Old Oct 27, 2012, 03:41 AM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
A photo of your setup please.
Tx/rx?
PC GCS > Parameters > Remote control mode?
Mr_westie is offline Find More Posts by Mr_westie
Old Oct 27, 2012, 05:13 AM
aok is offline
aok
Find More Posts by aok
aok
Joined Dec 2011
Bad picture, but it's probably not easy to see a mistake in that mess .. hehe
I have conection between tx/rx.
Remote control mode= Adaptive
PS: Its Y6 copter...
aok is offline Find More Posts by aok
Old Oct 27, 2012, 05:19 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Originally Posted by aok View Post
Yes three times ...
Okay...this is what your channels are supposed to look like. You may have to reverse a few channels, because from what I can see your Elevator is wrong.
robone is offline Find More Posts by robone
Old Oct 27, 2012, 05:25 AM
robone is offline
Joined Sep 2010
I see your IMU is located underneath your Main Controller. Not the right thing to do. It has been mentioned here before that this has been known to cause problems. Use double sided tape and fix it to the top of your Main Controller.
You should also clean up your wiring a bit.
Edit: Another thing. You a flying a Y6 so your Aircraft type must either be 6 or 7. You have it shown as 1
Have you read the manual?
Old Oct 27, 2012, 06:39 AM
aok is offline
aok
aok
Joined Dec 2011
When everythin works I`m going to clean up
IMU is on top.
Tank you for really nice pictures!!
Based on your photos I have located som problems I think, but I dont know how to fix them...
Old Oct 27, 2012, 06:55 AM
Salocin is offline
Find More Posts by Salocin
Salocin's Avatar
Joined Aug 2012
Take the IMU off the soft sponge and use foam tape to hard mount it to the FC. Don't use that sponge, it is too soft.
Salocin is offline Find More Posts by Salocin
Old Oct 27, 2012, 07:47 AM
KariY is offline
Find More Posts by KariY
Finland, Uusimaa, HKI
Joined Jan 2012
Also take wifi module away under imu and locate it as far as possible from imu and gps.
KariY is offline Find More Posts by KariY
Old Oct 27, 2012, 08:32 AM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
I have my IMU under my FC and it's been working fine,chould I be concerned as I've had may50 flights that way
Rich
richkphoto is offline Find More Posts by richkphoto
Old Oct 27, 2012, 08:35 AM
robone is offline
Joined Sep 2010
IMU is on top.
Your values are all wrong. You have to go through the channel alignment and you have to go through the ESC stroke (Throttle) Calibration. Follow clear instructions in the Guide. Read the manual. Once you have done that, then check to see if the numbers tie up with what my pics show and then if not, you must reverse the channels on your Tx.
Also get rid of the wifi module and the sponge. As I mentioned...Use double sided tape. Move the wifi module to one of the arms or the legs.
Old Oct 27, 2012, 08:37 AM
robone is offline
Joined Sep 2010
Rich
I just know of a few people who have had problems and as soon as they moved it to on top of the Main Controller, the problems went away. But, hey, if your is working, leave it alone.
Old Oct 27, 2012, 10:07 AM
aok is offline
aok
aok
Joined Dec 2011
ok, I'm one step further, but when I take the aileron stick to the left is the rudder that react?? can I change this in pc gcs? (and elevator stick responds elevator and aileron in the program)
I cant find it in the manual...
Old Oct 27, 2012, 10:52 AM
robone is offline
Joined Sep 2010
Check that your cables from your Rx to your Main Controller are connected correctly and going to the right channels.. This has nothing to do with the PC GCS.
Old Oct 27, 2012, 10:56 AM
aok is offline
aok
aok
Joined Dec 2011
anyone know any videos that show how to calibrate for example channel alignment?
EDIT:
Now it look like this:
Stickmove - Pc gcs
Throttle - Throttle
Rudder - Elevator
Elevator - Aileron
Aileron - Rudder
Old Oct 27, 2012, 01:12 PM
aok is offline
aok
aok
Joined Dec 2011
According to the manual that right.
I use futaba.
channel 1 = A
channel 2 = E
channel 3 = t
channel 4 = r
channel 5 = 5
channel 6 = 6
Old Oct 27, 2012, 01:16 PM
robone is offline
Joined Sep 2010
EDIT:
Stickmove - Pc gcs
Throttle - Throttle
Rudder - Elevator
Elevator - Aileron
Aileron - Rudder
Its quite simple. Just change the cables around so that the channels line up.
For interest, what Tx are you using?
Discussion YS-X6 testing GotHeliRC Multirotor Talk 1200 Aug 08, 2013 09:23 AM
New Product Test video of YS-X6 Autopilot system pzhang Multirotor Talk 141 Jun 07, 2012 06:50 AM
Discussion New UAV System from Zero UAV alishanmao UAV - Unmanned Aerial Vehicles 2 Apr 19, 2012 09:02 AM
New Product YS-X6:A coming new king in the multi rotor heli world yiny0730 Multirotor Talk 13 Mar 28, 2012 11:28 PM
