Old Jun 18, 2012, 11:27 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
It was about 4 hours job to set all up and all seems to be working. I'll wait if it calms a little later tonight to make maiden with F550. Just few questions left:
Can someone explain what does Broke rod and Protection settings? I'm using S-Bus but Remote Control Mode seems to switch always back to adaptive. Also what is magnet Num in data sheet, should i put there something?
Kari
KariY is offline Find More Posts by KariY
Old Jun 18, 2012, 11:32 AM
GotHeliRC is offline
Find More Posts by GotHeliRC
http://gothelirc.com/
GotHeliRC's Avatar
United States, AZ, Chandler
Joined Dec 2011
Uh oh!
It seem that the YS is on a lock down that was due to the after June15th unlimited trial thing.
So I think this is why JDreitman waypoint didn't work (possible more than 100meters radius or more then 4 points). Somehow the speed now is limited as well, the speed is not suppose to be limited. I will let them know so this can be fix quickly.
Hold tight!
GotHeliRC is offline Find More Posts by GotHeliRC
Site Sponsor
Old Jun 18, 2012, 01:13 PM
xrotor_rg686 is offline
Find More Posts by xrotor_rg686
Joined Mar 2012
@gotheliRC
Can you ask them also to fix the PC GCS so that the last map location will
be cached and displayed when no internet connection and make sure does not hang without internet connection?
xrotor_rg686 is offline Find More Posts by xrotor_rg686
Old Jun 18, 2012, 01:17 PM
GotHeliRC's Avatar
Joined Dec 2011
Originally Posted by xrotor_rg686 View Post
@gotheliRC
There's a red flag icon on the top menu tap. If you flag a location, it will remember that part of the map.
Site Sponsor
Old Jun 18, 2012, 01:33 PM
Joined Mar 2012
I don't think it will save that part of the map though like the android app.
If you don't have internet connection the PC GCS just hangs. Maybe I need to wait longer? I dont know.
Old Jun 18, 2012, 01:47 PM
KariY is offline
Joined Jan 2012
Kari
GotHeliRC, can you or someone please help with these? Also can someone explain how to set failsafe with Futaba. Flight mode does not change to back landing if i turn tx off.
Old Jun 18, 2012, 02:37 PM
GotHeliRC's Avatar
Joined Dec 2011
Broken Rod: default is enable, this is the V stick for throttle arming, diable this remove the safety. (this is what they said,but I think I have tried it and it didn't remove the arm requirement)
Protection: 5 seconds disarm, disable this will disable automatic disarm.
As for the fail safe, it should be set on your receiver/tx it have nothing to do with the YS. You have to set your RX so what if it loose signal, what position for all the channel it will output. Refer to your receiver/transmitter manual.
Site Sponsor
Old Jun 18, 2012, 04:13 PM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
I think my YAW problem has to be the ESC calibration.
I calibrated the ESCs one by one (SimonK) and I get the beep (throttle up) and beep beep (throttle down) that means everything worked.
But when I try what fajar wrote here http://www.rcgroups.com/forums/showp...&postcount=853 or the stick movement way (to arm) I can't get the "beep" (up) or the "beep beep" (down) from the ESCs. I tried many times and couldn't get this to work. Why?
What i'm doing wrong? (the throttle travel is standard and its not trimmed also)
Reginak is offline Find More Posts by Reginak
Old Jun 18, 2012, 04:17 PM
KariY is offline
Joined Jan 2012
Thanks GotHeliRC, didn't see any difference in arming switching on and off Broke Rod setting. So F/S should be fine by default for my T8FG then, i just waited some kind of indication of rth (or rtc) to flight mode screen after switching tx off.
First flights behind and all good so far. After tweaking R/P and atti sensitivity down a bit it flies quite well. I added motion compensation to 110 and it smoothened a bit, but still little twitchy reactions to controls. What kind of gain settings you are having for your setups? I have F550 with 9X5 graupners and flashed esc:s, i think i will swap YS to Cinestar later this week.
Old Jun 18, 2012, 04:22 PM
KariY is offline
Joined Jan 2012
I guess you have tried it already but i had to do it via Installation guide wizard in iPhone app, and go to setting mode and then do arming procedure before setting throttle to up position. Other than that didn't work for me.
Old Jun 18, 2012, 09:22 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Uh oh!
Hold tight!
interested to know what they say, because I sure can't change my speed now.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Jun 18, 2012, 09:29 PM
GotHeliRC's Avatar
Joined Dec 2011
I think the biggest issue with throttle calibration is first you need to understand that the YS have throttle block... Unless you do the combination stick (rudder left, throttle low and aileron right, elevator back... then full throttle). It will never go full throttle, so your esc will never recognize that it's suppose to do throttle calibration. The other thing is look under data to see if your Throttle low value if 7 or believe, sometime your esc will not see that as a low enough value to arm itself. So adjust your Throttle travel in your radio if nessesary.
Yes, confirmed. I will keep you guys update.
Site Sponsor
Old Jun 18, 2012, 09:33 PM
tc3wins is offline
Find More Posts by tc3wins
Multirotor Builder!!!!!
South Carolina
Joined Mar 2009
Gothelirc. Check your E-mails.
tc3wins is offline Find More Posts by tc3wins
Old Jun 18, 2012, 10:21 PM
tc3wins is offline
South Carolina
Joined Mar 2009
has anyone else been having trouble getting ahold of gothelirc. I sent a few e-mails and tried calling but nothing.
Old Jun 18, 2012, 11:05 PM
cryhavoc38's Avatar
Joined Mar 2007
Nope, he responded to the group a few minutes before you posted a message to him
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 10:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 07:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 10:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 29, 2012 12:28 AM
