i know there is that "joker"-setting but i don't want to try it first with expensive castles I'll try it maybe with cheap esc:s first to see what that setting does. I changed TC your flashed HK:s and all working fine with standard settings. I hope someone explains when find out what that other esc setting does, there's nothing in manual.
As Castle ESC:s throttle calibration is very different to other esc:s (actually not possible to calibrate but need to calibrate tx to match esc) it gets really confusing when try set endpoints match with MC between tx and esc. If someone finds a solution please let me know. I guess we need to first try calibrate MC channel alignment with "wrong" endpoint settings but it's just a guess what the endpoint settings should be in this state to make this work. Then find real endpoints in throttle calibration mode and after that redo channel alignment again with right settings.
Kari
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
