Old Jun 20, 2012, 02:54 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Spent another half day trying to calibrate the Compass and get the GPS to work, but I always had a problem getting the vertical calibrated because I always had to angle the arms.
So this evening I tested all the arms and the location of the IMU all the arms are in the correct position and so is the IMU however, now I think I know why I have been having problems calibrating my hexa.
Even though the IMU is located at the centre point and is located vertically in the axis, to calibrate the compass I have to move the hexa away from the vertical by about 5-10deg to get the LED to shine and to do the calibration, which makes it difficult and also I think it is what is puting the vertical circle off centre, which is what I think has been giving me the GPS problem.
Any solutions as how to rectify without stripping the IMU and shifting the electronics. I suppose I could always move the IMU so that it is facing 10deg the other way
Has anyone opened the IMU yet?
Any good advice is welcome
robone is offline Find More Posts by robone
Old Jun 20, 2012, 03:50 PM
RCI is offline
RCI
Find More Posts by RCI
RCI
RCI's Avatar
Joined Jun 2012
Yes, I opened an IMU. see photos
RCI is offline Find More Posts by RCI
Old Jun 20, 2012, 05:13 PM
xrotor_rg686 is offline
Find More Posts by xrotor_rg686
Joined Mar 2012
PC GCS unresponsive
I think I know why the PC GCS hangs or unresponsive when no internet connection. I did some research and I found out that the Google earth plug-in they use in the program does not work in offline mode looks like you need internet access all the time. Looks like we can't use the PC GCS in the field if no internet connectivity. I guess back to android app
xrotor_rg686 is offline Find More Posts by xrotor_rg686
Old Jun 20, 2012, 09:26 PM
GotHeliRC is offline
Find More Posts by GotHeliRC
http://gothelirc.com/
GotHeliRC's Avatar
United States, AZ, Chandler
Joined Dec 2011
Xrotor: I will talk to them about it, thanks.
On the side note, just receive back the unit from tc3twin, slap it onto my old F450 quad, total set up time was 20minutes. Left all setting the same, only change aircraft type, lipo cells to 4 and here's the test video. Didn't even change any gain before take off... the second part of the video is when I made some changes to it would hold better in GPS hold at the end (increase main gain from 60-68... Motion compensate from 85-100.
So no, there's no problem with the unit what so ever. Wifi connect right away, 8 satelites within 20 seconds, atittude value is 0.
For those out there who not having success tunning your unit to perfection. My suggestion is please take a step back, relax and take it easy and I am sure you can figure it out. After all, it's a autopilot system that required USER set up/command.
tctwin ys x6 (1 min 57 sec)
GotHeliRC is offline Find More Posts by GotHeliRC
Site Sponsor
Old Jun 20, 2012, 10:17 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
You are calibrating the compass which is located in the GPS unit. It looks like the GPS is slightly off center.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Jun 21, 2012, 12:29 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Me too, some more info here:
http://www.rcgroups.com/forums/showthread.php?t=1676150
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jun 21, 2012, 12:49 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
Welcome back tc.
The forums were boring without your posts.
redridinghood is offline Find More Posts by redridinghood
Old Jun 21, 2012, 12:53 AM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Glad they let you make bail tc. Good to see your alive.
kd4wen is offline Find More Posts by kd4wen
Old Jun 21, 2012, 01:23 AM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
so regarding the lack of a battery backup for the GPS...
The unit doesn't take forever to get a nice fix, but I suppose if one were to install a tiny battery, the unit could hot start/get a fix that much quicker no?
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jun 21, 2012, 01:33 AM
timecop is offline
Joined Dec 2010
That's what you would think (the components are just a supercap/battery + diode), but it already locks in pretty quick even from cold start, presumably due to the nice metal shield.
Old Jun 21, 2012, 01:36 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Hi guys,
I swapped my YS to cinestar but there's one thing i cannot get done. Has anyone yet set Castle Phoenix endpoints work with YS. Regular esc:s are straight forward but castles i just cannot get done. I can set full throttle point fine but when i start bring throttle down to set throttle off point, castles sees endpoint already at the middle throttle on the way down. No matter how low i set endpoint in tx.
All tips are welcome, i really like to try phoenix escs with ys as they have been wonderful escs after last fw update
Kari.
KariY is offline Find More Posts by KariY
Old Jun 21, 2012, 01:44 AM
timecop is offline
Joined Dec 2010
Huh? You should disable any sort of automatic throttle curve stuff on the esc, and just calibrate them with throttle endpoints on TX set to say ~120% (should give you around 1000..2000us more or less).
robone is offline
Joined Sep 2010
RCI and TC. Thanks for those images.
Old Jun 21, 2012, 02:35 AM
TNTJET is offline
Find More Posts by TNTJET
Wish i was a flight pack
TNTJET's Avatar
Australia, NSW, Bass Hill
Joined Jan 2012
+1 TC always enlightening (must have a lot of spare time)
TNTJET is offline Find More Posts by TNTJET
Old Jun 21, 2012, 03:18 AM
KariY is offline
Joined Jan 2012
No success with endpoints at 120 both and auto throttle calibrations off for sure. Hmmm.. ideas?
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
