Old Jan 08, 2013, 03:49 PM
ikotikot is offline
Find More Posts by ikotikot
Joined May 2008
Originally Posted by maximus-rc View Post
Hi, remove propellers and try to reverse throttle channel !
Cheers
Maximus
yes, did already that and stil no beep. throttle in gcs is 7min & 90max, ail+rud+ele sticks are in the right direction.
ikotikot is offline Find More Posts by ikotikot
Old Jan 09, 2013, 09:11 PM
ikotikot is offline
Joined May 2008
Originally Posted by ikotikot View Post
I successfully setup my ys-x6 on an octo frame and had few flights on it. I got a new hexa frame and tried to setup the ys-x6 on it. Did all the same procedure as before but now it won't arm.
Checked all data in the gcs and all seemed fine, stick direction, aircraft type 3, etc. But this time the esc's are not beeping so i can't do esc calibration. All esc's and motors are working fine when individually checked without passing through the autopilot
Setup was done in accordance with the install guide.
The esc's are not beeping. The motors wont arm. Can't figure out what's wrong this time.
Any help will be appreciated.
Cheers.
i had it sorted out. i replaced the Turnigy Multistar 45amp OPTO to earlier version non-OPTO's and it worked.
now, what happened to these new OPTO Multistar's? why don't they work with YS-X6? if you test them individually without passing through the YS-X6 - it works......but not with X6
sweetspot (3 min 37 sec)
Old Jan 12, 2013, 05:57 AM
ikotikot is offline
Joined May 2008
i also noticed that the throttle is so sensitive on the autopilot, throttle stick input really jerks the frame up and down - so uncomfortably crisp for me. i hit the ground on the 1st test flight and broke the landing gear.
is there a way we can slow down the response?
Old Jan 12, 2013, 11:15 AM
neato4u is offline
Find More Posts by neato4u
neato4u's Avatar
Malaysia
Joined Feb 2012
Originally Posted by GotHeliRC View Post
Steve,
Many people have problem configuring the YS is because they do not want to understand the concept of how this thing work and only want to know the step on how to do it.
All you have to do is basicly make sure you set the throttle direction correctly by looking at the GCS and low throttle should be 7 or lower and high is 90-99. If not, then you should do Channel Align again. Next I normally Power my YS and Wifi with a small separate battery, let it connect to my wifi, then go to Init set up, then V stick to arm the motor. (I do believe putting it into Init set up remove the gyro sensor out of the equation. After you arm the motor, give it full throttle then power on all your ESC at once. Wait for the beep... throttle down... you're done.
All it is is you want the YS to output a full throttle signal for all the esc before you power on the esc... In order to do that you have to V stick and full throttle to arm the motor... But in order for it to output the full throttle for all ESC it have to be in zero mode (init mode) Now I am not sure if that's exactly what it does... but it work for me in sync all the esc together.
Thanks! I think this is what I need to do to calibrate these escs. LOL, hope this works and it better be after some hours of thread digging..
neato4u is offline Find More Posts by neato4u
Old Jan 12, 2013, 12:13 PM
maximus-rc is offline
Find More Posts by maximus-rc
RTF copters maker
maximus-rc's Avatar
South France
New coaxial octo
Hi all,
this is my last Coaxial octocopter with YS-X6....
Cheers
Maximus
maximus-rc is offline Find More Posts by maximus-rc
Old Jan 14, 2013, 04:18 AM
archet is offline
Find More Posts by archet
Mozambique, Maputo City, Maputo
Joined Sep 2012
Manual servo position vs Realtime servo position
Hi, I would like to understand the difference between Manual servo position and Realtime servo position.
When I play back the log file in PC GCS I see that the rudder in Realtime servo position assumes values up to L13 (with the box background color in red) while in Manual servo position it is with 'MP' value. Even the throttle assumes values different from those of Manual servo position.
Does this difference affects somehow the flight? what to do to correct it?
archet is offline Find More Posts by archet
Old Jan 14, 2013, 12:16 PM
pepere is offline
Find More Posts by pepere
Joined Oct 2011
Throttle too much sensitive
Hi,
I just finished to built my X6 , and my question is to know how to reduce the sensivity of the throttle.
Is in "throtle P or I" ?
pepere is offline Find More Posts by pepere
Old Jan 14, 2013, 12:19 PM
RTF copters maker
maximus-rc's Avatar
South France
Originally Posted by pepere View Post
Hi,
The EXPO on your radio !!!
Old Jan 14, 2013, 04:48 PM
pepere is offline
Joined Oct 2011
thanks maximus-rc. Only that solution ?
Old Jan 15, 2013, 10:03 AM
RTF copters maker
maximus-rc's Avatar
South France
For me, standard sensitivity of throttle is very good, except when you switch from altitude mode to manual...you can have some...surprise !!! (too much or not enough)...
Cheers
Maximus
Old Jan 15, 2013, 10:12 AM
neato4u is offline
neato4u's Avatar
Malaysia
Joined Feb 2012
does it auto level in atti mode too? (beside hold alt)
manual mode means full manual? no auto level as well?
Old Jan 15, 2013, 12:30 PM
RTF copters maker
maximus-rc's Avatar
South France
Manual is much more "assited" than on WKM, and much more easy to fly (with auto-level).
Second position is altitude mode (with auto-level) then third is GPS with altitude holding .
Cheers
Maximus
Old Jan 15, 2013, 12:59 PM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
As Maximus says. Manual ,mode is actually a full Attitude mode and a pleasure to fly. I only use Manual mode and Auto Hover mode. I have taken altitude mode off my Tx as I find it not worth it.
Cheers
Rob
robone is offline Find More Posts by robone
Old Jan 15, 2013, 03:47 PM
pepere is offline
Joined Oct 2011
I see also that the motors stop when i switch on attitude mode. Where is the problème ?
Old Jan 15, 2013, 03:50 PM
RTF copters maker
maximus-rc's Avatar
South France
On attitude mode, motors only start after 20/30% throttle.
You must push up to 55/60% for automatic take off....
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
